[Llvm-bgq-discuss] bgclang r184137-20130617 on vesta/mira
Hal Finkel
hfinkel at anl.gov
Tue Jun 18 23:01:08 CDT 2013
----- Original Message -----
> Hal
> Thanks for the update! The new version compilers my code fine.
> However, I am now encountering a wrong-code-generation issue.
> Essentially, true && false evaluates to true, but of course in
> circumstances that are more complex.
> I have preprocessed source code that is 1.6 MB large
> (/home/eschnett/src/vecmathlib-qpx2/test.i), but most code in there
> is unused or commented out. The resulting file, when compiled with
> bgclang++11 -O3, runs very quickly and produces just a few lines of
> output. In fact, it even runs on the front-end, producing the same
> error.
If it runs on the frontend then I suppose that it is not a QPX-related problem.
> How should I continue to submit a bug report on this?
You can leave the input file where it is; can you send me an e-mail describing what the output is supposed to be vs. what it is and I'll look at it now.
Thanks again,
Hal
> -erik
> On Tue, Jun 18, 2013 at 3:00 PM, Hal Finkel < hfinkel at anl.gov >
> wrote:
> Hello again,
> I've upgraded the installation on vesta/mira to r184137-20130617.
> This incorporates a number of new upstream bug fixes and feature
> improvements, and also some QPX-specific bug fixes (as discussed
> recently on this list). I'll specifically note that this release
> picks up an upstream change which enables some limited loop
> autovectorization (QPX generation) at -O2 (previously, there was no
> autovectorization of any kind until -O3).
> The archive will the patches, build and wrapper scripts has been
> posted: https://trac.alcf.anl.gov/projects/llvm-bgq/wiki
> I'd like to thank everyone again for their patience and feedback!
> -Hal
> Hal Finkel
> Assistant Computational Scientist
> Leadership Computing Facility
> Argonne National Laboratory
> llvm-bgq-discuss mailing list
> llvm-bgq-discuss at lists.alcf.anl.gov
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> Erik Schnetter < schnetter at cct.lsu.edu >
> http://www.perimeterinstitute.ca/personal/eschnetter/
Hal Finkel
More information about the llvm-bgq-discuss
