[Llvm-bgq-discuss] clang code gen error -- Kernel_RanksToCoords
Michael Blocksome
blocksom at us.ibm.com
Fri Jul 26 13:25:28 CDT 2013
Hal,
Tom and I have discovered what appears to be a code gen problem when
compiling the Kernel_RanksToCoords() CNK syscall. See Tom's analysis
below.
GPR4 receives the second parameter, GPR5 receives the third parameter, and
GPR3 is the return value.
BTW, I'm using the latest "bgclang" wrapper script, but I've renamed it to
powerpc64-bgq-linux-clang so it plays nice with autoconf.
Michael Blocksome
Blue Gene Messaging
----- Forwarded by Michael Blocksome/Rochester/IBM on 07/26/2013 01:20 PM
To: Michael Blocksome/Rochester/IBM at IBMUS,
Date: 07/26/2013 11:20 AM
Subject: Re: clang
Looks like the addresses are getting truncated to 32-bits.
after ... Kernel_RanksToCoords (8, 0x1dbfffba18, 0x1dbfffba10 {0}) = 14
{4}.16.1: TB=0000000773c39a5c FL_SYSCALLAT:0 Syscall 1055 at
IP=0x0000000001001314 LR=0x00000000010012bc SP=0x0000001dbfffb9a0
(RANKS2COORDS)
{4}.16.1: TB=0000000773c39acc FL_SYSCALLEN:0 Syscall Entry
GPR3=0x0000000000000008 GPR4=0x00000000bfffba18 GPR5=0x00000000bfffba10
GPR6=0x0000001dbfffba50
{4}.16.1: TB=0000000773c3a1a4 FL_SYSCALLRT:0 Syscall Return GPR3=
0x000000000000000e
10012c0: 38 60 04 1f li r3,1055
10012c4: 38 9f 00 a8 addi r4,r31,168
10012c8: 38 df 00 b0 addi r6,r31,176
10012cc: 38 ff 00 b8 addi r7,r31,184
10012d0: 39 1f 00 c0 addi r8,r31,192
10012d4: e8 bf 00 80 ld r5,128(r31) <---- quite a few
load/stores... seems very wasteful.
10012d8: fb df 00 d0 std r30,208(r31)
10012dc: fb bf 00 c8 std r29,200(r31)
10012e0: e9 3f 00 d0 ld r9,208(r31)
10012e4: e9 5f 00 c8 ld r10,200(r31)
10012e8: f8 bf 00 d8 std r5,216(r31)
10012ec: e8 bf 00 d8 ld r5,216(r31)
10012f0: f9 3f 00 b0 std r9,176(r31)
10012f4: f9 5f 00 a8 std r10,168(r31)
10012f8: f8 bf 00 b8 std r5,184(r31)
10012fc: f8 7f 00 c0 std r3,192(r31)
1001300: 80 a4 00 04 lwz r5,4(r4) <---- these are
32-bit loads, should be 64-bit.
1001304: 80 86 00 04 lwz r4,4(r6)
1001308: 80 67 00 04 lwz r3,4(r7)
100130c: 80 08 00 04 lwz r0,4(r8)
1001310: 44 00 00 02 sc
The inline assembly piece is:
#define CNK_SPI_SYSCALL_3(name, arg0, arg1, arg2) \
register uint64_t r0 __asm__ ("r0") = (__NR_ ## name); \
register uint64_t r3 __asm__ ("r3") = ((uint64_t) (arg0)); \
register uint64_t r4 __asm__ ("r4") = ((uint64_t) (arg1)); \
register uint64_t r5 __asm__ ("r5") = ((uint64_t) (arg2)); \
__asm__ __volatile__ \
("sc" \
: "=&r"(r0),"=&r"(r3),"=&r"(r4),"=&r"(r5) \
: "0"(r0), "1"(r3), "2"(r4), "3"(r5) \
: "r6","r7","r8","r9","r10","r11","r12","cr0","memory"); \
r3; \
I don't see where they would be interpreted as 32-bits. In the
input/outputs section, "r" is a register for gcc assembly, which should be
64-bit for a 64-bit compile. I presume LLVM is following gcc assembly
semantics.
The other comment was that Hal seems to be directing people to his
"bgclang" wrapper script. I'm not sure it will make a difference, but
could be something to try.
Tom
Tom Gooding
Senior Engineer / Blue Gene Kernels
507-253-0747 (internal: 553-0747)
To:
Thomas Gooding/Rochester/IBM at IBMUS,
Date:
07/26/2013 08:56 AM
Subject:
clang
Tom,
I wrote a very simple test and compiled with the latest version of
llvm/clang from Hal.
$ cat kernel_rankstocoords.c
#include <stdlib.h>
#include <stdio.h>
#include <stdint.h>
#include "kernel/location.h"
int main (int argc, char * argv[])
uint32_t rc = 1;
size_t mapsize = 2*sizeof(BG_CoordinateMapping_t);
BG_CoordinateMapping_t map[2];
uint64_t n = 0;
fprintf (stdout, "before .. Kernel_RanksToCoords (%zu, %p, %p {%lu}) =
%d\n", mapsize, map, &n, n, rc);
rc = Kernel_RanksToCoords (mapsize, map, &n);
fprintf (stdout, "after ... Kernel_RanksToCoords (%zu, %p, %p {%lu}) =
return 0;
$ /bghome/blocksom/development/c++11/install/powerpc64-bgq-linux-clang
kernel_rankstocoords.c -o kernel_rankstocoords.clang
-I/bgsys/drivers/ppcfloor/spi/include
-I/bgsys/drivers/ppcfloor/spi/include/kernel/cnk -I/bgsys/drivers/ppcfloor
When I run this I get that same error as when I ran pami compiled with
clang..
$ runjob --block R00-M1-N10 --np 2 : kernel_rankstocoords.clang
before .. Kernel_RanksToCoords (8, 0x1dbfffba18, 0x1dbfffba10 {0}) = 1
.. but it runs fine when compiled with gcc..
$ /bgsys/drivers/ppcfloor/gnu-linux/bin/powerpc64-bgq-linux-gcc
kernel_rankstocoords.c -o kernel_rankstocoords.gcc
$ runjob --block R00-M1-N10 --np 2 : kernel_rankstocoords.gcc
before .. Kernel_RanksToCoords (8, 0x1dbfffba54, 0x1dbfffba60 {0}) = 1
after ... Kernel_RanksToCoords (8, 0x1dbfffba54, 0x1dbfffba60 {2}) = 0
Any ideas? Is it something I'm doing wrong, or should I post this to the
llvm-bgq mailing list?
Michael Blocksome
Blue Gene Messaging
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20130726/9a013d42/attachment.html>
More information about the llvm-bgq-discuss
