[intrepid-notify] Monday Maintenance reminder for September 29, 2008
Tisha Stacey
tstacey at alcf.anl.gov
Fri Sep 26 15:40:27 CDT 2008
The Intrepid system will have its regularly scheduled Monday maintenance
period this coming week.
Maintenance starts: 9:00 a.m. US CDT on Monday, September 29, 2008
Expected end: 5:00 p.m. US CDT on Monday, September 29, 2008
During this time:
- there will be no access to the login nodes
- no jobs will be run on the system.
During this window, changes will be made to the user environment:
- GPFS upgrade
- network maintenance
- increase default block boot timeout
- Cobalt upgrade (changes detailed below)
During this maintenance period, Cobalt on Intrepid will be upgraded to
match the version currently running on Surveyor. The new version of
Cobalt includes the following changes:
- (c)qstat now checks both versions of (C)QSTAT_HEADER and
(C)QSTAT_HEADER_FULL
- the COBALT_JOBID environment variable is now available to script mode
jobs
- you can specify an alternate location for the .cobaltlog file using
the --debuglog option to (c)qsub
- you can specify the umask for a job using the -u argument to (c)qsub
- qmove will now correctly run job submission filters
- script jobs will now set the cwd correctly
- partlist now shows when a partition is unavailable due to hardware in
an error state
- (c)qstat output format will have a new shorter state field option,
similar to PBS's state field: "Q" for queued, "R" for running, and
"H" for hold
- The long form states will be changed to add more specific state
information, eliminate spaces, and make the output narrower. Here are
the new state names and their definitions:
dep_hold: dependency hold
maxrun_hold: maxrunning hold
user_hold: user hold
starting: running - starting
executing: running - executing
killing: running - killing
admin_hold: admin hold
Mail will be sent when the work has been completed and the machines are
again available for general use. Please send any comments or questions
to support at alcf.anl.gov
Thank you,
The ALCF Support Team
More information about the intrepid-notify
