[Llvm-bgq-discuss] bgclang r185769-20130706 on vesta/mira
Hal Finkel
hfinkel at anl.gov
Sun Jul 7 13:41:31 CDT 2013
Erik,
Embarrassingly enough, you're right again! This has now been fixed.
A (-v2) archive is on the https://trac.alcf.anl.gov/projects/llvm-bgq/ page.
Thanks again,
Hal
----- Original Message -----
> Hal
> I believe this new version still exhibits an error with the []
> operator.
> My source code is in /home/eschnett/src/vecmathlib-qpx3. The source
> file is
> called test.cc. I built it with
> /home/projects/llvm/bin/bgclang++
> -I/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/include -o test
> test.cc
> -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -lmass_simd
> The output contains the lines
> n=1
> i=0 bits=1
> i=1 bits=0
> i=2 bits=0
> i=3 bits=0
> x=[1,0,1,0]
> 0x3ff0000000000000bff0000000000000bff0000000000000bff0000000000000
> i=0
> i=1
> i=2
> Error in []:
> x=[0,0,0,0]
> [0x3ff0000000000000bff0000000000000bff0000000000000bff0000000000000]
> fstd(x)=0 [0x00]
> fvml(x)=1 [0x01]
> isbad(x)=1
> i=3
> which indicate that there is an error: for n=1, the value stored in x
> should be [-1.0, +1.0, +1.0 +1.0], corresponding to the bit pattern
> found
> in the lowermost 4 bits of n. The hex output indicates that this is
> the
> case, the bool output [1,0,1,0] indicates that something is wrong
> with the
> [] operator accessing these values.
> The line "Error in []" below "i=2" indicates that bit 2 is found to
> be
> incorrect -- it is expected to be 0 (fstd), but found to be 1 (fvml).
> -erik
> On Sun, Jul 7, 2013 at 12:43 AM, Hal Finkel <hfinkel at anl.gov> wrote:
> > Hello,
> > I've installed a new bgclang build (r185769-20130706) on vesta and
> > mira.
> > This build incorporates some recent upstream enhancements and bug
> > fixes.
> > As usual, a new patch archive is available on:
> > http://trac.alcf.anl.gov/projects/llvm-bgq/
> > -Hal
> > Hal Finkel
> > Assistant Computational Scientist
> > Leadership Computing Facility
> > Argonne National Laboratory
> > _______________________________________________
> > llvm-bgq-discuss mailing list
> > llvm-bgq-discuss at lists.alcf.anl.gov
> > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> Erik Schnetter <schnetter at cct.lsu.edu>
> http://www.perimeterinstitute.ca/personal/eschnetter/
Hal Finkel
More information about the llvm-bgq-discuss
