[Llvm-bgq-discuss] fatal error: error in backend: Cannot select: 0x10040606cd0: f64 = extract_vector_elt 0x10040604570, 0x100402cc320 [ORD=1322] [ID=22]
Erik Schnetter
schnetter at cct.lsu.edu
Mon Jun 17 10:49:27 CDT 2013
Hal
Thanks!
Out of curiosity: What about the opposite, inserting a vector element?
-erik
On Mon, Jun 17, 2013 at 11:36 AM, Hal Finkel <hfinkel at anl.gov> wrote:
> Erik,
> I've fixed this in my local repository; so this will be fixed in the next
> patchset release.
> The cause of this error was that I did not understand that the 'index'
> argument of LLVM's extract-vector-element operation could be non-constant.
> I've added an implementation for this 'general' case as sldi (left shift by
> 5) -> qvlpclsx
> -> qvfperm. The constant index case is still handled by qvesplati as it
> was before.
> Thanks again,
> Hal
> > Erik,
> > Thanks! I'll get this (and your previous bug) fixed soon.
> > -Hal
> > > I received the following error message from clang on Vesta that I
> > > am
> > > reporting here instead of on bugs.llvm.org:
> > > Clang invocation:
> > > /home/projects/llvm/bin/bgclang++11 -O0
> > > -I/soft/compilers/ibmcmp-feb2013/xlmass/bg/7.3/include -o
> > > CMakeFiles/bench.dir/bench.cc.o -c
> > > /home/eschnett/src/vecmathlib-qpx/bench.cc
> > > Error message:
> > > In file included from /home/eschnett/src/vecmathlib-qpx/bench.cc:5:
> > > /home/eschnett/src/vecmathlib-qpx/vecmathlib.h:76:
> > > /home/eschnett/src/vecmathlib-qpx/vec_double_qpx.h:11:2: warning:
> > > "TODO"
> > > [-W#warnings]
> > > #warning "TODO"
> > > /home/eschnett/src/vecmathlib-qpx/vec_double_qpx.h:441:2: warning:
> > > "TODO"
> > > [-W#warnings]
> > > #warning "TODO"
> > > fatal error: error in backend: Cannot select: 0x100103bdc20: f64 =
> > > extract_vector_elt 0x10010719670, 0x10010734610 [ORD=1322]
> > > [ID=22]
> > > 0x10010719670: v4f64,ch = load 0x10010734810, 0x10010353f60,
> > > 0x10010749c00<LD32[%v]> [ORD=1320] [ID=21]
> > > 0x10010353f60: i64,ch = load 0x10010734810, 0x100103be020,
> > > 0x10010749c00<LD8[%this.addr]> [ORD=1318] [ID=19]
> > > 0x100103be020: i64 = FrameIndex<0> [ORD=1316] [ID=6]
> > > 0x10010749c00: i64 = undef [ORD=1316] [ID=7]
> > > 0x10010734610: i64,ch = load 0x10010734810, 0x100107383f0,
> > > 0x10010749c00<LD4[%n.addr], zext from i32> [ID=18]
> > > 0x100107383f0: i64 = FrameIndex<1> [ORD=1317] [ID=8]
> > > In function: _ZNK10vecmathlib7realvecIdLi4EEixEi
> > > clang: error: clang frontend command failed with exit code 70 (use
> > > -v
> > > to
> > > see invocation)
> > > clang version 3.4 (login1.mcs.anl.gov:src/llvm-trunk/tools/clang
> > > a56f5370124826a853d38050afa60fe85096870b)
> > > 66fd9b1b79e04004afe6eca8a438d6430341aa00)
> > > Target: powerpc64-bgq-linux
> > > Thread model: posix
> > > clang: note: diagnostic msg: PLEASE submit a bug report to
> > > http://llvm.org/bugs/ and include the crash backtrace, preprocessed
> > > source,
> > > and associated run script.
> > > PLEASE ATTACH THE FOLLOWING FILES TO THE BUG REPORT:
> > > Preprocessed source(s) and associated run script(s) are located at:
> > > clang: note: diagnostic msg: /tmp/bench-PYtUac.cpp
> > > clang: note: diagnostic msg: /tmp/bench-PYtUac.sh
> > > -erik
> > > Erik Schnetter <schnetter at cct.lsu.edu>
> > > http://www.perimeterinstitute.ca/personal/eschnetter/
> > > _______________________________________________
> > > llvm-bgq-discuss mailing list
> > > llvm-bgq-discuss at lists.alcf.anl.gov
> > > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20130617/a1628252/attachment.html>
More information about the llvm-bgq-discuss
