[Llvm-bgq-discuss] bgclang r205936-20140409 on vesta/mira
Hal Finkel
hfinkel at anl.gov
Mon Apr 14 08:32:24 CDT 2014
----- Original Message -----
> From: "John A. Biddiscombe" <biddisco at cscs.ch>
> To: "Hal Finkel" <hfinkel at anl.gov>
> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Monday, April 14, 2014 8:25:17 AM
> Subject: RE: [Llvm-bgq-discuss] bgclang r205936-20140409 on vesta/mira
> Hal,
> It took me surprisingly long to find out how to fix the paths in the
> script, but the solution (I thought) turned out to be simple
> I changed
> new_floor=/bgsys/drivers/toolchain/${dvr}_base_4.7.2
> to
> new_floor=$BGSYS_FLOOR
> and now it is correctly detecting 4.7.2 toolchain, but although some
> projects are compiling, log4cxx is giving me trouble.
> In file included from
> ../../../src/main/include/log4cxx/helpers/iso8601dateformat.h:21:
> ../../../src/main/include/log4cxx/helpers/simpledateformat.h:57:73:
> error: reference to 'locale' is ambiguous
> SimpleDateFormat(const LogString& pattern, const std::locale*
> locale);
> /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/libc++/include/__locale:48:24:
> note: candidate found by name lookup is 'std::__1::locale'
> class _LIBCPP_TYPE_VIS locale
> ../../../src/main/include/log4cxx/helpers/simpledateformat.h:33:23:
> note: candidate found by name lookup is 'std::locale'
> namespace std { class locale; }
It looks like simpledateformat.h is trying to forward-declare std::locale; I don't think this is a good idea, because it is making an implementation assumption (that turns out not to be true for libc++). Please just include <locale> in simpledateformat.h instead and I predict this problem will go away.
-Hal
> Do you have any idea what might be causing this
> JB
> > -----Original Message-----
> > From: Hal Finkel [mailto:hfinkel at anl.gov]
> > Sent: 11 April 2014 18:37
> > To: Biddiscombe, John A.
> > Cc: llvm-bgq-discuss at lists.alcf.anl.gov; Thomas Heller
> > Subject: Re: [Llvm-bgq-discuss] bgclang r205936-20140409 on
> > vesta/mira
> > > From: "John A. Biddiscombe" < biddisco at cscs.ch >
> > > To: "Hal Finkel" < hfinkel at anl.gov >
> > > Cc: llvm-bgq-discuss at lists.alcf.anl.gov , "Thomas Heller"
> > < thom.heller at gmail.com >
> > > Sent: Friday, April 11, 2014 11:32:47 AM
> > > vesta/mira
> > > Not there. No such file or directory
> > > On 11/04/14 18:24, "Hal Finkel" < hfinkel at anl.gov > wrote:
> > > >/bgsys/drivers/toolchain/V1R2M1_base_4.7.2/gnu-linux-4.7.2
> > > Yes, I see, I misread your line
> > > /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/
> > > I guess I should just do a search/replace in the script.
> > Sure. Also, if you do a "proper update" (so that it also retains
> > the current
> > behavior), and send a patch, I'll be happy to include the
> > functionality in
> > future builds.
> > -Hal
> > > Thanks again
> > > JB
> > Hal Finkel
> > Assistant Computational Scientist
> > Leadership Computing Facility
> > Argonne National Laboratory
Hal Finkel
More information about the llvm-bgq-discuss
