[intrepid-notify] ALCF Weekly Updates - September 27
ALCF User Services
support at alcf.anl.gov
Fri Sep 28 06:22:17 CDT 2012
*** Allinea DDT Updated ***
The Allinea DDT parallel debugger has been updated to version 3.2-24924.
It is now the default on all BG/P systems through the softenv key
"+ddt". This version has various improvements including: a bug fix for
local variables missing from the display in Fortran codes; a fix for a
GUI hang; improved performance at large process counts. Full release
notes are available at: http://www.allinea.com/products/ddt-support
*** View /home Storage Usage on Intrepid ***
To view your storage usage for /home on Intrepid, use the following
command: myquota (full path: /usr/local/bin/myquota). Please note that
all of your files under /home are counted in your quota: files in
/home/projects or files in other user directories owned by you are also
counted. For more information about our new home directory quota policy,
please visit
http://www.alcf.anl.gov/resource-guides/data-policy#space-limit-enforcement
More information about the intrepid-notify
