[Llvm-bgq-discuss] rint() with -ffast-math
Erik Schnetter
schnetter at cct.lsu.edu
Wed Jun 19 12:06:14 CDT 2013
On Wed, Jun 19, 2013 at 12:48 PM, Hal Finkel <hfinkel at anl.gov> wrote:
> > From
> > http://gcc.gnu.org/onlinedocs/gcc-4.1.1/gcc/Optimize-Options.html:
> > -ffast-math
> > Sets -fno-math-errno, -funsafe-math-optimizations,
> > -fno-trapping-math,
> > -ffinite-math-only, -fno-rounding-math, -fno-signaling-nans and
> > fcx-limited-range.
> > This option causes the preprocessor macro __FAST_MATH__ to be
> > defined.
> > This option should never be turned on by any -O option since it can
> > result in incorrect output for programs which depend on an exact
> > implementation of IEEE or ISO rules/specifications for math
> > functions.
> > Based upon this, I would not count on accurate results when fast-math
> > is defined unless explicitly verified.
> > Assuming LLVM behaves like GCC and defines __FAST_MATH__, you could
> > also do this:
> Yes, Clang also defines __FAST_MATH__ -- however, I think that if a user
> is forced to manually implement rint() then that is not a good outcome.
I am not a user in this sense... I am developing a library that provides a
portable C++ interface to vector types.
That is, this library <https://bitbucket.org/eschnett/vecmathlib/wiki/Home>
provides e.g. a function
double4 rint(double4)
where "double4" is implemented as QPX vector on the BG/Q. The question is
now whether rint can be converted to round or not.
-erik
-Hal
> > #ifdef __FAST_MATH__
> > slower_rounding_function_that_is_always_correct(stuff);
> > #else
> > rint(stuff);
> > #endif
> > Jeff
> > On Wed, Jun 19, 2013 at 10:48 AM, Erik Schnetter
> > <schnetter at cct.lsu.edu> wrote:
> > > On Wed, Jun 19, 2013 at 11:12 AM, Hal Finkel <hfinkel at anl.gov>
> > >> > The function rint() is supposed to round to the nearest integer,
> > >> > breaking ties to even. With -ffast-math, it breaks ties away
> > >> > from
> > >> > zero. That is, in corner cases the result is incorrectly
> > >> > rounded.
> > >> > Is this intended? This (BGQ with Clang) is the first system that
> > >> > does
> > >> > so. (I understand why one would do this given the machine
> > >> > instructions available.)
> > >> Yes, this is the intended behavior (and LLVM will currently do
> > >> this on all
> > >> PPC systems). It is a function of the (odd) way in which the PPC
> > >> frin
> > >> instruction is defined. The upside is that it is much faster than
> > >> the libc
> > >> function call. That having been said, I put this optimization in,
> > >> and I can
> > >> take it out again ;) [or make it require some other flag]. Is the
> > >> behavior
> > >> too different for you?
> > > I can live with this optimization, I just want to know where
> > > -ffast-math has
> > > its boundaries...
> > > -erik
> > > Erik Schnetter <schnetter at cct.lsu.edu>
> > > http://www.perimeterinstitute.ca/personal/eschnetter/
> > > _______________________________________________
> > > llvm-bgq-discuss mailing list
> > > llvm-bgq-discuss at lists.alcf.anl.gov
> > > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> > Jeff Hammond
> > Argonne Leadership Computing Facility
> > University of Chicago Computation Institute
> > jhammond at alcf.anl.gov / (630) 252-5381
> > http://www.linkedin.com/in/jeffhammond
> > https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
> > ALCF docs: http://www.alcf.anl.gov/user-guides
> Hal Finkel
> Assistant Computational Scientist
> Argonne National Laboratory
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20130619/2cf8515c/attachment.html>
More information about the llvm-bgq-discuss
