[Llvm-bgq-discuss] bgclang r205936-20140409 on vesta/mira
Hal Finkel
hfinkel at anl.gov
Fri Apr 11 07:44:45 CDT 2014
What's in your hello.cxx?
-Hal
----- Original Message -----
> From: "John A. Biddiscombe" <biddisco at cscs.ch>
> To: "Hal Finkel" <hfinkel at anl.gov>, "Thomas Heller" <thom.heller at gmail.com>
> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Friday, April 11, 2014 7:42:25 AM
> Subject: RE: [Llvm-bgq-discuss] bgclang r205936-20140409 on vesta/mira
> Hal,
> I have
> CC="/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/bin/bgclang"
> CXX="/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/bin/bgclang++11"
> after a bit of experimentation, I found that
> $CC hello.c -o hello
> works fine and executable runs on login and ION
> $CXX hello.cxx -o hello
> gives the link error
> but
> /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/mpi/bgclang/bin/mpic++
> hello.cxx -o hello
> works for a non mpi application on login and ION
> and for an mpi aplication
> hellompi.cxx -o hello
> compiles ok, but on execution dies on login and ION
> bbpbg2:~/src/c++test$ mpiexec -n 1 ./hello
> /bgsys/source/srcV1R2M1.17463/comm/sys/buildtools/pami/common/bgq/BgqPersonality.h:102:
> /bgsys/source/srcV1R2M1.17463/comm/sys/buildtools/pami/common/bgq/BgqPersonality.h<102>
> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> = EXIT CODE: 134
> = CLEANING UP REMAINING PROCESSES
> = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> APPLICATION TERMINATED WITH THE EXIT STRING: Aborted (signal 6)
> Not sure if this helps you, but it's interesting that mpic++ links
> ok, when c++ does not, I use c++ compiler by default and link mkpi
> stuff myself (I don't use the mpi wrappers generally)
> JB
> > -----Original Message-----
> > From: Hal Finkel [mailto:hfinkel at anl.gov]
> > Sent: 11 April 2014 14:19
> > To: Thomas Heller
> > Cc: Biddiscombe, John A.; llvm-bgq-discuss at lists.alcf.anl.gov
> > Subject: Re: [Llvm-bgq-discuss] bgclang r205936-20140409 on
> > vesta/mira
> > I'll look into this today.
> > -Hal
> > > From: "Thomas Heller" <thom.heller at gmail.com>
> > > To: "John A. Biddiscombe" <biddisco at cscs.ch>,
> > > Sent: Friday, April 11, 2014 6:19:32 AM
> > > vesta/mira
> > > On 04/11/2014 12:48 PM, Biddiscombe, John A. wrote:
> > > > oops, I think I pasted the wrong error into my email, the
> > > > actual one
> > > > I can't make go away is this
> > > > /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-
> > 20140409/libc++/lib/libc++.so:
> > > > undefined reference to `vtable for
> > > > std::nested_exception at CXXABI_1.3.5' clang: error: linker
> > > > command
> > > > failed with exit code 1 (use -v to see invocation)
> > > > any suggestions welcome.
> > > I haven't seen this error before ...
> > > > JB
> > > >> From: llvm-bgq-discuss-bounces at lists.alcf.anl.gov
> > > >> [mailto:llvm-bgq-discuss-
> > > >> bounces at lists.alcf.anl.gov] On Behalf Of Thomas Heller
> > > >> Sent: 11 April 2014 12:42
> > > >> To: llvm-bgq-discuss at lists.alcf.anl.gov
> > > >> vesta/mira
> > > >> John,
> > > >> I have a dirty workaround for this in HPX ... let me commit
> > > >> real
> > > >> quick (not sure where this comes from though)
> > > >> On 04/11/2014 12:03 PM, Biddiscombe, John A. wrote:
> > > >>> Hal
> > > >>> We have the toolchain_4.7.2 files installed in what I
> > > >>> believe is
> > > >>> the default location, recompiling boost+hpx still gives me
> > > >>> the
> > > >>> std::exception link errors, if I add
> > > >>> /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/powerpc64-bgq-linux/li
> > > >>> b/li
> > > >>> bstdc++.a
> > > >>> to the link libs, then all the errors go away except this one
> > > >>> ../../../../lib/hpx/libhpxd.so.0.9.9: undefined reference to
> > > >> `boost::re_detail::perl_matcher<std::__1::__wrap_iter<char
> > > >> const*>,
> > > >> std::__1::allocator<boost::sub_match<std::__1::__wrap_iter<char
> > > >> const*> >
> > > >>> , boost::regex_traits<char, boost::cpp_regex_traits<char> >
> > > >>> >::match()'
> > > >>> Which looks like a -stdlib=c++ problem.
> > > >>> Can you tell me what setting you use to compile boost with?
> > > >>> I've
> > > >>> been using # user-config.jam (put this file into your home
> > > >>> directory) using clang
> > > >>> : bgclang++11
> > > >>> : <cxxflags> -std=c++0x
> > > >>> and tried adding/removing -stdlib=libc++ or -stdlib=stdc++,
> > > >>> but so
> > > >>> far no
> > > >> success.
> > > >>> yours
> > > >>> JB
> > > >>>> Sent: 10 April 2014 19:41
> > > >>>> To: Biddiscombe, John A.
> > > >>>> vesta/mira
> > > >>>> John,
> > > >>>> Yes, this looks exactly like the issue that really motivated
> > > >>>> the
> > > >>>> switch. There are necessary symbols that are just missing
> > > >>>> from
> > > >>>> the old 4.4.6 libraries (the situation is somewhat
> > > >>>> complicated
> > > >>>> because the compiler actually generated multiple version of
> > > >>>> these
> > > >>>> destructors, and the older gcc did not generate all of
> > > >>>> them). As
> > > >>>> I said,
> > > >> please let me know if you can't get the files.
> > > >>>> -Hal
> > > >>>>> Sent: Thursday, April 10, 2014 12:30:12 PM
> > > >>>>> vesta/mira
> > > >>>>> Hal
> > > >>>>> Linking CXX executable ../../../../bin/network_storage
> > > >>>>> CMakeFiles/network_storage_exe.dir/network_storage.cpp.o:
> > > >>>>> In
> > > >>>>> function
> > > >>>>> `current_exception_std_exception_wrapper':
> > /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/boost_1_55_0/include/boo
> > > >> st
> > > >>>>> 1_55/
> > > >>>>> boost/exception/detail/exception_ptr.hpp:220: undefined
> > > >>>>> reference to `std::domain_error::~domain_error()'
> > > >>>>> In
> > > >>>>> function
> > > >>>>> `~current_exception_std_exception_wrapper':
> > > >> st
> > > >>>>> 1_55/
> > > >>>>> boost/exception/detail/exception_ptr.hpp:224: undefined
> > > >>>>> …. + million more
> > > >>>>> I have to go out now, so I can’t play, but if those errors
> > > >>>>> look
> > > >>>>> like a
> > > >>>>> libstdc++ issue then I might need those 4.7.2 files…
> > > >>>>> Cheers
> > > >>>>> JB
> > > >>>>> On 10/04/14 19:06, "Hal Finkel" <hfinkel at anl.gov> wrote:
> > > >>>>>> I'll also add that all V1R2M1 installs (as far as I know)
> > > >>>>>> use
> > > >>>>>> 4.4.6
> > > >>>>>> by default. The 4.7.2 files are supplementary; you (or
> > > >>>>>> your
> > > >>>>>> system
> > > >>>>>> admins)
> > > >>>>>> just need to unpack them.
> > > >>>>>> -Hal
> > > >>>>>>> From: "Hal Finkel" <hfinkel at anl.gov>
> > > >>>>>>> Sent: Thursday, April 10, 2014 12:04:16 PM
> > > >>>>>>> on
> > > >>>>>>> vesta/mira
> > > >>>>>>> No problem; to be clear, the files from the 4.7.2
> > > >>>>>>> toolchain
> > > >>>>>>> that are used by bgclang should not really be sensitive
> > > >>>>>>> to the
> > > >>>>>>> driver version you're actually using. If, however, you
> > > >>>>>>> have
> > > >>>>>>> any problems with the new build, please let me know.
> > > >>>>>>> -Hal
> > > >>>>>>>> To: "John A. Biddiscombe" <biddisco at cscs.ch>, "Hal
> > > >>>>>>>> Finkel"
> > > >>>>>>>> <hfinkel at anl.gov>, llvm-bgq-discuss at lists.alcf.anl.gov
> > > >>>>>>>> Sent: Thursday, April 10, 2014 12:00:34 PM
> > > >>>>>>>> on
> > > >>>>>>>> vesta/mira
> > > >>>>>>>> Sorry, rereading what you wrote the answer must be no. I
> > > >>>>>>>> was
> > > >>>>>>>> confused because we have V1R2M1, but use 4.4.6
> > > >>>>>>>> JB
> > > >>>>>>>> On 10/04/14 18:55, "Biddiscombe, John A."
> > > >>>>>>>> wrote:
> > > >>>>>>>>> Hal,
> > > >>>>>>>>>> 1. The toolchain is now setup to use libc/libstdc++
> > > >>>>>>>>>> files
> > > >>>>>>>>> >from the
> > > >>>>>>>>>> /bgsys/drivers/toolchain/V1R2M1_base_4.7.2 -- this
> > > >>>>>>>>>> gives
> > > >>>>>>>>>> access to a more-recent environment for C/C++03
> > > >>>>>>>>>> compilation, and furthermore, is necessary to make (at
> > > >>>>>>>>>> least one part of) Boost work with
> > > >>>>>>>>>> bgclang++11. You
> > > >>>>>>>>>> don't need to be on a system running V1R2M1 (Mira is
> > > >>>>>>>>>> not
> > > >>>>>>>>>> yet, for
> > > >>>>>>>>>> example) to make use of this.
> > > >>>>>>>>> We don’t have the toolchain 4.7.2 on our system. Does
> > > >>>>>>>>> that
> > > >>>>>>>>> mean I can’t use the new compiler? We have only files
> > > >>>>>>>>> from
> > > >>>>>>>>> 4.4.6 :(
> > > >>>>>>>>> Thanks
> > > >>>>>>>>> JB
> > > >>>>>>>>>> 2. There are more OpenMP 4 features available for you
> > > >>>>>>>>>> to
> > > >>>>>>>>>> play
> > > >>>>>>>>>> with:
> > > >>>>>>>>>> - '#pragma omp simd' (and friends) should now work
> > > >>>>>>>>>> (in
> > > >>>>>>>>>> the
> > > >>>>>>>>>> sense
> > > >>>>>>>>>> that
> > > >>>>>>>>>> there is a reasonable probability that it will cause
> > > >>>>>>>>>> QPX to
> > > >>>>>>>>>> be
> > > >>>>>>>>>> generated)
> > > >>>>>>>>>> - '#pragma omp task depend(...)' is supported (for
> > > >>>>>>>>>> the
> > > >>>>>>>>>> most
> > > >>>>>>>>>> part; I
> > > >>>>>>>>>> think there are still some corner cases where the
> > > >>>>>>>>>> compiler
> > > >>>>>>>>>> support is ahead of the runtime).
> > > >>>>>>>>>> Please try these things out and let me know what
> > > >>>>>>>>>> you
> > > >>>>>>>>>> find.
> > > >>>>>>>>>> For those maintaining their own installs, RPMs (and
> > > >>>>>>>>>> SRPMs)
> > > >>>>>>>>>> are available on the trac page:
> > > >>>>>>>>>> https://trac.alcf.anl.gov/projects/llvm-bgq
> > > >>>>>>>>>> If
> > > >>>>>>>>>> your
> > > >>>>>>>>>> system does not have
> > > >>>>>>>>>> unpacked,
> > > >>>>>>>>>> and you can't get a copy of those files, please let me
> > > >>>>>>>>>> know.
> > > >>>>>>>>>> Finally, for those strange creatures wanting to run
> > > >>>>>>>>>> the
> > > >>>>>>>>>> compiler
> > > >>>>>>>>> >from the
> > > >>>>>>>>>> A2 login or I/O nodes, I believe this build should now
> > > >>>>>>>>>> work
> > > >>>>>>>>>> for you again. ;)
> > > >>>>>>>>>> Thanks again,
> > > >>>>>>>>>> Hal
> > > >>>>>>>>>> Hal Finkel
> > > >>>>>>>>>> Assistant Computational Scientist Leadership Computing
> > > >>>>>>>>>> Facility Argonne National Laboratory
> > > >>>>>>>>>> _______________________________________________
> > > >>>>>>>>>> llvm-bgq-discuss mailing list
> > > >>>>>>>>>> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discus
> > > >>>>>>>>>> s
> > > >>>>>>>>>> s
> > > >>>>>>>>>> s
> > > >>>>>>>>> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> > > >>>>>>> Hal Finkel
> > > >>>>>> Hal Finkel
> > > >>>>>> Facility
> > > >>>> Hal Finkel
> > > >>>> Leadership Computing Facility
> > > >> Thomas Heller
> > > >> Friedrich-Alexander-Universität Erlangen-Nürnberg Department
> > > >> Informatik -
> > > >> Lehrstuhl Rechnerarchitektur Martensstr. 3
> > > >> 91058 Erlangen
> > > >> Tel.: 09131/85-27018
> > > >> Fax: 09131/85-27912
> > > >> Email: thomas.heller at cs.fau.de
> > > Thomas Heller
> > > Department Informatik - Lehrstuhl Rechnerarchitektur
> > > Martensstr. 3
> > > 91058 Erlangen
> > > Fax: 09131/85-27912
> > Hal Finkel
Hal Finkel
More information about the llvm-bgq-discuss
