[Llvm-bgq-discuss] Does anyone use math-function errno?
Hal Finkel
hfinkel at anl.gov
Thu Aug 29 11:09:33 CDT 2013
I'm looking for user feedback here:
Currently, Clang on Linux (and, thus, on the BG/Q) uses -fmath-errno as the default setting. This means that it recognizes that math functions (like sqrt for example) might set the global (per-thread) errno variable in error situations. This limits a number of optimizations that can be performed (including preventing these libm math functions from being autovectorized). This is turned off in fast-math mode (with -ffast-math), but some systems (such as Mac OS X) also have it turned off in general (meaning that -fno-math-errno is the system wide default).
I'll note that bgxlc uses its equivalent of fast-math mode by default at -O3 and higher, and I'm sure that I'd like to go that far. But, in my experience, I've not seen a science code that actually checked errno after calling a libm math function. As a result, I'm considering making the BG/Q Clang default, like on Mac OS X, be -fno-math-errno. In this way, by default, we'll get stronger optimizations around calls to libm functions (including autovectorization). If anyone has an opinion here, please share.
Thanks again,
Hal
Hal Finkel
Assistant Computational Scientist
Leadership Computing Facility
Argonne National Laboratory
More information about the llvm-bgq-discuss
