[intrepid-notify] ALCF Weekly Updates - June 2
ALCF User Services
support at alcf.anl.gov
Thu Jun 2 18:09:44 CDT 2011
*** Attention All Users ***
The /home filesystems on Surveyor and Intrepid are near capacity. Delete unneeded data and move data that doesn't need to be immediately accessible out of /home. We'll even help you. Contact support at alcf.anl.gov.
*** CORRECTION: April IBM Compiler Available ***
The default XL compiler version is the December 2010 release. Choose the April 2011 release using the softenv key "@ibm-compilers-apr2011". See https://wiki.alcf.anl.gov/index.php/Compiling_and_linking#Selecting_XL_Compiler_versions for detailed directions. Please build your application with the latest version and report any problems to us at support at alcf.anl.gov.
***Measure How Much Memory Your Code Uses***
Go to: https://wiki.alcf.anl.gov/index.php/Debugging#How_do_I_get_information_on_used.2Favailable_memory_in_my_code.3F.
*** Workshop June 7-9 May Affect System Availability ***
Due to system reservations for the Leap to Petascale workshop (June 7-9), the standard queues on Intrepid those days may be blocked or operating with reduced resources. As a result, consider submitting shorter jobs for better throughput. We will manage the workshop reservations to minimize the impact on production jobs and to meet workshop needs. Please use the 'showres' command for up-to-date information on the size and duration of the workshop reservations. For assistance, contact support at alcf.anl.gov.
*** Register Now for IWOMP 2011 - June 13-15 ***
The International Workshop on OpenMP (IWOMP) is an annual workshop dedicated to the promotion and advancement of all aspects of parallel programming with OpenMP. Held in Chicago this year, the event will feature tutorials on topics of interest to current and prospective OpenMP developers at all levels, as well as technical papers and panel sessions. To register, visit: http://www.ncsa.illinois.edu/Conferences/IWOMP11/.
*** Important Dates ***
June 13-15: IWOMP 2011, Chicago: http://www.ncsa.illinois.edu/Conferences/IWOMP11/
June 30: Monthly User Call: http://www.alcf.anl.gov/news/eventsdetail.php?id=1257
July 10-14: SciDAC 2011, Colorado: http://press.mcs.anl.gov/scidac2011/
SC11 - Important Dates: http://sc11.supercomputing.org/?pg=dates.html
URL: <http://lists.alcf.anl.gov/pipermail/intrepid-notify/attachments/20110602/ab8d15dd/attachment.htm>
More information about the intrepid-notify
