[hpct] HPM issues: works with GNU compiler set
Vitali A. Morozov
morozov at anl.gov
Thu Sep 4 18:39:45 CDT 2008
Dear All;
I am sorry it took me so long to verify this but, in short, HPCT hpm
part works with GNU compiler set for both Fortran and C++.
Thank you very much everyone, and particularly Christoph Pospiech, for
the full list of necessary commands and examples!
Here are technical details for those interested. I was testing a serial
mode only.
1) Fortran
program Test_HPM
implicit none
include "mpif.h"
#include "f_hpm.h"
integer ierr
call MPI_Init( ierr )
call f_hpminit( 0, "Test_HPM" )
call f_hpmstart( 0, "MEASURE" )
call f_hpmstop( 0 )
call f_hpmterminate( 0 )
call MPI_Finalize( ierr )
stop
end
Here both includes are important and exactly as written. The second with
the # sign will be processed by pre-processor.
To compile:
mpif90 -g -x f77-cpp-input -std=gnu -Wp,-DHPM -I$(IHPCT_BASE)/include -c
Test_HPM.f
mpif90 -g -dynamic -o Test_HPM Test_HPM.o -L$(IHPCT_BASE)/lib -lhpm
-llicense
Here "-x f77-cpp-input -Wp,DHPM" is important.
To run:
TASK=Test_HPM
qsub -A Performance -q short -t 0:10:00 -n 1 --proccount 1 --mode smp -O
$TASK \
--env IHPCT_BASE=$IHPCT_BASE:LD_LIBRARY_PATH=$IHPCT_BASE/lib $TASK
Here, LD_LIBRARY_PATH is important.
As promised, the result is two files, Test_HPM.viz and Test_HPM.hpm. The
first can successfully be processed with peekperf, the second is a
regular text file with counter information.
2) C++, simpler, and I give only the differences
#include <mpi.h>
#include "libhpm.h"
int main(int argc, char **argv)
MPI::Status stat;
MPI::Init( argc, argv );
int rank = MPI::COMM_WORLD.Get_rank();
hpmInit( rank, "hpct-hcpm" );
hpmStart( 1, "multiply-regular" );
hpmStop( 1 );
hpmTerminate( taskID );
MPI::Finalize();
return 0;
mpicxx -g -I$(IHPCT_BASE)/include -c Test_hpm.cxx
mpicxx -g -dynamic -o Test_hpm Test_hpm.o -L$(IHPCT_BASE)/lib -lhpm
-llicense
TASK=Test_HPM
$TASK \
Once again, thank you very much, Christoph!
with best regards,
Vitali
p.s. An open issue is how to make the same with IBM XL compiler???
More information about the hpct
