[Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
Geoffrey Irving
irving at naml.us
Fri Jan 18 21:35:18 CST 2013
Cool, that gets me through linking and unit tests in debug mode and
optimized with -O2. However, I get an illegal instruction in some
static initialization code if I use -O3. I'll see how easy it is to
reduce my test case.
In any case, progress!
Geoffrey
On Fri, Jan 18, 2013 at 7:18 PM, Hal Finkel <hfinkel at anl.gov> wrote:
> Geoffrey,
> I believe this bug has been fixed in trunk; I'll updated our install next week. In the mean time, try building with -mcmodel=small
> -Hal
>> From: "Geoffrey Irving" <irving at naml.us>
>> To: llvm-bgq-discuss at lists.alcf.anl.gov
>> Sent: Friday, January 18, 2013 9:10:59 PM
>> Subject: [Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
>> I'm trying to get my C++11 app running on vesta. Compiling with
>> clang
>> gives me the following linker errors (summarized below, with full
>> build output attached):
>> /home/projects/llvm/current/bin/bgclang++ -o
>> build/powerpc/release/core/array/RawArray.os -c
>> -U__GXX_EXPERIMENTAL_CXX0X__ -O3 -funroll-loops -Wall -Winit-self
>> -Woverloaded-virtual -Wsign-compare -fno-strict-aliasing -std=c++0x
>> -Werror -Wno-array-bounds -Wno-unknown-pragmas -fPIC -DOTHER_PYTHON
>> -DNDEBUG -DOTHER_THREAD_SAFE=1 -DBOOST_EXCEPTION_DISABLE
>> -DBUILDING_other_core -I/usr/include/python2.6
>> -I/home/irving/.local/lib/python2.6/site-packages/numpy/core/include
>> -I/usr/local/include -Ibuild/include
>> -I/home/irving/download/boost_1_52_0 core/array/RawArray.cpp
>> ...MANY OTHER COMPILE COMMANDS...
>> build/powerpc/release/core/libother_core.so -shared
>> -Wl,-rpath=/gpfs/vesta_home/irving/otherlab/other/install/release/lib
>> ...MANY_OTHER_OBJECT_FILES... -L/usr/lib64 -L/usr/local/lib
>> -Linstall/release/lib -lpython2.6
>> /bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/bin/ld:
>> build/powerpc/release/core/array/RawArray.os(.text+0x63e):
>> unresolvable R_PPC64_TOC16_HA relocation against symbol
>> `_ZTVSt9bad_alloc@@GLIBCXX_3.4'
>> build/powerpc/release/core/array/RawArray.os(.text+0x642):
>> unresolvable R_PPC64_TOC16_LO relocation against symbol
>> build/powerpc/release/core/array/RawArray.os(.text+0x652):
>> `_ZTISt9bad_alloc@@GLIBCXX_3.4'
>> build/powerpc/release/core/array/RawArray.os(.text+0x656):
>> final link failed: Nonrepresentable section on output
>> clang: error: linker command failed with exit code 1 (use -v to see
>> invocation)
>> scons: *** [build/powerpc/release/core/libother_core.so] Error 1
>> Any ideas what might be going wrong? A google search turned up many
>> similar bugs in the past, but I haven't found a specific reference.
>> Notes:
>> 1. The only library I'm linking to is Python.
>> 2. I needed to undef __GXX_EXPERIMENTAL_CXX0X__ in order to get
>> -std=c++0x to compile. Otherwise it complains about stuff like this
>> (more details on request):
>> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/include/c++/4.4.6/bits/stl_pair.h:106:10:
>> error: no matching function for call to 'move'
>> : first(std::move(__p.first)),
>> Thanks,
>> Geoffrey
>> llvm-bgq-discuss mailing list
>> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> Hal Finkel
> Postdoctoral Appointee
> Leadership Computing Facility
> Argonne National Laboratory
More information about the llvm-bgq-discuss
