[Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
Hal Finkel
hfinkel at anl.gov
Sat Jan 19 17:57:47 CST 2013
Geoffrey,
You're running on the compute nodes, right? Not the login nodes?
-Hal
----- Original Message -----
> From: "Geoffrey Irving" <irving at naml.us>
> To: "Hal Finkel" <hfinkel at anl.gov>
> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Friday, January 18, 2013 9:35:18 PM
> Subject: Re: [Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
> Cool, that gets me through linking and unit tests in debug mode and
> optimized with -O2. However, I get an illegal instruction in some
> static initialization code if I use -O3. I'll see how easy it is to
> reduce my test case.
> In any case, progress!
> Thanks,
> Geoffrey
> On Fri, Jan 18, 2013 at 7:18 PM, Hal Finkel <hfinkel at anl.gov> wrote:
> > Geoffrey,
> > I believe this bug has been fixed in trunk; I'll updated our
> > install next week. In the mean time, try building with
> > -mcmodel=small
> > -Hal
> >> To: llvm-bgq-discuss at lists.alcf.anl.gov
> >> Sent: Friday, January 18, 2013 9:10:59 PM
> >> Subject: [Llvm-bgq-discuss] linker errors with
> >> I'm trying to get my C++11 app running on vesta. Compiling with
> >> clang
> >> gives me the following linker errors (summarized below, with full
> >> build output attached):
> >> /home/projects/llvm/current/bin/bgclang++ -o
> >> build/powerpc/release/core/array/RawArray.os -c
> >> -U__GXX_EXPERIMENTAL_CXX0X__ -O3 -funroll-loops -Wall -Winit-self
> >> -Woverloaded-virtual -Wsign-compare -fno-strict-aliasing
> >> -std=c++0x
> >> -Werror -Wno-array-bounds -Wno-unknown-pragmas -fPIC
> >> -DOTHER_PYTHON
> >> -DNDEBUG -DOTHER_THREAD_SAFE=1 -DBOOST_EXCEPTION_DISABLE
> >> -DBUILDING_other_core -I/usr/include/python2.6
> >> -I/home/irving/.local/lib/python2.6/site-packages/numpy/core/include
> >> -I/usr/local/include -Ibuild/include
> >> -I/home/irving/download/boost_1_52_0 core/array/RawArray.cpp
> >> ...MANY OTHER COMPILE COMMANDS...
> >> build/powerpc/release/core/libother_core.so -shared
> >> -Wl,-rpath=/gpfs/vesta_home/irving/otherlab/other/install/release/lib
> >> ...MANY_OTHER_OBJECT_FILES... -L/usr/lib64 -L/usr/local/lib
> >> -Linstall/release/lib -lpython2.6
> >> /bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/bin/ld:
> >> build/powerpc/release/core/array/RawArray.os(.text+0x63e):
> >> unresolvable R_PPC64_TOC16_HA relocation against symbol
> >> `_ZTVSt9bad_alloc@@GLIBCXX_3.4'
> >> build/powerpc/release/core/array/RawArray.os(.text+0x642):
> >> unresolvable R_PPC64_TOC16_LO relocation against symbol
> >> build/powerpc/release/core/array/RawArray.os(.text+0x652):
> >> `_ZTISt9bad_alloc@@GLIBCXX_3.4'
> >> build/powerpc/release/core/array/RawArray.os(.text+0x656):
> >> final link failed: Nonrepresentable section on output
> >> clang: error: linker command failed with exit code 1 (use -v to
> >> see
> >> invocation)
> >> scons: *** [build/powerpc/release/core/libother_core.so] Error 1
> >> Any ideas what might be going wrong? A google search turned up
> >> many
> >> similar bugs in the past, but I haven't found a specific
> >> reference.
> >> Notes:
> >> 1. The only library I'm linking to is Python.
> >> 2. I needed to undef __GXX_EXPERIMENTAL_CXX0X__ in order to get
> >> -std=c++0x to compile. Otherwise it complains about stuff like
> >> this
> >> (more details on request):
> >> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/include/c++/4.4.6/bits/stl_pair.h:106:10:
> >> error: no matching function for call to 'move'
> >> : first(std::move(__p.first)),
> >> Thanks,
> >> Geoffrey
> >> _______________________________________________
> >> llvm-bgq-discuss mailing list
> >> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> > Hal Finkel
> > Postdoctoral Appointee
> > Leadership Computing Facility
> > Argonne National Laboratory
Hal Finkel
More information about the llvm-bgq-discuss
