[Llvm-bgq-discuss] c++ linkage
Hal Finkel hfinkel at anl.gov
Fri Dec 21 15:24:27 CST 2012
Michael,
Try this: make a symlink to /bghome/blocksom/development/llvm/bgclang called /bghome/blocksom/development/llvm/bgclang++ and use that; this should call clang++ instead of clang, and that should invoke the driver's C++ logic. If that still does not work, then we'll investiage further.
 -Hal
----- Original Message -----
> From: "Michael Blocksome" <blocksom at us.ibm.com>
> To: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Friday, December 21, 2012 2:15:19 PM
> Subject: [Llvm-bgq-discuss] c++ linkage
> I seem to have a more fundamental problem as well. I can't figure out
> how to link the appropriate libstdc++ .. any ideas?
> .../test> cat vector_test.cc
> #include <vector>
> int main ()
> std::vector<unsigned> foo;
> return 0;
> .../test> /bghome/blocksom/development/llvm/bgclang -v vector_test.cc
> -o vector_test.cnk
> clang version 3.3 (trunk 170436)
> Target: powerpc64-bgq-linux
> Thread model: posix
> "/bghome/blocksom/development/llvm/install/bin/clang" -cc1 -triple
> powerpc64-bgq-linux -S -disable-free -main-file-name vector_test.cc
> -static-define -mrelocation-model static -mdisable-fp-elim
> -fmath-errno -ffp-contract=fast -mconstructor-aliases -target-cpu
> a2q -target-linker-version 2.20.51.0.2 -momit-leaf-frame-pointer -v
> -resource-dir
> /bghome/blocksom/development/llvm/install/bin/../lib/clang/3.3
> -fmodule-cache-path /var/tmp/clang-module-cache -internal-isystem
> /bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/include/c++/4.4.6
> -internal-isystem
> /bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/include/c++/4.4.6/powerpc64-bgq-linux
> -internal-isystem
> /bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/include/c++/4.4.6/backward
> -internal-isystem /usr/local/include -internal-isystem
> /bghome/blocksom/development/llvm/install/bin/../lib/clang/3.3/include
> -internal-externc-isystem /include -internal-externc-isystem
> /usr/include -fdeprecated-macro -fno-dwarf-directory-asm
> -fdebug-compilation-dir
> /bghome/blocksom/development/boost-pami/next/test -ferror-limit 19
> -fmessage-length 231 -mstackrealign -fno-signed-char
> -fobjc-runtime=gcc -fcxx-exceptions -fexceptions
> -fdiagnostics-show-option -fcolor-diagnostics -isystem
> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/sys-include
> -mllvm -enable-misched -mllvm -enable-aa-sched-mi -o
> /tmp/vector_test-f6IGjg.s -x c++ vector_test.cc
> clang -cc1 version 3.3 based upon LLVM 3.3svn default target
> powerpc64-unknown-linux-gnu
> ignoring nonexistent directory "/include"
> #include "..." search starts here:
> #include <...> search starts here:
> /usr/local/include
> /usr/include
> End of search list.
> "/bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/bin/as"
> -a64 -mppc64 -many -o /tmp/vector_test-wO5yyv.o
> "/bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/bin/ld"
> --hash-style=gnu --no-add-needed --build-id -m elf64ppc -static -o
> vector_test.cnk
> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/lib/crt1.o
> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/lib/crti.o
> /bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crtbeginT.o
> -L/bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6
> -L/bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../lib64
> -L/lib/../lib64 -L/usr/lib/../lib64
> -L/bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib
> -L/lib -L/usr/lib /tmp/vector_test-wO5yyv.o --start-group -lgcc
> -lgcc_eh -lc --end-group
> /bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crtend.o
> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/lib/crtn.o
> /tmp/vector_test-wO5yyv.o:(.text._ZNSt6vectorIjSaIjEED2Ev[_ZNSt6vectorIjSaIjEED2Ev]+0xac):
> undefined reference to `std::terminate()'
> /tmp/vector_test-wO5yyv.o:(.text._ZN9__gnu_cxx13new_allocatorIjE10deallocateEPjm[_ZN9__gnu_cxx13new_allocatorIjE10deallocateEPjm]+0x34):
> undefined reference to `operator delete(void*)'
> /tmp/vector_test-wO5yyv.o:(.eh_frame+0x87): undefined reference to
> `__gxx_personality_v0'
> clang: error: linker command failed with exit code 1 (use -v to see
> invocation)
> Thanks,
> Michael Blocksome
> Blue Gene Messaging
> From: Hal Finkel <hfinkel at anl.gov>
> To: Michael Blocksome/Rochester/IBM at IBMUS,
> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> Date: 12/18/2012 11:58 AM
> Subject: Re: [Llvm-bgq-discuss] clang ICE
> > From: "Hal Finkel" <hfinkel at anl.gov>
> > To: "Michael Blocksome" <blocksom at us.ibm.com>
> > Sent: Monday, December 17, 2012 4:54:03 PM
> > > Sent: Monday, December 17, 2012 3:49:30 PM
> > > Michael,
> > > This is an LLVM inline assembly issue. If I can't figure out how
> > > to
> > > fix this in the next few minutes, I'll file a bug report.
> > FYI: http://llvm.org/bugs/show_bug.cgi?id=14627
> I committed a fix to this bug in r170436. Assuming the buildbots
> don't complain, I'll update the bug report.
> -Hal
> > -Hal
> > > Thanks again,
> > > Hal
> > > > Sent: Monday, December 17, 2012 2:29:24 PM
> > > > Subject: [Llvm-bgq-discuss] clang ICE
> > > > I've encountered an ICE with clang and was wondering if someone
> > > > on
> > > > the list could recreate the problem? I thought I'd start here
> > > > instead of submitting a clang bug report since I'm using the
> > > > provided patches and compile script. I'm not sure if the
> > > > problem
> > > > is
> > > > with the patched llvm/clang or if it is in the base source.
> > > > bgclang-20121213
> > > > clang-bgq-r170143-20121213.patch
> > > > llvm-bgq-r170143-20121213.patch
> > > > I've pulled out the majority of the junk around the failure and
> > > > have
> > > > it down to a few files and a clang command (whittled down from
> > > > -v
> > > > output of the entire build). To recreate, just edit and run the
> > > > 'clang_ice.sh' file.
> > > > Thanks,
> > > > Michael Blocksome
> > > > Blue Gene Messaging
> > > > _______________________________________________
> > > > llvm-bgq-discuss mailing list
> > > > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> > > Hal Finkel
> > > Postdoctoral Appointee
> > > Leadership Computing Facility
> > > Argonne National Laboratory
> > Hal Finkel
> Hal Finkel
Hal Finkel
More information about the llvm-bgq-discuss mailing list
