[Llvm-bgq-discuss] clang ICE
Hal Finkel hfinkel at anl.gov
Tue Dec 18 11:58:08 CST 2012
----- Original Message -----
> From: "Hal Finkel" <hfinkel at anl.gov>
> To: "Michael Blocksome" <blocksom at us.ibm.com>
> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Monday, December 17, 2012 4:54:03 PM
> Subject: Re: [Llvm-bgq-discuss] clang ICE
> > Sent: Monday, December 17, 2012 3:49:30 PM
> > Michael,
> > This is an LLVM inline assembly issue. If I can't figure out how to
> > fix this in the next few minutes, I'll file a bug report.
> FYI: http://llvm.org/bugs/show_bug.cgi?id=14627
I committed a fix to this bug in r170436. Assuming the buildbots don't complain, I'll update the bug report.
 -Hal
>  -Hal
> > Thanks again,
> > Hal
> > > From: "Michael Blocksome" <blocksom at us.ibm.com>
> > > To: llvm-bgq-discuss at lists.alcf.anl.gov
> > > Sent: Monday, December 17, 2012 2:29:24 PM
> > > Subject: [Llvm-bgq-discuss] clang ICE
> > > I've encountered an ICE with clang and was wondering if someone
> > > on
> > > the list could recreate the problem? I thought I'd start here
> > > instead of submitting a clang bug report since I'm using the
> > > provided patches and compile script. I'm not sure if the problem
> > > is
> > > with the patched llvm/clang or if it is in the base source.
> > > bgclang-20121213
> > > clang-bgq-r170143-20121213.patch
> > > llvm-bgq-r170143-20121213.patch
> > > I've pulled out the majority of the junk around the failure and
> > > have
> > > it down to a few files and a clang command (whittled down from -v
> > > output of the entire build). To recreate, just edit and run the
> > > 'clang_ice.sh' file.
> > > Thanks,
> > > Michael Blocksome
> > > Blue Gene Messaging
> > > _______________________________________________
> > > llvm-bgq-discuss mailing list
> > > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> > Hal Finkel
> > Postdoctoral Appointee
> > Leadership Computing Facility
> > Argonne National Laboratory
> Hal Finkel
Hal Finkel
More information about the llvm-bgq-discuss mailing list
