[Llvm-bgq-discuss] more issues from trying bgclang with GROMACS
Mark Abraham
mark.abraham at scilifelab.se
Fri Feb 7 08:29:18 CST 2014
Hi Hal,
AFAICS not the problem, but it's hard for a mere user to find this kind of
stuff out:
[juqueen3 ~ (juq-homedir)] $ ls /bgsys/drivers/
ppcfloor toolchain V1R2M0 V1R2M1
Jeff helpfully tried to sort me out with an ALCF account last year, but the
cryptocard they shipped never worked with the PIN they sent with it, and
the helpdesk insisted on me calling from Sweden to get any help at all, so
I gave up. :-( That was about the time Congress decided to act more like
children than usual, so maybe things were messier than usual! :-)
On Fri, Feb 7, 2014 at 2:27 PM, Hal Finkel <hfinkel at anl.gov> wrote:
> > From: "Mark Abraham" <mark.j.abraham at gmail.com>
> > To: llvm-bgq-discuss at lists.alcf.anl.gov
> > Sent: Friday, February 7, 2014 4:55:24 AM
> > Subject: Re: [Llvm-bgq-discuss] more issues from trying bgclang with
> GROMACS
> > Hi,
> > Unfortunately, the OpenMP runs failed outright (results from
> > reduction over threads were nan, reason unclear), and there was some
> > other issue. That will take some time to dig into, because we don't
> > have a "known good with bgclang" code version with which to compare.
> > I'll get back to this, but it'll be a few weeks, sorry.
> What driver version is the machine running? (there are known issues with
> OpenMP and driver version V1R1M2 (and earlier) -- which I did not think
> anyone was still using, but it seems some folks still are).
> -Hal
> > Thanks again,
> > Mark
> > On Fri, Feb 7, 2014 at 2:23 AM, Mark Abraham <
> > mark.j.abraham at gmail.com > wrote:
> > Oops, I did indeed forget to unpack that RPM. Thanks for the tip!
> > With it, the OpenMP aspect build was flawless. I was able to work
> > around the other bug by compiling those files at -O2 - which is fine
> > for normal GROMACS. Test run in the queue :-)
> > Mark
> > > From: "Mark Abraham" < mark.j.abraham at gmail.com >
> > > Sent: Thursday, February 6, 2014 6:26:55 PM
> > > Subject: [Llvm-bgq-discuss] more issues from trying bgclang with
> > > GROMACS
> > > Hi,
> > > I had another go compiling GROMACS 5.0 beta with bgclang latest RPM
> > > (r200401-20140129). CMake detection of OpenMP support in mpiclang
> > > failed. Detection should just work because using the -fopenmp flag
> > > is a standard way to do it. When I tried a manual compile:
> > > $ ~/progs/bgclang/current/bin/bgclang -fopenmp test.c -o test
> > > /homea/slbio/slbio013/progs/bgclang/r200401-20140129/binutils/bin/ld:
> > > cannot find -liomp5
> > > clang: error: linker command failed with exit code 1 (use -v to see
> > > invocation)
> > > That looks like a lingering Intel-ism?
> > Yes, but that's okay, the libomp package should create the necessary
> > symlink for you. Did you install
> > bgclang-libomp-r200401-20140129-1-1.ppc64.rpm?
> > -Hal
> > > The MPI plus non-OpenMP build seemed to go OK, but a file in our
> > > bundled lapack subset provoked a bug (attached in tarball). That
> > > file was not a problem in ~August 2013.
> > > Thanks again for the effort!
> > > Cheers,
> > > Mark
> > > _______________________________________________
> > > llvm-bgq-discuss mailing list
> > > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> > Hal Finkel
> > Assistant Computational Scientist
> > Leadership Computing Facility
> > Argonne National Laboratory
> Hal Finkel
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20140207/9792bec5/attachment.html>
More information about the llvm-bgq-discuss
