[Llvm-bgq-discuss] Patches for r176829-20130309 (the current vesta version)
Hal Finkel
hfinkel at anl.gov
Wed Apr 17 13:03:58 CDT 2013
----- Original Message -----
> From: "Hal Finkel" <hfinkel at anl.gov>
> To: reply at meinersbur.de
> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Wednesday, April 17, 2013 1:01:42 PM
> Subject: Re: [Llvm-bgq-discuss] Patches for r176829-20130309 (the current vesta version)
> > From: "Michael Kruse" <llvm-bgq-discuss at meinersbur.de>
> > To: "Hal Finkel" <hfinkel at anl.gov>
> > Sent: Wednesday, April 17, 2013 12:22:47 PM
> > Hi,
> > originally I intended to send the following as part of a collection
> > with more problems I found and you might be interested in. But
> > because
> > I do not have time at the moment for closer investigation, I just
> > send
> > it now and will send the other problems sometime later. Please
> > excuse
> > the premature style.
> Not a problem; I'd rather get reports early and often.
> > 1. I found two cases where bgclang segfaults on code that works
> > fine
> > with xlc (see added files).
> > The first is some inline asm, but I don't know whether inline asm
> > is
> > supposed to work in clang.
> > The second uses IBM-style builtins.
> > 2. bgclang is quite unreliable on inline assemble. With this:
> > asm (
> > "dcbt 0,%[ptr] \n"
> > "dcbt %[c64],%[ptr] \n"
> > "dcbt %[c128],%[ptr] \n"
> > "dcbt %[c192],%[ptr] \n"
> > "dcbt %[c256],%[ptr] \n"
> > "dcbt %[c320],%[ptr] \n"
> > [ptr] "+r" (ptr),
> > [c64] "b" (64),
> > [c128] "b" (128),
> > [c192] "b" (192),
> > [c256] "b" (256),
> > [c320] "b" (320)
> > I sometimes get
> > error: invalid input constraint '+r' in asm
> > other times
> > fatal error: error in backend: Do not know how to split the result
> > of
> > this operator!
> > (though I am not sure it's this piece of code, clang doesn't give
> > me
> > a location)
Also, in the mean time, you can use the __dcbt intrinsic. It works just like in xlc (so special header currently required).
-Hal
> I'm not sure; but if this is still a problem upstream, I'll get it
> fixed.
> > 3. There is some issue with the inline functions. The IBM header
> > files
> > seem to assume -fgnu89-inline (with -std=c99), otherwise I get
> > multiple definitions errors from the linker. I don't really
> > understand, because the IBM-supported gcc compiler shouldn't have
> > this
> > problem either.
> > 4. The unimplemented-errors using _Complex data type and compound
> > expressions ("+=") are inherited from clang?
> I think this has just-recently been improved upstream. I should be
> rebasing soon, so I'll let you know.
> Thanks again,
> Hal
> > Michael
> > 2013/3/30 Hal Finkel <hfinkel at anl.gov>:
> > > Hello everyone,
> > > I've attached the patches for the currently-installed version on
> > > vesta (r176829-20130309). These apply to upstream revision
> > > r176829. This is the first released version to contain QPX
> > > autovectorization for single-precision values (in addition to
> > > many
> > > other improvements). I've also included the bgclang wrapper
> > > script
> > > and the libc++ build script (and the llvm build script and the
> > > exception_ptr.h wrapper header).
> > > Another user-visible change to mention: You no longer need to
> > > explicitly include the qpxintrin.h header to use the IBM-style
> > > QPX
> > > intrinsics. This header is now automatically included for you.
> > > For any of you doing first-time on-your-own installs (or anyone
> > > else), please feel free to ask questions about how all of this
> > > needs to be setup in practice.
> > > Sincerely,
> > > Hal
> > > Hal Finkel
> > > Postdoctoral Appointee
> > > Leadership Computing Facility
> > > Argonne National Laboratory
> > > _______________________________________________
> > > llvm-bgq-discuss mailing list
> > > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
More information about the llvm-bgq-discuss
