[Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
Geoffrey Irving
irving at naml.us
Fri Jan 18 21:10:59 CST 2013
I'm trying to get my C++11 app running on vesta. Compiling with clang
gives me the following linker errors (summarized below, with full
build output attached):
/home/projects/llvm/current/bin/bgclang++ -o
build/powerpc/release/core/array/RawArray.os -c
-U__GXX_EXPERIMENTAL_CXX0X__ -O3 -funroll-loops -Wall -Winit-self
-Woverloaded-virtual -Wsign-compare -fno-strict-aliasing -std=c++0x
-Werror -Wno-array-bounds -Wno-unknown-pragmas -fPIC -DOTHER_PYTHON
-DNDEBUG -DOTHER_THREAD_SAFE=1 -DBOOST_EXCEPTION_DISABLE
-DBUILDING_other_core -I/usr/include/python2.6
-I/home/irving/.local/lib/python2.6/site-packages/numpy/core/include
-I/usr/local/include -Ibuild/include
-I/home/irving/download/boost_1_52_0 core/array/RawArray.cpp
...MANY OTHER COMPILE COMMANDS...
build/powerpc/release/core/libother_core.so -shared
-Wl,-rpath=/gpfs/vesta_home/irving/otherlab/other/install/release/lib
...MANY_OTHER_OBJECT_FILES... -L/usr/lib64 -L/usr/local/lib
-Linstall/release/lib -lpython2.6
/bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/bin/ld:
build/powerpc/release/core/array/RawArray.os(.text+0x63e):
unresolvable R_PPC64_TOC16_HA relocation against symbol
`_ZTVSt9bad_alloc@@GLIBCXX_3.4'
build/powerpc/release/core/array/RawArray.os(.text+0x642):
unresolvable R_PPC64_TOC16_LO relocation against symbol
build/powerpc/release/core/array/RawArray.os(.text+0x652):
`_ZTISt9bad_alloc@@GLIBCXX_3.4'
build/powerpc/release/core/array/RawArray.os(.text+0x656):
final link failed: Nonrepresentable section on output
clang: error: linker command failed with exit code 1 (use -v to see invocation)
scons: *** [build/powerpc/release/core/libother_core.so] Error 1
Any ideas what might be going wrong? A google search turned up many
similar bugs in the past, but I haven't found a specific reference.
Notes:
1. The only library I'm linking to is Python.
2. I needed to undef __GXX_EXPERIMENTAL_CXX0X__ in order to get
-std=c++0x to compile. Otherwise it complains about stuff like this
(more details on request):
/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/include/c++/4.4.6/bits/stl_pair.h:106:10:
error: no matching function for call to 'move'
: first(std::move(__p.first)),
Geoffrey
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20130118/c7bf491f/attachment-0001.txt>
More information about the llvm-bgq-discuss
