[Llvm-bgq-discuss] pulling in mpi using clang
Jeff Hammond
jhammond at alcf.anl.gov
Fri Feb 1 00:24:59 CST 2013
*.legacy should work fine for everything except MPI_THREAD_MULTIPLE.
This is a subtle difference from your statement, which indicates
support only for MPI_THREAD_{SINGLE,FUNNELED}.
Jeff
On Fri, Feb 1, 2013 at 3:21 PM, Hal Finkel <hfinkel at anl.gov> wrote:
> Geoffrey,
> Use the wrapper scripts in:
> /home/projects/llvm/mpi/clang/bin/
> or
> /home/projects/llvm/mpi/clang.legacy/bin/
> depending on which version of MPI you'd like (legacy has a global MPI lock, and so it is for apps that only call MPI from one thread)
> -Hal
>> From: "Geoffrey Irving" <irving at naml.us>
>> To: llvm-bgq-discuss at lists.alcf.anl.gov
>> Sent: Friday, February 1, 2013 12:16:34 AM
>> Subject: [Llvm-bgq-discuss] pulling in mpi using clang
>> What's the proper way to get mpi when using
>> /home/projects/llvm/current/bin/bgclang++? Previously, I stole the
>> flags from the gcc mpi wrapper (I unfortunately do not remember how I
>> did this), and then manually specifiied
>> -I/bgsys/drivers/V1R1M2/ppc64/comm/sys/include
>> -I/bgsys/drivers/V1R1M2/ppc64/spi/include
>> -I/bgsys/drivers/V1R1M2/ppc64/spi/include/kernel/cnk
>> -I/bgsys/drivers/V1R1M2/ppc64/comm/gcc/include
>> -Wl,-rpath=/bgsys/drivers/V1R1M2/ppc64/comm/gcc/lib
>> -Wl,-rpath=/bgsys/drivers/V1R1M2/ppc64/comm/sys/lib
>> -Wl,-rpath=/bgsys/drivers/V1R1M2/ppc64/spi/lib
>> -L/bgsys/drivers/V1R1M2/ppc64/comm/gcc/lib
>> -L/bgsys/drivers/V1R1M2/ppc64/comm/sys/lib
>> -L/bgsys/drivers/V1R1M2/ppc64/spi/lib -lmpich -lopa -lmpl -lrt -ldl
>> -lpami -lSPI -lSPI_cnk -lpthread
>> This seems fairly sketchy, so I'd like to do it the right way if such
>> exists, especially if the driver versions are going to change soon.
>> Are there wrapper compilers set up?
>> If I do the above manual way, and qsub a job, it errors out during
>> launch with
>> 2013-01-31 17:21:50.888 (INFO ) [0xfff7f4ba210]
>> 14558:ibm.runjob.AbstractOptions: using properties file
>> /bgsys/local/etc/bg.properties
>> 2013-01-31 17:21:50.889 (INFO ) [0xfff7f4ba210]
>> 14558:ibm.runjob.AbstractOptions: max open file descriptors: 65536
>> 14558:ibm.runjob.AbstractOptions: core file limit: 0
>> 14558:tatu.runjob.client: scheduler job id is 54725
>> 2013-01-31 17:21:50.891 (INFO ) [0xfffadf71a70]
>> 14558:tatu.runjob.monitor: monitor started
>> 2013-01-31 17:21:50.892 (INFO ) [0xfff7f4ba210]
>> VST-20400-31511-32:14558:ibm.runjob.client.options.Parser: set local
>> socket to runjob_mux from properties file
>> 2013-01-31 17:21:51.319 (FATAL) [0xfff7f4ba210]
>> VST-20400-31511-32:14558:ibm.runjob.client.Job: could not start job:
>> job failed to start
>> VST-20400-31511-32:14558:ibm.runjob.client.Job: Load failed on
>> Q02-I4-J04: Application executable ELF header contains invalid value,
>> errno 8 Exec format error
>> 2013-01-31 17:21:51.320 (INFO ) [0xfff7f4ba210] tatu.runjob.client:
>> task exited with status 1
>> 2013-01-31 17:21:54.634 (INFO ) [0xfffadf71a70]
>> 14558:tatu.runjob.monitor: tracklib completed
>> 14558:tatu.runjob.monitor: monitor terminating
>> 2013-01-31 17:21:54.635 (INFO ) [0xfff7f4ba210] tatu.runjob.client:
>> monitor completed
>> It's possible this is unrelated, of course.
>> Thanks,
>> Geoffrey
>> llvm-bgq-discuss mailing list
>> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
Jeff Hammond
Argonne Leadership Computing Facility
University of Chicago Computation Institute
jhammond at alcf.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
More information about the llvm-bgq-discuss
