[Llvm-bgq-discuss] Linker error: undefined reference to `vtable for std::nested_exception'
Rob Latham
robl at mcs.anl.gov
Thu Jul 17 11:30:35 CDT 2014
See http://www.alcf.anl.gov/user-guides/bgclang-compiler#faq, which I
myself was just staring at last night:
Linking code compiled with bgclang++ together with code compiled with
bgclang++11 does not work, why?
Code compiled using bgclang++ uses the same libstdc++ standard template
library (STL) implementation as the system-default GNU
powerpc64-bgq-linux-g++ compiler. This provides compatibility with C++
libraries, including some system libraries, compiled with the GNU
toolchain. This STL implementation, however, cannot provide a conforming
C++11 programming environment, and so bgclang++11 uses an up-to-date STL
implementation derived from LLVM's libc++. Unfortunately, this STL
implementation is incompatible with libstdc++, and so linking errors
will result for functions that use STL objects as part of their
signatures (i.e. parameter or return types).
==rob
On 07/17/2014 08:48 AM, Michael Schlottke wrote:
> Hi Hal,
> We tried to install the new version of clang on the BG/Q @ FZ Juelich
> from your rpms, which worked like a breeze (thanks again for your
> effors!). However, with the new installation we are not able to link
> even simple problems against libcxx, as all attempts end with the
> following error:
> /bgsys/local/clang/r209570-20140527/libc++/lib/libc++.a(exception.cpp.o):(.toc+0x0):
> clang: error: linker command failed with exit code 1 (use -v to see
> invocation)
> It happens as soon as we try to compile & link a dummy program that has
> at least one std library include file. If we use bgclang++, the error
> does not occur, but it does when using either -stdlib=libc++ or bgclang++11.
> Do you have any idea what the source of the problem could be? I attached
> a MWE and the output of running bgclang++11 with -v.
> Regards,
> Michael
> P.S.: We had a driver/toolchain upgrade on JUQUEEN and thus our old
> clang installations are not working anymore. Maybe this could be related
> to the problem?
> Forschungszentrum Juelich GmbH
> 52425 Juelich
> Sitz der Gesellschaft: Juelich
> Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
> Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
> Geschaeftsfuehrung: Prof. Dr.-Ing. Wolfgang Marquardt (Vorsitzender),
> Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
> Prof. Dr. Sebastian M. Schmidt
> llvm-bgq-discuss mailing list
> llvm-bgq-discuss at lists.alcf.anl.gov
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
More information about the llvm-bgq-discuss
