[Llvm-bgq-discuss] bgclang r185415-20130701 on vesta/mira
Hal Finkel
hfinkel at anl.gov
Fri Jul 5 13:57:30 CDT 2013
----- Original Message -----
> Hal
> I this version supposed to handle the && operator correctly?
Yes, I fixed the bug responsible for that issue.
> I believe that my original test case now works fine, but I encounter
> a different problem with the && and || operators, even without
> optimization.
Can you point me to the failing code and I'll take a look.
Thanks again,
Hal
> -erik
> On Tue, Jul 2, 2013 at 12:07 PM, Hal Finkel < hfinkel at anl.gov >
> wrote:
> Hello everyone,
> I've upgraded the bgclang install on vesta/mira to build
> r185415-20130701. This build incorporates a number of important bug
> fixes, and while hitting these bugs seems rare, I recommend that all
> codes compiled with previous builds be recompiled.
> For those of you maintaining your own installs, I've posted the
> updated patches and build/wrapper scripts on:
> https://trac.alcf.anl.gov/projects/llvm-bgq
> -Hal
> Hal Finkel
> Assistant Computational Scientist
> Leadership Computing Facility
> Argonne National Laboratory
> llvm-bgq-discuss mailing list
> llvm-bgq-discuss at lists.alcf.anl.gov
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> Erik Schnetter < schnetter at cct.lsu.edu >
> http://www.perimeterinstitute.ca/personal/eschnetter/
Hal Finkel
More information about the llvm-bgq-discuss
