[Llvm-bgq-discuss] thread local crash
Geoffrey Irving
irving at naml.us
Sat Feb 2 21:58:56 CST 2013
I'm getting a crash on the login nodes which seems to be related to
thread local variables. First, am I correct that
/home/projects/llvm/current/bin/clang -O2
should work fine on the login nodes? If it shouldn't work on the
login nodes, you can stop reading here.
The following details are fairly incomplete, since I haven't made any
attempt to isolate or minimize the problem yet. I can work through
that if what I'm doing (__thread on the login nodes) is indeed
supposed to work.
On the compute nodes, using mpiclang -O3, everything seems to be working fine.
This is not critical, since (1) it only breaks the fast post-compute
verification, which can be run elsewhere or in debug mode and (2) I
can presumably work around it with manual pthread calls.
Geoffrey
The function in question looks like
// Thread local temporary buffer for local compression and decompression.
static inline RawArray<Vector<super_t,2>> local_buffer() {
const int count =
ceil_div(raw_max_fast_compressed_size,sizeof(Vector<super_t,2>));
static __thread Vector<super_t,2>* buffer = 0;
if (!buffer) {
buffer = (Vector<super_t,2>*)malloc(sizeof(Vector<super_t,2>)*count);
if (!buffer)
die("local_fast_compress/uncompress: failed to allocate thread
local buffer of size %zu",sizeof(Vector<super_t,2>)*count);
return RawArray<Vector<super_t,2>>(count,buffer);
It works fine in unoptimized debug mode (-g, no -O), though I do get a
warning during link:
scons: building associated VariantDir targets: build/powerpc/debug
/home/projects/llvm/current/bin/clang -o
build/powerpc/debug/old/endgame.os -c -U__GXX_EXPERIMENTAL_CXX0X__
-mcmodel=small -g -Wall -Winit-self -Woverloaded-virtual
-Wsign-compare -fno-strict-aliasing -std=c++11 -Werror
-Wno-array-bounds -Wno-unknown-pragmas -Wno-invalid-offsetof -fPIC
-DOTHER_PYTHON -DOTHER_THREAD_SAFE=1 -DBOOST_EXCEPTION_DISABLE
-DBUILDING_pentago_core -I/usr/include/python2.6
-I/home/irving/.local/lib/python2.6/site-packages/numpy/core/include
-Ibuild/include -Ibuild/powerpc/debug -I.
-I/home/irving/download/boost_1_52_0 old/endgame.cpp
build/powerpc/debug/libpentago_core.so -shared -g -shared
-Wl,-rpath=/home/irving/lib
-Wl,-rpath=/gpfs/vesta_home/irving/otherlab/other/install/debug/lib
build/powerpc/debug/bin/analyze.os
build/powerpc/debug/data/block_cache.os
build/powerpc/debug/data/compress.os
build/powerpc/debug/data/filter.os
build/powerpc/debug/data/supertensor.os build/powerpc/debug/module.os
build/powerpc/debug/search/engine.os
build/powerpc/debug/search/stat.os
build/powerpc/debug/search/superengine.os
build/powerpc/debug/search/supertable.os
build/powerpc/debug/search/table.os
build/powerpc/debug/search/trace.os
build/powerpc/debug/end/block_store.os
build/powerpc/debug/end/check.os build/powerpc/debug/end/compute.os
build/powerpc/debug/end/fast_compress.os
build/powerpc/debug/end/history.os build/powerpc/debug/end/line.os
build/powerpc/debug/end/load_balance.os
build/powerpc/debug/end/partition.os
build/powerpc/debug/end/predict.os
build/powerpc/debug/end/random_partition.os
build/powerpc/debug/end/sections.os
build/powerpc/debug/end/simple_partition.os
build/powerpc/debug/end/sparse_store.os
build/powerpc/debug/end/store_block_cache.os
build/powerpc/debug/base/all_boards.os
build/powerpc/debug/base/board.os build/powerpc/debug/base/count.os
build/powerpc/debug/base/hash.os build/powerpc/debug/base/moves.os
build/powerpc/debug/base/score.os build/powerpc/debug/base/section.os
build/powerpc/debug/base/superscore.os
build/powerpc/debug/base/symmetry.os
build/powerpc/debug/utility/aligned.os
build/powerpc/debug/utility/debug.os
build/powerpc/debug/utility/large.os
build/powerpc/debug/utility/memory.os
build/powerpc/debug/utility/mmap.os
build/powerpc/debug/utility/convert.os
build/powerpc/debug/utility/thread.os
build/powerpc/debug/old/endgame.os build/powerpc/debug/gen/tables.os
-L/usr/lib64 -L/home/irving/lib
-L/gpfs/vesta_home/irving/otherlab/other/install/debug/lib -llzma
-lpython2.6 -lz -lsnappy -lother_core
/usr/bin/ld: build/powerpc/debug/end/fast_compress.os(.debug_info+0x2510):
R_PPC64_ADDR64 used with TLS symbol
_ZZN7pentago3endL12local_bufferEvE6buffer
In release mode (-O2, no -g), I get no linker warning, but it seems to
be crashed in that function:
build/powerpc/release/old/endgame.os -c -U__GXX_EXPERIMENTAL_CXX0X__
-mcmodel=small -O2 -Wall -Winit-self -Woverloaded-virtual
-DOTHER_PYTHON -DNDEBUG -DOTHER_THREAD_SAFE=1
-DBOOST_EXCEPTION_DISABLE -DBUILDING_pentago_core
-Ibuild/include -Ibuild/powerpc/release -I.
build/powerpc/release/libpentago_core.so -shared -shared
-Wl,-rpath=/gpfs/vesta_home/irving/otherlab/other/install/release/lib
build/powerpc/release/bin/analyze.os
build/powerpc/release/data/block_cache.os
build/powerpc/release/data/compress.os
build/powerpc/release/data/filter.os
build/powerpc/release/data/supertensor.os
build/powerpc/release/module.os build/powerpc/release/search/engine.os
build/powerpc/release/search/stat.os
build/powerpc/release/search/superengine.os
build/powerpc/release/search/supertable.os
build/powerpc/release/search/table.os
build/powerpc/release/search/trace.os
build/powerpc/release/end/block_store.os
build/powerpc/release/end/check.os
build/powerpc/release/end/compute.os
build/powerpc/release/end/fast_compress.os
build/powerpc/release/end/history.os build/powerpc/release/end/line.os
build/powerpc/release/end/load_balance.os
build/powerpc/release/end/partition.os
build/powerpc/release/end/predict.os
build/powerpc/release/end/random_partition.os
build/powerpc/release/end/sections.os
build/powerpc/release/end/simple_partition.os
build/powerpc/release/end/sparse_store.os
build/powerpc/release/end/store_block_cache.os
build/powerpc/release/base/all_boards.os
build/powerpc/release/base/board.os
build/powerpc/release/base/count.os build/powerpc/release/base/hash.os
build/powerpc/release/base/moves.os
build/powerpc/release/base/score.os
build/powerpc/release/base/section.os
build/powerpc/release/base/superscore.os
build/powerpc/release/base/symmetry.os
build/powerpc/release/utility/aligned.os
build/powerpc/release/utility/debug.os
build/powerpc/release/utility/large.os
build/powerpc/release/utility/memory.os
build/powerpc/release/utility/mmap.os
build/powerpc/release/utility/convert.os
build/powerpc/release/utility/thread.os
build/powerpc/release/gen/tables.os -L/usr/lib64 -L/home/irving/lib
-L/gpfs/vesta_home/irving/otherlab/other/install/release/lib -llzma
I'm not completely sure this is the location, since gdb bails out with
Program received signal SIGSEGV, Segmentation fault.
0x00000fffb0e782f4 in
._ZN7pentago3end21local_fast_uncompressEN5other8RawArrayIKhLi1EEEm ()
from /home/irving/otherlab/other/install/flavor/lib/pentago_core.so
During symbol reading, incomplete CFI data; unspecified registers
(e.g., r2) at 0xfffb0e78264.
[Thread 0xffeed7ff200 (LWP 9468) exited]
[Thread 0xfffb074f200 (LWP 9419) exited]
Program terminated with signal SIGSEGV, Segmentation fault.
The program no longer exists.
Missing separate debuginfos, use: debuginfo-install python-2.6.6-29.el6.ppc64
More information about the llvm-bgq-discuss
