[Llvm-bgq-discuss] bgclang r205936-20140409 on vesta/mira
Hal Finkel
hfinkel at anl.gov
Fri Apr 11 11:24:54 CDT 2014
----- Original Message -----
> From: "John A. Biddiscombe" <biddisco at cscs.ch>
> To: "Hal Finkel" <hfinkel at anl.gov>
> Cc: llvm-bgq-discuss at lists.alcf.anl.gov, "Thomas Heller" <thom.heller at gmail.com>
> Sent: Friday, April 11, 2014 11:21:22 AM
> Subject: Re: [Llvm-bgq-discuss] bgclang r205936-20140409 on vesta/mira
> Hal
> Ours is installed (correctly?) in
> /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/
The wrapper script currently looks only in:
/bgsys/drivers/toolchain/V1R2M1_base_4.7.2/gnu-linux-4.7.2
Do you have them there? (I'm guessing the answer is no).
-Hal
> And the output of the link is here.
> Thanks again
> JB
> bbpbg2:~/src/c++test$ bgclang++11 -O3 -o hello hello.cxx -dynamic -v
> clang version 3.5.0 (trunk)
> Target: powerpc64-bgq-linux
> Thread model: posix
> Found candidate GCC installation:
> /bgsys/drivers/V1R2M1/ppc64/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6
> Selected GCC installation:
> Candidate multilib: .;@m64
> Selected multilib: .;@m64
> "/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/bin/c
> lang" -cc1 -triple powerpc64-bgq-linux -S -disable-free
> -main-file-name
> hello.cxx -mrelocation-model static -mdisable-fp-elim
> -ffp-contract=fast
> -no-integrated-as -mconstructor-aliases -target-cpu a2q
> -target-linker-version 2.20.51.0.2 -v -resource-dir
> /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/bin/../
> lib/clang/3.5.0 -D __bgclang__=1 -D
> "__bgclang_version__=\"r205936-20140409\"" -I
> /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/sleef/i
> nclude -internal-isystem /usr/local/include -internal-isystem
> lib/clang/3.5.0/include -internal-externc-isystem /include
> -internal-externc-isystem /usr/include -O3 -std=gnu++11
> -fdeprecated-macro
> -fno-dwarf-directory-asm -fdebug-compilation-dir
> /gpfs/bbp.cscs.ch/home/biddisco/src/c++test -ferror-limit 19
> -fmessage-length 129 -mstackrealign -fno-signed-char
> -fobjc-runtime=gcc
> -fcxx-exceptions -fexceptions -fdiagnostics-show-option
> -fcolor-diagnostics -vectorize-loops -vectorize-slp -isystem
> /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/libc++/
> include -isystem
> /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/libstdc
> ++fixup/include -isystem
> /bgsys/drivers/V1R2M1/ppc64/gnu-linux/powerpc64-bgq-linux/include/c++/4.4.6
> -isystem
> /powerpc64-bgq-linux -isystem
> /bgsys/drivers/V1R2M1/ppc64/gnu-linux/powerpc64-bgq-linux/sys-include
> -mllvm -optimize-regalloc -mllvm -fast-isel=0 -o /tmp/hello-57bca4.s
> -x
> c++ hello.cxx
> clang -cc1 version 3.5.0 based upon LLVM 3.5.0svn default target
> powerpc64-unknown-linux-gnu
> ignoring nonexistent directory
> "/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/libstd
> c++fixup/include"
> ignoring nonexistent directory "/include"
> #include "..." search starts here:
> #include <...> search starts here:
> include
> /include
> 6
> 6/powerpc64-bgq-linux
> /usr/local/include
> /lib/clang/3.5.0/include
> /usr/include
> End of search list.
> "/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/binut
> ils/bin/as" -a64 -mppc64 -many -ma2q -o /tmp/hello-70bffe.o
> /tmp/hello-57bca4.s
> ils/bin/ld" --hash-style=gnu --no-add-needed --build-id
> --eh-frame-hdr -m
> elf64ppc -dynamic-linker /lib64/ld64.so.1 -o hello
> /bgsys/drivers/V1R2M1/ppc64/gnu-linux/powerpc64-bgq-linux/lib/crt1.o
> /bgsys/drivers/V1R2M1/ppc64/gnu-linux/powerpc64-bgq-linux/lib/crti.o
> /bgsys/drivers/V1R2M1/ppc64/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crt
> begin.o
> -L/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/libc+
> +/lib -L/bgsys/drivers/V1R2M1/ppc64/gnu-linux/powerpc64-bgq-linux/lib
> -L/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/sleef
> /lib
> -L/bgsys/drivers/V1R2M1/ppc64/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6
> -L/bgsys/drivers/V1R2M1/ppc64/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/.
> ./../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64
> ./../../../powerpc64-bgq-linux/lib
> -L/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/bin/.
> ./lib -L/lib -L/usr/lib -rpath
> lib -rpath
> /tmp/hello-70bffe.o -rpath
> /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/sleef/l
> ib --as-needed -lsleef --no-as-needed -lc++ -lstdc++ -lm -lgcc_s
> -lgcc -lc
> -lgcc_s -lgcc
> end.o
> /bgsys/drivers/V1R2M1/ppc64/gnu-linux/powerpc64-bgq-linux/lib/crtn.o
> lib/libc++.so: undefined reference to `vtable for
> std::nested_exception at CXXABI_1.3.5'
> clang: error: linker command failed with exit code 1 (use -v to see
> invocation)
> On 11/04/14 17:53, "Hal Finkel" <hfinkel at anl.gov> wrote:
> >John,
> >I just noticed that, while I'm unable to reproduce this problem on
> >our
> >vesta system, I am able to reproduce the problem on our mira system.
> >The
> >reason is that on mira the 4.7.2 files ended up in a directory:
> >/bgsys/drivers/toolchain/V1R2M1_base_4.7.2/V1R2M1_base_4.7.2/gnu-linux-4.7
> >.2
> >instead of:
> >did something similar happen to you? Otherwise, can you please send
> >the
> >output of:
> > -Hal
> >> Sent: Friday, April 11, 2014 7:45:49 AM
> >> Subject: RE: [Llvm-bgq-discuss] bgclang r205936-20140409 on
> >> vesta/mira
> >> bbpbgas033:~/src/c++test$ cat hello.cxx
> >> #include <stdio.h>
> >> #include <string.h>
> >> #include <errno.h>
> >> #include <sys/types.h>
> >> #include <sys/stat.h>
> >> #include <fcntl.h>
> >> #include <iostream>
> >> int main(int argc, char **argv)
> >> std::cout << "Hello " << std::endl;
> >> apologies for the surplus #includes
> >> > -----Original Message-----
> >> > From: Hal Finkel [mailto:hfinkel at anl.gov]
> >> > Sent: 11 April 2014 14:45
> >> > To: Biddiscombe, John A.
> >> > Cc: llvm-bgq-discuss at lists.alcf.anl.gov; Thomas Heller
> >> > vesta/mira
> >> > What's in your hello.cxx?
> >> > -Hal
> >> > > To: "Hal Finkel" <hfinkel at anl.gov>, "Thomas Heller"
> >> > > Sent: Friday, April 11, 2014 7:42:25 AM
> >> > > vesta/mira
> >> > > Hal,
> >> > > I have
> >> > > CC="/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/bin/bgclang"
> >> > CXX="/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/bin/bgclang++1
> >> > 1"
> >> > > after a bit of experimentation, I found that $CC hello.c -o
> >> > > hello
> >> > > works fine and executable runs on login and ION
> >> > > $CXX hello.cxx -o hello
> >> > > gives the link error
> >> > > but
> >> > /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/mpi/bgclang/bin/mpi
> >> > > c++
> >> > > hello.cxx -o hello
> >> > > works for a non mpi application on login and ION
> >> > > and for an mpi aplication
> >> > > c++
> >> > > hellompi.cxx -o hello
> >> > > compiles ok, but on execution dies on login and ION
> >> > > bbpbg2:~/src/c++test$ mpiexec -n 1 ./hello
> >> > /bgsys/source/srcV1R2M1.17463/comm/sys/buildtools/pami/common/bgq/
> >> > BgqPersonality.h:102:
> >> > BgqP
> >> > > ersonality.h<102>
> >> > > = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> >> > > = EXIT CODE: 134
> >> > > = CLEANING UP REMAINING PROCESSES
> >> > > = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> >> > > =============== APPLICATION TERMINATED WITH THE EXIT STRING:
> >> > Aborted
> >> > > (signal 6)
> >> > > Not sure if this helps you, but it's interesting that mpic++
> >> > > links ok,
> >> > > when c++ does not, I use c++ compiler by default and link mkpi
> >> > > stuff
> >> > > myself (I don't use the mpi wrappers generally)
> >> > > JB
> >> > > > Sent: 11 April 2014 14:19
> >> > > > To: Thomas Heller
> >> > > > Cc: Biddiscombe, John A.;
> >> > > > vesta/mira
> >> > > > I'll look into this today.
> >> > > > -Hal
> >> > > > > From: "Thomas Heller" <thom.heller at gmail.com>
> >> > > > > To: "John A. Biddiscombe" <biddisco at cscs.ch>,
> >> > > > > Sent: Friday, April 11, 2014 6:19:32 AM
> >> > > > > on
> >> > > > > vesta/mira
> >> > > > > On 04/11/2014 12:48 PM, Biddiscombe, John A. wrote:
> >> > > > > > oops, I think I pasted the wrong error into my email,
> >> > > > > > the
> >> > > > > > actual
> >> > > > > > one I can't make go away is this
> >> > > > 20140409/libc++/lib/libc++.so:
> >> > > > > > std::nested_exception at CXXABI_1.3.5' clang: error: linker
> >> > > > > > command
> >> > > > > > failed with exit code 1 (use -v to see invocation)
> >> > > > > > any suggestions welcome.
> >> > > > > I haven't seen this error before ...
> >> > > > > > JB
> >> > > > > >> From: llvm-bgq-discuss-bounces at lists.alcf.anl.gov
> >> > > > > >> [mailto:llvm-bgq-discuss-
> >> > > > > >> bounces at lists.alcf.anl.gov] On Behalf Of Thomas Heller
> >> > > > > >> Sent: 11 April 2014 12:42
> >> > > > > >> To: llvm-bgq-discuss at lists.alcf.anl.gov
> >> > > > > >> r205936-20140409
> >> > > > > >> on
> >> > > > > >> vesta/mira
> >> > > > > >> John,
> >> > > > > >> I have a dirty workaround for this in HPX ... let me
> >> > > > > >> commit
> >> > > > > >> real quick (not sure where this comes from though)
> >> > > > > >> On 04/11/2014 12:03 PM, Biddiscombe, John A. wrote:
> >> > > > > >>> Hal
> >> > > > > >>> We have the toolchain_4.7.2 files installed in what I
> >> > > > > >>> believe
> >> > > > > >>> is the default location, recompiling boost+hpx still
> >> > > > > >>> gives me
> >> > > > > >>> the std::exception link errors, if I add
> >> > > > > >>> /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/powerpc64-bgq-
> >> > linu
> >> > > > > >>> x/li
> >> > > > > >>> b/li
> >> > > > > >>> bstdc++.a
> >> > > > > >>> to the link libs, then all the errors go away except
> >> > > > > >>> this
> >> > > > > >>> one
> >> > > > > >>> ../../../../lib/hpx/libhpxd.so.0.9.9: undefined
> >> > > > > >>> reference
> >> > > > > >>> to
> >> > > > > >> `boost::re_detail::perl_matcher<std::__1::__wrap_iter<char
> >> > > > > >> const*>,
> >>std::__1::allocator<boost::sub_match<std::__1::__wrap_iter<char
> >> > > > > >> const*> >
> >> > > > > >>> , boost::regex_traits<char,
> >> > > > > >>> boost::cpp_regex_traits<char>
> >> > > > > >>> >::match()'
> >> > > > > >>> Which looks like a -stdlib=c++ problem.
> >> > > > > >>> Can you tell me what setting you use to compile boost
> >> > > > > >>> with?
> >> > > > > >>> I've
> >> > > > > >>> been using # user-config.jam (put this file into your
> >> > > > > >>> home
> >> > > > > >>> directory) using clang
> >> > > > > >>> : bgclang++11
> >> > > > > >>> : <cxxflags> -std=c++0x
> >> > > > > >>> and tried adding/removing -stdlib=libc++ or
> >> > > > > >>> -stdlib=stdc++,
> >> > > > > >>> but so far no
> >> > > > > >> success.
> >> > > > > >>> yours
> >> > > > > >>> JB
> >> > > > > >>>> Sent: 10 April 2014 19:41
> >> > > > > >>>> r205936-20140409
> >> > > > > >>>> on
> >> > > > > >>>> vesta/mira
> >> > > > > >>>> John,
> >> > > > > >>>> Yes, this looks exactly like the issue that really
> >> > > > > >>>> motivated
> >> > > > > >>>> the switch. There are necessary symbols that are just
> >> > > > > >>>> missing
> >> > > > > >>>> from the old 4.4.6 libraries (the situation is
> >> > > > > >>>> somewhat
> >> > > > > >>>> complicated because the compiler actually generated
> >> > > > > >>>> multiple
> >> > > > > >>>> version of these destructors, and the older gcc did
> >> > > > > >>>> not
> >> > > > > >>>> generate all of them). As I said,
> >> > > > > >> please let me know if you can't get the files.
> >> > > > > >>>> -Hal
> >> > > > > >>>>> Sent: Thursday, April 10, 2014 12:30:12 PM
> >> > > > > >>>>> r205936-20140409 on
> >> > > > > >>>>> vesta/mira
> >> > > > > >>>>> Hal
> >> > > > > >>>>> Linking CXX executable
> >> > > > > >>>>> ../../../../bin/network_storage
> >> > > > > >>>>> CMakeFiles/network_storage_exe.dir/network_storage.cpp.o:
> >> > > > > >>>>> In
> >> > > > > >>>>> function
> >> > > > > >>>>> `current_exception_std_exception_wrapper':
> >> > /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/boost_1_55_0/include/boo
> >> > > > > >> st
> >> > > > > >>>>> 1_55/
> >> > > > > >>>>> boost/exception/detail/exception_ptr.hpp:220:
> >> > > > > >>>>> undefined
> >> > > > > >>>>> reference to `std::domain_error::~domain_error()'
> >> > > > > >>>>> In
> >> > > > > >>>>> function
> >> > > > > >>>>> `~current_exception_std_exception_wrapper':
> >> > > > > >> st
> >> > > > > >>>>> 1_55/
> >> > > > > >>>>> boost/exception/detail/exception_ptr.hpp:224:
> >> > > > > >>>>> undefined
> >> > > > > >>>>> …. + million more
> >> > > > > >>>>> I have to go out now, so I can’t play, but if those
> >> > > > > >>>>> errors
> >> > > > > >>>>> look like a
> >> > > > > >>>>> libstdc++ issue then I might need those 4.7.2 files…
> >> > > > > >>>>> Cheers
> >> > > > > >>>>> JB
> >> > > > > >>>>> On 10/04/14 19:06, "Hal Finkel" <hfinkel at anl.gov>
> >> > > > > >>>>> wrote:
> >> > > > > >>>>>> I'll also add that all V1R2M1 installs (as far as I
> >> > > > > >>>>>> know)
> >> > > > > >>>>>> use
> >> > > > > >>>>>> 4.4.6
> >> > > > > >>>>>> by default. The 4.7.2 files are supplementary; you
> >> > > > > >>>>>> (or
> >> > > > > >>>>>> your
> >> > > > > >>>>>> system
> >> > > > > >>>>>> admins)
> >> > > > > >>>>>> just need to unpack them.
> >> > > > > >>>>>> -Hal
> >> > > > > >>>>>>> From: "Hal Finkel" <hfinkel at anl.gov>
> >> > > > > >>>>>>> Sent: Thursday, April 10, 2014 12:04:16 PM
> >> > > > > >>>>>>> r205936-20140409
> >> > > > > >>>>>>> on vesta/mira
> >> > > > > >>>>>>> No problem; to be clear, the files from the 4.7.2
> >> > > > > >>>>>>> toolchain that are used by bgclang should not
> >> > > > > >>>>>>> really
> >> > > > > >>>>>>> be
> >> > > > > >>>>>>> sensitive to the driver version you're actually
> >> > > > > >>>>>>> using. If,
> >> > > > > >>>>>>> however, you have any problems with the new build,
> >> > > > > >>>>>>> please
> >> > > > > >>>>>>> let me know.
> >> > > > > >>>>>>> -Hal
> >> > > > > >>>>>>>> "Hal
> >> > > > > >>>>>>>> Finkel"
> >> > > > > >>>>>>>> Sent: Thursday, April 10, 2014 12:00:34 PM
> >> > > > > >>>>>>>> r205936-20140409
> >> > > > > >>>>>>>> on vesta/mira
> >> > > > > >>>>>>>> Sorry, rereading what you wrote the answer must
> >> > > > > >>>>>>>> be
> >> > > > > >>>>>>>> no. I
> >> > > > > >>>>>>>> was confused because we have V1R2M1, but use
> >> > > > > >>>>>>>> 4.4.6
> >> > > > > >>>>>>>> JB
> >> > > > > >>>>>>>> On 10/04/14 18:55, "Biddiscombe, John A."
> >> > > > > >>>>>>>> wrote:
> >> > > > > >>>>>>>>> Hal,
> >> > > > > >>>>>>>>>> 1. The toolchain is now setup to use
> >> > > > > >>>>>>>>>> libc/libstdc++
> >> > > > > >>>>>>>>>> files
> >> > > > > >>>>>>>>> >from the
> >> > > > > >>>>>>>>>> /bgsys/drivers/toolchain/V1R2M1_base_4.7.2 --
> >> > > > > >>>>>>>>>> this
> >> > > > > >>>>>>>>>> gives access to a more-recent environment for
> >> > > > > >>>>>>>>>> C/C++03
> >> > > > > >>>>>>>>>> compilation, and furthermore, is necessary to
> >> > > > > >>>>>>>>>> make
> >> > > > > >>>>>>>>>> (at
> >> > > > > >>>>>>>>>> least one part of) Boost work with
> >> > > > > >>>>>>>>>> bgclang++11. You
> >> > > > > >>>>>>>>>> don't need to be on a system running V1R2M1
> >> > > > > >>>>>>>>>> (Mira
> >> > > > > >>>>>>>>>> is
> >> > > > > >>>>>>>>>> not yet, for
> >> > > > > >>>>>>>>>> example) to make use of this.
> >> > > > > >>>>>>>>> We don’t have the toolchain 4.7.2 on our system.
> >> > > > > >>>>>>>>> Does
> >> > > > > >>>>>>>>> that mean I can’t use the new compiler? We have
> >> > > > > >>>>>>>>> only
> >> > > > > >>>>>>>>> files from
> >> > > > > >>>>>>>>> 4.4.6 :(
> >> > > > > >>>>>>>>> Thanks
> >> > > > > >>>>>>>>> JB
> >> > > > > >>>>>>>>>> 2. There are more OpenMP 4 features available
> >> > > > > >>>>>>>>>> for
> >> > > > > >>>>>>>>>> you
> >> > > > > >>>>>>>>>> to play
> >> > > > > >>>>>>>>>> with:
> >> > > > > >>>>>>>>>> - '#pragma omp simd' (and friends) should
> >> > > > > >>>>>>>>>> now
> >> > > > > >>>>>>>>>> work
> >> > > > > >>>>>>>>>> (in
> >> > > > > >>>>>>>>>> the
> >> > > > > >>>>>>>>>> sense
> >> > > > > >>>>>>>>>> that
> >> > > > > >>>>>>>>>> there is a reasonable probability that it will
> >> > > > > >>>>>>>>>> cause
> >> > > > > >>>>>>>>>> QPX to be
> >> > > > > >>>>>>>>>> generated)
> >> > > > > >>>>>>>>>> - '#pragma omp task depend(...)' is
> >> > > > > >>>>>>>>>> supported
> >> > > > > >>>>>>>>>> (for
> >> > > > > >>>>>>>>>> the
> >> > > > > >>>>>>>>>> most
> >> > > > > >>>>>>>>>> part; I
> >> > > > > >>>>>>>>>> think there are still some corner cases where
> >> > > > > >>>>>>>>>> the
> >> > > > > >>>>>>>>>> compiler support is ahead of the runtime).
> >> > > > > >>>>>>>>>> Please try these things out and let me
> >> > > > > >>>>>>>>>> know
> >> > > > > >>>>>>>>>> what
> >> > > > > >>>>>>>>>> you
> >> > > > > >>>>>>>>>> find.
> >> > > > > >>>>>>>>>> For those maintaining their own installs, RPMs
> >> > > > > >>>>>>>>>> (and
> >> > > > > >>>>>>>>>> SRPMs)
> >> > > > > >>>>>>>>>> are available on the trac page:
> >> > > > > >>>>>>>>>> https://trac.alcf.anl.gov/projects/llvm-bgq
> >> > > > > >>>>>>>>>> If
> >> > > > > >>>>>>>>>> your
> >> > > > > >>>>>>>>>> system does not have
> >> > > > > >>>>>>>>>> unpacked,
> >> > > > > >>>>>>>>>> and you can't get a copy of those files, please
> >> > > > > >>>>>>>>>> let me
> >> > > > > >>>>>>>>>> know.
> >> > > > > >>>>>>>>>> Finally, for those strange creatures wanting to
> >> > > > > >>>>>>>>>> run the
> >> > > > > >>>>>>>>>> compiler
> >> > > > > >>>>>>>>> >from the
> >> > > > > >>>>>>>>>> A2 login or I/O nodes, I believe this build
> >> > > > > >>>>>>>>>> should
> >> > > > > >>>>>>>>>> now
> >> > > > > >>>>>>>>>> work for you again. ;)
> >> > > > > >>>>>>>>>> Thanks again,
> >> > > > > >>>>>>>>>> Hal
> >> > > > > >>>>>>>>>> Hal Finkel
> >> > > > > >>>>>>>>>> Assistant Computational Scientist Leadership
> >> > > > > >>>>>>>>>> Computing
> >> > > > > >>>>>>>>>> Facility Argonne National Laboratory
> >> > _______________________________________________
> >> > > > > >>>>>>>>>> llvm-bgq-discuss mailing list
> >>https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-di
> >> > > > > >>>>>>>>>> scus
> >> > > > > >>>>>>>>>> s
> >> > > > > >>>>>>>>>> scus
> >> > > > > >>>>>>>>>> s
> >> > > > > >>>>>>>>>> scus
> >> > > > > >>>>>>>>>> s
> >>https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-dis
> >> > > > > >>>>>>>>> cuss
> >> > > > > >>>>>>> Hal Finkel
> >> > > > > >>>>>>> Computing
> >>https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discu
> >> > > > > >>>>>>> ss
> >> > > > > >>>>>> Hal Finkel
> >> > > > > >>>>>> Computing
> >> > > > > >>>> Hal Finkel
> >> > > > > >>>> Leadership Computing Facility
> >> > > > > >>> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> >> > > > > >> Thomas Heller
> >> > > > > >> Friedrich-Alexander-Universität Erlangen-Nürnberg
> >> > > > > >> Department
> >> > > > > >> Informatik -
> >> > > > > >> Lehrstuhl Rechnerarchitektur Martensstr. 3
> >> > > > > >> 91058 Erlangen
> >> > > > > >> Tel.: 09131/85-27018
> >> > > > > >> Fax: 09131/85-27912
> >> > > > > >> Email: thomas.heller at cs.fau.de
> >> > > > > Thomas Heller
> >> > > > > Department Informatik - Lehrstuhl Rechnerarchitektur
> >> > > > > Martensstr. 3
> >> > > > > 91058 Erlangen
> >> > > > > Fax: 09131/85-27912
> >> > > > Hal Finkel
> >> > Hal Finkel
> >Hal Finkel
Hal Finkel
More information about the llvm-bgq-discuss
