[intrepid-notify] ALCF Weekly Updates - May 27, 2011
ALCF User Services
support at alcf.anl.gov
Fri May 27 05:25:22 CDT 2011
*** Upcoming Change to Cobalt Script Jobs ***
During the next scheduled Cobalt upgrade (Wednesday, June 1), a change to Cobalt may affect script-mode jobs. The execution environment that script jobs will receive when started will change to be the default environment for the user who submitted the job at the time the job runs. Previously, script-mode jobs inherited Cobalt's environment when started. Please check that the environment variables you are using in your script-mode jobs are set to expected values after this change. You should also no longer have to source your environment to bring your default environment variables into a script job. For assistance, contact support at alcf.anl.gov.
*** Workshop June 7-9 May Affect System Availability ***
Due to system reservations for the Leap to Petascale workshop (June 7-9), the standard queues on Intrepid those days may be blocked or operating with reduced resources. As a result, consider submitting shorter jobs for better throughput. We will manage the workshop reservations to minimize the impact on production jobs and to meet workshop needs. Please use the 'showres' command for up-to-date information on the size and duration of the workshop reservations. For assistance, contact support at alcf.anl.gov.
*** /home filesystems Near Capacity ***
The /home filesystems on Surveyor and Intrepid are near capacity. Please delete data you no longer need, and/or move data you don't need immediate access to out of /home. For help transferring or archiving data, please contact support at alcf.anl.gov.
*** CHANGE: Maintenance Skips Memorial Day, Next Maintenance is June 1 ***
Due to the holiday, the next routine maintenance will be Wednesday, June 1, at 9 a.m. CDT (14:00 UTC). Please watch the "notify" list for projected and actual release times. If you have questions, please contact ALCF User Services at support at alcf.anl.gov.
*** Data Analytics Clusters on the BG/P ***
We have data analytics clusters attached to both ALCF Blue Gene machines. For details, see
https://wiki.alcf.anl.gov/index.php/Using_the_Data_Analytics_Cluster_(Eureka).
*** April IBM Compiler Available ***
The default XL compiler version is the December 2010 release. Choose the April 2011 release using the softenv key "+ibm-compilers-apr2011". See https://wiki.alcf.anl.gov/index.php/Compiling_and_linking#Selecting_XL_Compiler_versions for detailed directions. Please build your application with the latest version and report any problems to us at support at alcf.anl.gov.
*** Register Now for IWOMP 2011 - June 13-15 ***
The International Workshop on OpenMP (IWOMP) is an annual workshop dedicated to the promotion and advancement of all aspects of parallel programming with OpenMP. Held in Chicago this year, the event will feature tutorials on topics of interest to current and prospective OpenMP developers at all levels, as well as technical papers and panel sessions. To register, visit: http://www.ncsa.illinois.edu/Conferences/IWOMP11/.
*** Important Dates ***
June 13-15: IWOMP 2011, Chicago: http://www.ncsa.illinois.edu/Conferences/IWOMP11/
July 10-14: SciDAC 2011, Colorado: http://press.mcs.anl.gov/scidac2011/
SC11 - Important Dates: http://sc11.supercomputing.org/?pg=dates.html
URL: <http://lists.alcf.anl.gov/pipermail/intrepid-notify/attachments/20110527/fffa2a71/attachment.htm>
More information about the intrepid-notify
