[Llvm-bgq-discuss] bgclang r192411-20131010 on vesta/mira (with LTO)
Hal Finkel
hfinkel at anl.gov
Fri Oct 11 11:43:50 CDT 2013
Hello,
A quick update: the install last night would not handle LTO when linking dynamically. I've fixed this now.
For those maintaining their own installs, an updated bgclang-binutils RPM (and SRPM) are available on the trac page: https://trac.alcf.anl.gov/projects/llvm-bgq
-Hal
----- Original Message -----
> Hello again,
> I've updated our bgclang install on vesta and mira to
> r192411-20131010.
> The primary motivation behind this release is to let you all play
> with a new feature: link-time optimization (LTO). I consider LTO
> here to be alpha quality, and I already know of at least one bug
> (building HACC with LTO and debugging symbols (-g) will crash the
> link-time optimizer). Nevertheless, the potential performance
> benefit is significant, and so please feel free to try it and
> provide feedback. Here's how:
> 1. Pass the command-line argument -flto to bgclang when both
> compiling and linking (you'll also want -O2 or -O3).
> 2. If you build using static archives (.a files), you need to
> construct them using bundled 'ar' utility. bgclang-ar (and
> equivalently powerpc64-bgq-linux-clang-ar) are provided in the wbin
> directory for this purpose. If you'd like to view the symbols in
> these archives, the system 'nm' utility will not help you. Use
> bgclang-nm (or powerpc64-bgq-linux-clang-nm) from the wbin
> directory instead.
> If you fail to use the bundled 'ar' utility, and instead use the
> system 'ar', when you link you'll likely receive an error
> message like this:
> error adding symbols: Archive has no index; run ranlib to add
> one
> For those maintaining their own installs, RPMs (and SRPMs) are
> Thanks again,
> Hal
> Hal Finkel
> Assistant Computational Scientist
> Leadership Computing Facility
> Argonne National Laboratory
Hal Finkel
More information about the llvm-bgq-discuss
