[Llvm-bgq-discuss] LLVM explodes on GSL-1.9
Hal Finkel
hfinkel at anl.gov
Wed Aug 14 19:01:02 CDT 2013
FYI: this is next on my list (it is a bug in the automatic prefetch transformation)... I'll fix this soon. Why are you using gsl-1.9? They're on 1.16 now ;)
-Hal
----- Original Message -----
> It compiles fine with GCC and XLC...
> Jeff
> make[2]: Entering directory
> `/gpfs/vesta-home/jhammond/GSL/build-llvm/ieee-utils'
> /bin/sh ../libtool --tag=CC --mode=compile bgclang -DHAVE_CONFIG_H
> -I. -I../../gsl-1.9/ieee-utils -I.. -I.. -g -O2 -c -o read.lo
> ../../gsl-1.9/ieee-utils/read.c
> bgclang -DHAVE_CONFIG_H -I. -I../../gsl-1.9/ieee-utils -I.. -I.. -g
> -O2 -c ../../gsl-1.9/ieee-utils/read.c -o read.o
> PHI node has multiple entries for the same basic block with different
> incoming values!
> %indvar = phi i64 [ 0, %if.then5 ], [ %indvar.next, %do.body6 ], [
> %indvar.next99, %do.body6 ]
> label %do.body6
> %indvar.next = add i64 %indvar, 1, !dbg !240
> %indvar.next99 = add i64 %indvar, 1, !dbg !240
> Broken module found, compilation aborted!
> 0 clang 0x000000001237e81c llvm::sys::PrintStackTrace(_IO_FILE*)
> + 4280248588
> 1 clang 0x000000001237ea80
> 2 clang 0x000000001237f924
> 3 0x00000fff7d660418 __kernel_sigtramp_rt64 + 0
> 4 libc.so.6 0x0000008050136ed8 abort + 4293479816
> 5 clang 0x000000001232e018
> 6 clang 0x0000000012300448
> llvm::FPPassManager::runOnFunction(llvm::Function&) + 4279751752
> 7 clang 0x000000001230058c
> llvm::FPPassManager::runOnModule(llvm::Module&) + 4279752060
> 8 clang 0x00000000122ffd4c
> llvm::MPPassManager::runOnModule(llvm::Module&) + 4279750012
> 9 clang 0x0000000012300074
> llvm::PassManagerImpl::run(llvm::Module&) + 4279750804
> 10 clang 0x0000000012300184 llvm::PassManager::run(llvm::Module&)
> + 4279751060
> 11 clang 0x00000000104b26a4
> clang::EmitBackendOutput(clang::DiagnosticsEngine&,
> clang::CodeGenOptions const&, clang::TargetOptions const&,
> clang::LangOptions const&, llvm::Module*, clang::BackendAction,
> llvm::raw_ostream*) + 4248759948
> 12 clang 0x00000000104af434
> 13 clang 0x0000000010678790 clang::ParseAST(clang::Sema&, bool,
> bool) + 4250576552
> 14 clang 0x00000000102fa920
> clang::ASTFrontendAction::ExecuteAction() + 4247006472
> 15 clang 0x00000000104ada90 clang::CodeGenAction::ExecuteAction()
> + 4248740920
> 16 clang 0x00000000102fad74 clang::FrontendAction::Execute() +
> 4247007516
> 17 clang 0x00000000102d49b4
> clang::CompilerInstance::ExecuteAction(clang::FrontendAction&) +
> 4246852652
> 18 clang 0x00000000102b62a0
> clang::ExecuteCompilerInvocation(clang::CompilerInstance*) +
> 4246733880
> 19 clang 0x00000000102ab6f8 cc1_main(char const**, char const**,
> char const*, void*) + 4246690400
> 20 clang 0x00000000102b3a00 main + 4246723512
> 21 libc.so.6 0x000000805011bcd8
> 22 libc.so.6 0x000000805011bed0 __libc_start_main + 4293374464
> Stack dump:
> 0. Program arguments:
> /gpfs/vesta-home/projects/llvm/r186563-20130718/bin/clang -cc1
> -triple powerpc64-bgq-linux -S -disable-free -main-file-name read.c
> -static-define -mrelocation-model static -mdisable-fp-elim
> -fmath-errno -ffp-contract=fast -mconstructor-aliases -target-cpu
> a2q -target-linker-version 2.20.51.0.2 -g -coverage-file
> /tmp/read-0568f0.s -resource-dir
> /gpfs/vesta-home/projects/llvm/r186563-20130718/bin/../lib/clang/3.4
> -D HAVE_CONFIG_H -I . -I ../../gsl-1.9/ieee-utils -I .. -I ..
> -internal-isystem /usr/local/include -internal-isystem
> /gpfs/vesta-home/projects/llvm/r186563-20130718/bin/../lib/clang/3.4/include
> -internal-externc-isystem /include -internal-externc-isystem
> /usr/include -O2 -fno-dwarf-directory-asm -fdebug-compilation-dir
> /home/jhammond/GSL/build-llvm/ieee-utils -ferror-limit 19
> -fmessage-length 185 -mstackrealign -fno-signed-char
> -fobjc-runtime=gcc -fobjc-default-synthesize-properties
> -fdiagnostics-show-option -fcolor-diagnostics -vectorize-loops
> -isystem
> /bgsys/drivers/V1R2M0/ppc64/gnu-linux/powerpc64-bgq-linux/sys-include
> -mllvm -enable-misched -mllvm -enable-aa-sched-mi -mllvm
> -optimize-regalloc -o /tmp/read-0568f0.s -x c
> 1. <eof> parser at end of file
> 2. Code generation
> 3. Running pass 'Function Pass Manager' on module
> '../../gsl-1.9/ieee-utils/read.c'.
> 4. Running pass 'Module Verifier' on function
> '@gsl_ieee_read_mode_string'
> clang: error: unable to execute command: Aborted (core dumped)
> clang: error: clang frontend command failed due to signal (use -v to
> see invocation)
> clang version 3.4 (login1.mcs.anl.gov:src/llvm-trunk/tools/clang
> 43fcaf395fe2ab260ebd838ef19c58bbb69b5889)
> 569be27fc56ad8f617673d0517d0991366dafff5)
> Target: powerpc64-bgq-linux
> Thread model: posix
> clang: note: diagnostic msg: PLEASE submit a bug report to
> http://llvm.org/bugs/ and include the crash backtrace, preprocessed
> source, and associated run script.
> PLEASE ATTACH THE FOLLOWING FILES TO THE BUG REPORT:
> Preprocessed source(s) and associated run script(s) are located at:
> clang: note: diagnostic msg: /tmp/read-9be9ad.c
> clang: note: diagnostic msg: /tmp/read-9be9ad.sh
> make[2]: *** [read.lo] Error 1
> make[2]: Leaving directory
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/gpfs/vesta-home/jhammond/GSL/build-llvm'
> make: *** [all] Error 2
> Jeff Hammond
> Argonne Leadership Computing Facility
> University of Chicago Computation Institute
> jhammond at alcf.anl.gov / (630) 252-5381
> http://www.linkedin.com/in/jeffhammond
> https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
> ALCF docs: http://www.alcf.anl.gov/user-guides
> llvm-bgq-discuss mailing list
> llvm-bgq-discuss at lists.alcf.anl.gov
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
Hal Finkel
Assistant Computational Scientist
Argonne National Laboratory
More information about the llvm-bgq-discuss
