[Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
Geoffrey Irving
irving at naml.us
Tue Feb 5 11:58:56 CST 2013
On Tue, Feb 5, 2013 at 9:49 AM, Hal Finkel <hfinkel at anl.gov> wrote:
> ----- Geoffrey Irving <irving at naml.us> wrote:
>> >> On Mon, Feb 4, 2013 at 11:54 AM, Geoffrey Irving <irving at naml.us> wrote:
>> >> > On Sun, Feb 3, 2013 at 9:07 AM, Hal Finkel <hfinkel at anl.gov> wrote:
>> >> >> ----- Original Message -----
>> >> >>> From: "Hal Finkel" <hfinkel at anl.gov>
>> >> >>> To: "Geoffrey Irving" <irving at naml.us>
>> >> >>> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
>> >> >>> Sent: Saturday, February 2, 2013 8:45:31 PM
>> >> >>> Subject: Re: [Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
>> >> >>> > From: "Geoffrey Irving" <irving at naml.us>
>> >> >>> > To: "Hal Finkel" <hfinkel at anl.gov>
>> >> >>> > Sent: Saturday, February 2, 2013 4:09:56 PM
>> >> >>> > Alas, using the new clang I get a new compiler error. Output and
>> >> >>> > preprocessed source here:
>> >> >>> Well, that's not good. I have some idea of where the problem lies,
>> >> >>> and I'll fix it (or translate it into something that can be an
>> >> >>> upstream bug report). Thanks for testing!
>> >> >> As it turned out, this was not an upstream bug (meaning it was completely my fault). I think that particular bug is now fixed. Can you please try the build in /home/projects/llvm/r174287-20130202 to confirm.
>> >> > Cool. I'll give it a try once vesta comes back from maintenance.
>> >> > Geoffrey
>> >> Confirmed: /home/projects/llvm/r174287-20130202/bin/clang++ works fine
>> >> for me now, at least on the login nodes. Thanks!
>> > Great. You might also try r174287-20130203 which has fixes for some of the aforementioned performance regressions I've been investigating.
>> That also works. I've confirmed that it doesn't fix the __thread
>> issue though; I'll isolate that for you tonight.
> Great, thanks! The __thread issue is just when compiling for the host? Or also when compiling for the compute nodes?
It seems to work fine on the compute nodes.
Geoffrey
More information about the llvm-bgq-discuss
