[Llvm-bgq-discuss] Linker error: undefined reference to `vtable for std::nested_exception'
Michael Schlottke
m.schlottke at fz-juelich.de
Fri Jul 18 03:23:59 CDT 2014
Hi Hal,
Thanks for checking this out. I installed the last RPMs that we knew
worked before the toolchain upgrade (r201012-20140207), but to no avail.
When trying to compile the same MWE program, we get a compiler
(preprocessor?) error instead, but again it seems to be centered around
exceptions (I've attached the log). Maybe this sheds some more light on
the issues we're having.
Michael
P.S.: As before, the error occurs only when using bgclang++11 or when
manually adding -stdlib=libc++ to bgclang++. Otherwise it compiles &
runs just fine.
On 17.07.2014 19:21, Hal Finkel wrote:
> Hi,
> This error almost always occurs when you pick up the old libstdc++ library instead of the one from the 4.7.2 toolchain. I'll look at your verbose logs later.
> -Hal
>> From: "Sandipan Mohanty" <s.mohanty at fz-juelich.de>
>> To: llvm-bgq-discuss at lists.alcf.anl.gov
>> Sent: Thursday, July 17, 2014 11:53:07 AM
>> Subject: Re: [Llvm-bgq-discuss] Linker error: undefined reference to `vtable for std::nested_exception'
>> Hi!
>> The linker error Michael mentioned also appears for a simple
>> hello world
>> program:
>> #include <iostream>
>> int main()
>> std::cout << "Hello, World!\n";
>> Compiling it with bgclang++ is fine. Compiling with bgclang++11,
>> which also
>> links with libc++, produces the linker error he mentioned about
>> nested_exception. The nested_exception class members are defined
>> inside the
>> exception.cpp file in the libc++ source. But there are lots of macros
>> influencing what sections get compiled. Is the libc++ in the RPM
>> compiled with
>> libsupc++, libcxxrt or libcxxabi as the LIBCXX_CXX_ABI ?
>> /Sandipan
>> On Thursday 17 Jul 2014 11:30:35 Rob Latham wrote:
>>> See http://www.alcf.anl.gov/user-guides/bgclang-compiler#faq, which
>>> I
>>> myself was just staring at last night:
>>> Linking code compiled with bgclang++ together with code compiled
>>> with
>>> bgclang++11 does not work, why?
>>> Code compiled using bgclang++ uses the same libstdc++ standard
>>> template
>>> library (STL) implementation as the system-default GNU
>>> powerpc64-bgq-linux-g++ compiler. This provides compatibility with
>>> C++
>>> libraries, including some system libraries, compiled with the GNU
>>> toolchain. This STL implementation, however, cannot provide a
>>> conforming
>>> C++11 programming environment, and so bgclang++11 uses an
>>> up-to-date STL
>>> implementation derived from LLVM's libc++. Unfortunately, this STL
>>> implementation is incompatible with libstdc++, and so linking
>>> errors
>>> will result for functions that use STL objects as part of their
>>> signatures (i.e. parameter or return types).
>>> ==rob
>>> On 07/17/2014 08:48 AM, Michael Schlottke wrote:
>>>> Hi Hal,
>>>> We tried to install the new version of clang on the BG/Q @ FZ
>>>> Juelich
>>>> from your rpms, which worked like a breeze (thanks again for your
>>>> effors!). However, with the new installation we are not able to
>>>> link
>>>> even simple problems against libcxx, as all attempts end with the
>>>> following error:
>>>> /bgsys/local/clang/r209570-20140527/libc++/lib/libc++.a(exception.cpp.o):(
>>>> .toc+0x0): undefined reference to `vtable for
>>>> clang: error: linker command failed with exit code 1 (use -v to
>>>> see
>>>> invocation)
>>>> It happens as soon as we try to compile & link a dummy program
>>>> that has
>>>> at least one std library include file. If we use bgclang++, the
>>>> error
>>>> does not occur, but it does when using either -stdlib=libc++ or
>>>> bgclang++11.
>>>> Do you have any idea what the source of the problem could be? I
>>>> attached
>>>> a MWE and the output of running bgclang++11 with -v.
>>>> Regards,
>>>> Michael
>>>> P.S.: We had a driver/toolchain upgrade on JUQUEEN and thus our
>>>> old
>>>> clang installations are not working anymore. Maybe this could be
>>>> related
>>>> to the problem?
>>>> ----------------------- Forschungszentrum Juelich GmbH
>>>> 52425 Juelich
>>>> Sitz der Gesellschaft: Juelich
>>>> Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B
>>>> 3498
>>>> Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
>>>> Geschaeftsfuehrung: Prof. Dr.-Ing. Wolfgang Marquardt
>>>> (Vorsitzender),
>>>> Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald
>>>> Bolt,
>>>> Prof. Dr. Sebastian M. Schmidt
>>>> _______________________________________________
>>>> llvm-bgq-discuss mailing list
>>>> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
52425 Juelich
Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
Geschaeftsfuehrung: Prof. Dr.-Ing. Wolfgang Marquardt (Vorsitzender),
Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
Type: text/x-log
Desc: not available
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20140718/74651c7f/attachment.bin>
More information about the llvm-bgq-discuss
