[Llvm-bgq-discuss] rint() with -ffast-math
Erik Schnetter
schnetter at cct.lsu.edu
Wed Jun 19 11:20:05 CDT 2013
By the way (and indicating that I recently spent way too much time learning
about IEEE rounding, and thinking about how to implement this efficiently):
double round(double x) { return trunc(x + copysign(0.5, x)); }
is correct and quite efficient if trunc is efficient (ignoring nans, infs,
etc.). If you have an efficient floor instead of trunc, then you can also
use
double round(double x) { return copysign(floor(fabs(x)+0.5), x); }
which probably requires one more instruction because of the fabs.
-erik
On Wed, Jun 19, 2013 at 12:03 PM, Erik Schnetter <schnetter at cct.lsu.edu>wrote:
> Actually, the Intel AVX instructions have a similar issue: rint() has a
> fast instruction, but round() does not. On this architecture, round() still
> does the "right thing", even with -ffast-math, both with gcc and clang.
> Actually, as I just see, gcc generates a short sequence of instructions
> (five or so) to implement round() properly, whereas clang calls _round.
> Given this, the behaviour on BGQ is indeed special. I would expect clang
> to behave consistently -- to either apply this optimization across the
> board, or nowhere. Do you want to raise the issue on the llvm mailing list?
> -erik
> On Wed, Jun 19, 2013 at 11:52 AM, Jeff Hammond <jhammond at alcf.anl.gov>wrote:
>> From http://gcc.gnu.org/onlinedocs/gcc-4.1.1/gcc/Optimize-Options.html:
>> -ffast-math
>> Sets -fno-math-errno, -funsafe-math-optimizations, -fno-trapping-math,
>> -ffinite-math-only, -fno-rounding-math, -fno-signaling-nans and
>> fcx-limited-range.
>> This option causes the preprocessor macro __FAST_MATH__ to be defined.
>> This option should never be turned on by any -O option since it can
>> result in incorrect output for programs which depend on an exact
>> implementation of IEEE or ISO rules/specifications for math functions.
>> Based upon this, I would not count on accurate results when fast-math
>> is defined unless explicitly verified.
>> Assuming LLVM behaves like GCC and defines __FAST_MATH__, you could
>> also do this:
>> #ifdef __FAST_MATH__
>> slower_rounding_function_that_is_always_correct(stuff);
>> #else
>> rint(stuff);
>> #endif
>> Jeff
>> On Wed, Jun 19, 2013 at 10:48 AM, Erik Schnetter <schnetter at cct.lsu.edu>
>> wrote:
>> > On Wed, Jun 19, 2013 at 11:12 AM, Hal Finkel <hfinkel at anl.gov> wrote:
>> >> ----- Original Message -----
>> >> > The function rint() is supposed to round to the nearest integer,
>> >> > breaking ties to even. With -ffast-math, it breaks ties away from
>> >> > zero. That is, in corner cases the result is incorrectly rounded.
>> >> > Is this intended? This (BGQ with Clang) is the first system that does
>> >> > so. (I understand why one would do this given the machine
>> >> > instructions available.)
>> >> Yes, this is the intended behavior (and LLVM will currently do this on
>> all
>> >> PPC systems). It is a function of the (odd) way in which the PPC frin
>> >> instruction is defined. The upside is that it is much faster than the
>> libc
>> >> function call. That having been said, I put this optimization in, and
>> I can
>> >> take it out again ;) [or make it require some other flag]. Is the
>> behavior
>> >> too different for you?
>> > I can live with this optimization, I just want to know where
>> -ffast-math has
>> > its boundaries...
>> > -erik
>> > http://www.perimeterinstitute.ca/personal/eschnetter/
>> > _______________________________________________
>> > llvm-bgq-discuss mailing list
>> > llvm-bgq-discuss at lists.alcf.anl.gov
>> > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
>> Jeff Hammond
>> Argonne Leadership Computing Facility
>> University of Chicago Computation Institute
>> jhammond at alcf.anl.gov / (630) 252-5381
>> http://www.linkedin.com/in/jeffhammond
>> https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
>> ALCF docs: http://www.alcf.anl.gov/user-guides
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20130619/20f0d3fb/attachment.html>
More information about the llvm-bgq-discuss
