[Llvm-bgq-discuss] llvm-bgq
Hal Finkel
hfinkel at anl.gov
Wed Apr 2 09:17:39 CDT 2014
----- Original Message -----
> From: "Chris Samuel" <samuel at unimelb.edu.au>
> To: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Wednesday, April 2, 2014 7:57:25 AM
> Subject: [Llvm-bgq-discuss] llvm-bgq
> Hi there,
> First of all great to see this happening! We finally have hope of
> building newer versions of OpenFOAM for our 4 rack system - it needs
> a
> newer version of GCC than is available for BG/Q, but does seem to
> claim
> to support this clang version.
Yes, I have several users because of OpenFOAM.
Regarding the errors, did you install the binutils package? It looks like you have not. You need the bgclang-binutils package for the setup to function properly.
-Hal
> One wrinkle I've found is that if I try and use the MPI wrappers to
> build a
> simple "hello world" program they do not correctly determine the
> library
> locations:
> [samuel at avoca Test]$ bash -x mpicc -O3 -o hello-bgclang hello.c
> ++ readlink /bgsys/drivers/ppcfloor
> + ppcflr=V1R2M0/ppc64/
> + pamilibdir=V1R2M0/ppc64//comm/sys/lib
> + newlayout=0
> + '[' -d V1R2M0/ppc64//comm/lib ']'
> + '[' 0 = 1 ']'
> + prefix=V1R2M0/ppc64//comm/gcc
> + exec_prefix=V1R2M0/ppc64//comm/gcc
> + sysconfdir=V1R2M0/ppc64//comm/gcc/etc
> + libdir=V1R2M0/ppc64//comm/gcc/lib
> + includedir=V1R2M0/ppc64//comm/gcc/include
> + CC=/usr/local/llvm/r203443-20140309/bin/bgclang
> + '[' 0 = 1 ']'
> + CFLAGS=' -IV1R2M0/ppc64/ -IV1R2M0/ppc64//comm/sys/include
> -IV1R2M0/ppc64//spi/include -IV1R2M0/ppc64//spi/include/kernel/cnk'
> + CPPFLAGS=' '
> + LDFLAGS=' -LV1R2M0/ppc64//spi/lib -LV1R2M0/ppc64//comm/sys/lib
> -LV1R2M0/ppc64//spi/lib'
> + LIBS='-lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++
> -lpthread '
> [...much elided...]
> + bgclang -IV1R2M0/ppc64/ -IV1R2M0/ppc64//comm/sys/include
> -LV1R2M0/ppc64//spi/lib -O3 -o hello-bgclang hello.c
> -IV1R2M0/ppc64//comm/gcc/include -LV1R2M0/ppc64//comm/gcc/lib
> -Wl,-rpath -Wl,V1R2M0/ppc64//comm/sys/lib -Wl,-rpath
> -Wl,V1R2M0/ppc64//comm/gcc/lib -lmpich -lopa -lmpl -lpami -lSPI
> -lSPI_cnk -lrt -lpthread -lstdc++ -lpthread
> /usr/local/llvm/r203443-20140309/bin/clang: /lib64/libz.so.1: no
> version information available (required by
> /usr/local/llvm/r203443-20140309/bin/../lib/libLLVM-3.5.0svn.so)
> /usr/local/llvm/r203443-20140309/binutils/bin/as: /lib64/libz.so.1:
> no version information available (required by
> /usr/local/llvm/r203443-20140309/binutils/bin/as)
> /usr/local/llvm/r203443-20140309/binutils/bin/ld: /lib64/libz.so.1:
> /usr/local/llvm/r203443-20140309/binutils/bin/ld)
> /usr/local/llvm/r203443-20140309/binutils/bin/ld: cannot find
> crtbeginT.o: No such file or directory
> /usr/local/llvm/r203443-20140309/binutils/bin/ld: cannot find -lmpich
> /usr/local/llvm/r203443-20140309/binutils/bin/ld: cannot find -lopa
> /usr/local/llvm/r203443-20140309/binutils/bin/ld: cannot find -lmpl
> /usr/local/llvm/r203443-20140309/binutils/bin/ld: cannot find -lpami
> /usr/local/llvm/r203443-20140309/binutils/bin/ld: cannot find -lSPI
> -lSPI_cnk
> /usr/local/llvm/r203443-20140309/binutils/bin/ld: cannot find -lrt
> -lpthread
> -lstdc++
> -lpthread
> /usr/local/llvm/r203443-20140309/binutils/bin/ld: cannot find -lgcc
> -lgcc_eh
> /usr/local/llvm/r203443-20140309/binutils/bin/ld: cannot find -ldl
> /usr/local/llvm/r203443-20140309/binutils/bin/ld: cannot find -lc
> -lnss_files
> -lnss_dns
> -lresolv
> clang: error: linker command failed with exit code 1 (use -v to see
> invocation)
> + rc=1
> + exit 1
> My guess this is a result of how the link is set:
> [samuel at avoca Test]$ ls -ld /bgsys/drivers/ppcfloor
> lrwxrwxrwx 1 root root 13 Jan 30 11:23 /bgsys/drivers/ppcfloor ->
> V1R2M0/ppc64/
> The fix for the MPI/PAMI/SPI side may be as simple as testing if
> the destination of the link is relative (as it is here) and if so
> then prepending the path of the directory containing the link
> to it.
> However, if I add those by hand I am still left with this puzzling
> set:
> -lpthread
> -lstdc++
> -lpthread
> -lgcc_eh
> -lnss_files
> -lnss_dns
> -lresolv
> invocation)
> I can fix most of those by hand by adding the library paths by hand
> with:
> -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6
> -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib
> but it needs some way to automate finding them I'd say.
> That still leaves me with the ones I cannot solve:
> Thoughts?
> cheers!
> Chris
> Christopher Samuel Senior Systems Administrator
> VLSCI - Victorian Life Sciences Computation Initiative
> Email: samuel at unimelb.edu.au Phone: +61 (0)3 903 55545
> http://www.vlsci.org.au/ http://twitter.com/vlsci
> llvm-bgq-discuss mailing list
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
Hal Finkel
Assistant Computational Scientist
Leadership Computing Facility
Argonne National Laboratory
More information about the llvm-bgq-discuss
