[Llvm-bgq-discuss] rint() with -ffast-math
Jeff Hammond
jhammond at alcf.anl.gov
Wed Jun 19 10:52:06 CDT 2013
>From http://gcc.gnu.org/onlinedocs/gcc-4.1.1/gcc/Optimize-Options.html:
-ffast-math
Sets -fno-math-errno, -funsafe-math-optimizations, -fno-trapping-math,
-ffinite-math-only, -fno-rounding-math, -fno-signaling-nans and
fcx-limited-range.
This option causes the preprocessor macro __FAST_MATH__ to be defined.
This option should never be turned on by any -O option since it can
result in incorrect output for programs which depend on an exact
implementation of IEEE or ISO rules/specifications for math functions.
Based upon this, I would not count on accurate results when fast-math
is defined unless explicitly verified.
Assuming LLVM behaves like GCC and defines __FAST_MATH__, you could
also do this:
#ifdef __FAST_MATH__
slower_rounding_function_that_is_always_correct(stuff);
#else
rint(stuff);
#endif
Jeff
On Wed, Jun 19, 2013 at 10:48 AM, Erik Schnetter <schnetter at cct.lsu.edu> wrote:
> On Wed, Jun 19, 2013 at 11:12 AM, Hal Finkel <hfinkel at anl.gov> wrote:
>> ----- Original Message -----
>> > The function rint() is supposed to round to the nearest integer,
>> > breaking ties to even. With -ffast-math, it breaks ties away from
>> > zero. That is, in corner cases the result is incorrectly rounded.
>> > Is this intended? This (BGQ with Clang) is the first system that does
>> > so. (I understand why one would do this given the machine
>> > instructions available.)
>> Yes, this is the intended behavior (and LLVM will currently do this on all
>> PPC systems). It is a function of the (odd) way in which the PPC frin
>> instruction is defined. The upside is that it is much faster than the libc
>> function call. That having been said, I put this optimization in, and I can
>> take it out again ;) [or make it require some other flag]. Is the behavior
>> too different for you?
> I can live with this optimization, I just want to know where -ffast-math has
> its boundaries...
> -erik
> http://www.perimeterinstitute.ca/personal/eschnetter/
> llvm-bgq-discuss mailing list
> llvm-bgq-discuss at lists.alcf.anl.gov
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
Jeff Hammond
Argonne Leadership Computing Facility
University of Chicago Computation Institute
jhammond at alcf.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
ALCF docs: http://www.alcf.anl.gov/user-guides
More information about the llvm-bgq-discuss
