[Llvm-bgq-discuss] pulling in mpi using clang
Geoffrey Irving
irving at naml.us
Fri Feb 1 00:16:34 CST 2013
What's the proper way to get mpi when using
/home/projects/llvm/current/bin/bgclang++? Previously, I stole the
flags from the gcc mpi wrapper (I unfortunately do not remember how I
did this), and then manually specifiied
-I/bgsys/drivers/V1R1M2/ppc64/comm/sys/include
-I/bgsys/drivers/V1R1M2/ppc64/spi/include
-I/bgsys/drivers/V1R1M2/ppc64/spi/include/kernel/cnk
-I/bgsys/drivers/V1R1M2/ppc64/comm/gcc/include
-Wl,-rpath=/bgsys/drivers/V1R1M2/ppc64/comm/gcc/lib
-Wl,-rpath=/bgsys/drivers/V1R1M2/ppc64/comm/sys/lib
-Wl,-rpath=/bgsys/drivers/V1R1M2/ppc64/spi/lib
-L/bgsys/drivers/V1R1M2/ppc64/comm/gcc/lib
-L/bgsys/drivers/V1R1M2/ppc64/comm/sys/lib
-L/bgsys/drivers/V1R1M2/ppc64/spi/lib -lmpich -lopa -lmpl -lrt -ldl
-lpami -lSPI -lSPI_cnk -lpthread
This seems fairly sketchy, so I'd like to do it the right way if such
exists, especially if the driver versions are going to change soon.
Are there wrapper compilers set up?
If I do the above manual way, and qsub a job, it errors out during launch with
2013-01-31 17:21:50.888 (INFO ) [0xfff7f4ba210]
14558:ibm.runjob.AbstractOptions: using properties file
/bgsys/local/etc/bg.properties
2013-01-31 17:21:50.889 (INFO ) [0xfff7f4ba210]
14558:ibm.runjob.AbstractOptions: max open file descriptors: 65536
14558:ibm.runjob.AbstractOptions: core file limit: 0
14558:tatu.runjob.client: scheduler job id is 54725
2013-01-31 17:21:50.891 (INFO ) [0xfffadf71a70]
14558:tatu.runjob.monitor: monitor started
2013-01-31 17:21:50.892 (INFO ) [0xfff7f4ba210]
VST-20400-31511-32:14558:ibm.runjob.client.options.Parser: set local
socket to runjob_mux from properties file
2013-01-31 17:21:51.319 (FATAL) [0xfff7f4ba210]
VST-20400-31511-32:14558:ibm.runjob.client.Job: could not start job:
job failed to start
VST-20400-31511-32:14558:ibm.runjob.client.Job: Load failed on
Q02-I4-J04: Application executable ELF header contains invalid value,
errno 8 Exec format error
2013-01-31 17:21:51.320 (INFO ) [0xfff7f4ba210] tatu.runjob.client:
task exited with status 1
2013-01-31 17:21:54.634 (INFO ) [0xfffadf71a70]
14558:tatu.runjob.monitor: tracklib completed
14558:tatu.runjob.monitor: monitor terminating
2013-01-31 17:21:54.635 (INFO ) [0xfff7f4ba210] tatu.runjob.client:
monitor completed
It's possible this is unrelated, of course.
Geoffrey
More information about the llvm-bgq-discuss
