[Llvm-bgq-discuss] Linker error: undefined reference to `vtable for std::nested_exception'
Hal Finkel
hfinkel at anl.gov
Fri Jul 18 17:57:03 CDT 2014
Sandipan,
To solve the actual std::exception error you still need to pick up the libstdc++ libs from the 4.7.2 toolchain. If you look in the wrapper script, it looks for them in some particular places; make sure that matches you system.
-Hal
----- Original Message -----
> From: "Sandipan Mohanty" <s.mohanty at fz-juelich.de>
> To: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Friday, July 18, 2014 5:29:40 PM
> Subject: Re: [Llvm-bgq-discuss] Linker error: undefined reference to `vtable for std::nested_exception'
> Hi Hal, Michael and Roy,
> I changed the variable VLIBSTDCXX from 4.4.6 to 4.4.7 in the
> bgclang
> wrapper in Jülich. Unfortunately, the error persists.
> /Sandipan
> On Friday 18 Jul 2014 17:06:28 Hal Finkel wrote:
> > Roy,
> > Ah, that certainly explains things.
> > Michael, if you edit the variables at the top of the bgclang
> > wrapper script,
> > you'll make things work again.
> > I need to put together a new release soon anyway (upstream 3.5 is
> > almost
> > out...)
> > -Hal
> > > From: "Roy Musselman" <roymuss at us.ibm.com>
> > > To: "Hal Finkel" <hfinkel at anl.gov>
> > > Cc: llvm-bgq-discuss at lists.alcf.anl.gov,
> > > llvm-bgq-discuss-bounces at lists.alcf.anl.gov, "Michael Schlottke"
> > > <m.schlottke at fz-juelich.de>
> > > Sent: Friday, July 18, 2014 5:02:57 PM
> > > to
> > > Hi Hal & Michael,
> > > We installed V1R2M2 here at LLNL. Note that the subdirectory is
> > > 4.4.7
> > > for V1R2M2, not 4.4.6 as it was for V1R2M1.
> > > Roy Musselman
> > > HPC Application Analyst at LLNL
> > > email: roymuss at us.ibm.com
> > > Cell: 507-358-8895, Home: 507-281-9565
> > > Inactive hide details for Hal Finkel ---07/18/2014 12:20:12
> > > PM---Michael, The relevant parts of the log are:Hal Finkel
> > > ---07/18/2014 12:20:12 PM---Michael, The relevant parts of the
> > > log
> > > are:
> > > From: Hal Finkel <hfinkel at anl.gov>
> > > To: Michael Schlottke <m.schlottke at fz-juelich.de>
> > > Date: 07/18/2014 12:20 PM
> > > to
> > > Sent by: llvm-bgq-discuss-bounces at lists.alcf.anl.gov
> > > Michael,
> > > ignoring nonexistent directory
> > > "/bgsys/drivers/V1R2M2/ppc64/gnu-linux/powerpc64-bgq-linux/include/c++/4.4
> > > .6"
> > > .6/powerpc64-bgq-linux"
> > > Where did these files go on your system?
> > > -Hal
> > > > From: "Michael Schlottke" <m.schlottke at fz-juelich.de>
> > > > To: llvm-bgq-discuss at lists.alcf.anl.gov, hfinkel at anl.gov
> > > > Sent: Friday, July 18, 2014 3:23:59 AM
> > > > reference
> > > > Hi Hal,
> > > > Thanks for checking this out. I installed the last RPMs that we
> > > > knew
> > > > worked before the toolchain upgrade (r201012-20140207), but to
> > > > no
> > > > avail.
> > > > When trying to compile the same MWE program, we get a compiler
> > > > (preprocessor?) error instead, but again it seems to be
> > > > centered
> > > > around
> > > > exceptions (I've attached the log). Maybe this sheds some more
> > > > light
> > > > on
> > > > the issues we're having.
> > > > Regards,
> > > > Michael
> > > > P.S.: As before, the error occurs only when using bgclang++11
> > > > or
> > > > when
> > > > manually adding -stdlib=libc++ to bgclang++. Otherwise it
> > > > compiles
> > > > runs just fine.
> > > > On 17.07.2014 19:21, Hal Finkel wrote:
> > > > > Hi,
> > > > > This error almost always occurs when you pick up the old
> > > > > libstdc++
> > > > > library instead of the one from the 4.7.2 toolchain. I'll
> > > > > look at
> > > > > your verbose logs later.
> > > > > -Hal
> > > > >> Sent: Thursday, July 17, 2014 11:53:07 AM
> > > > >> reference
> > > > >> Hi!
> > > > >> The linker error Michael mentioned also appears for a simple
> > > > >> hello world
> > > > >> program:
> > > > >> #include <iostream>
> > > > >> int main()
> > > > >> std::cout << "Hello, World!\n";
> > > > >> Compiling it with bgclang++ is fine. Compiling with
> > > > >> bgclang++11,
> > > > >> which also
> > > > >> links with libc++, produces the linker error he mentioned
> > > > >> about
> > > > >> nested_exception. The nested_exception class members are
> > > > >> defined
> > > > >> inside the
> > > > >> exception.cpp file in the libc++ source. But there are lots
> > > > >> of
> > > > >> macros
> > > > >> influencing what sections get compiled. Is the libc++ in the
> > > > >> RPM
> > > > >> compiled with
> > > > >> libsupc++, libcxxrt or libcxxabi as the LIBCXX_CXX_ABI ?
> > > > >> /Sandipan
> > > > >> On Thursday 17 Jul 2014 11:30:35 Rob Latham wrote:
> > > > >>> See
> > > > >>> http://www.alcf.anl.gov/user-guides/bgclang-compiler#faq ,
> > > > >>> which
> > > > >>> I
> > > > >>> myself was just staring at last night:
> > > > >>> Linking code compiled with bgclang++ together with code
> > > > >>> compiled
> > > > >>> with
> > > > >>> bgclang++11 does not work, why?
> > > > >>> Code compiled using bgclang++ uses the same libstdc++
> > > > >>> standard
> > > > >>> template
> > > > >>> library (STL) implementation as the system-default GNU
> > > > >>> powerpc64-bgq-linux-g++ compiler. This provides
> > > > >>> compatibility
> > > > >>> with
> > > > >>> C++
> > > > >>> libraries, including some system libraries, compiled with
> > > > >>> the
> > > > >>> GNU
> > > > >>> toolchain. This STL implementation, however, cannot provide
> > > > >>> a
> > > > >>> conforming
> > > > >>> C++11 programming environment, and so bgclang++11 uses an
> > > > >>> up-to-date STL
> > > > >>> implementation derived from LLVM's libc++. Unfortunately,
> > > > >>> this
> > > > >>> STL
> > > > >>> implementation is incompatible with libstdc++, and so
> > > > >>> linking
> > > > >>> errors
> > > > >>> will result for functions that use STL objects as part of
> > > > >>> their
> > > > >>> signatures (i.e. parameter or return types).
> > > > >>> ==rob
> > > > >>> On 07/17/2014 08:48 AM, Michael Schlottke wrote:
> > > > >>>> Hi Hal,
> > > > >>>> We tried to install the new version of clang on the BG/Q @
> > > > >>>> FZ
> > > > >>>> Juelich
> > > > >>>> from your rpms, which worked like a breeze (thanks again
> > > > >>>> for
> > > > >>>> your
> > > > >>>> effors!). However, with the new installation we are not
> > > > >>>> able
> > > > >>>> to
> > > > >>>> link
> > > > >>>> even simple problems against libcxx, as all attempts end
> > > > >>>> with
> > > > >>>> the
> > > > >>>> following error:
> > > > >>>> /bgsys/local/clang/r209570-20140527/libc++/lib/libc++.a(exception.c
> > > > >>>> pp.o):(
> > > > >>>> .toc+0x0): undefined reference to `vtable for
> > > > >>>> clang: error: linker command failed with exit code 1 (use
> > > > >>>> -v
> > > > >>>> to
> > > > >>>> see
> > > > >>>> invocation)
> > > > >>>> It happens as soon as we try to compile & link a dummy
> > > > >>>> program
> > > > >>>> that has
> > > > >>>> at least one std library include file. If we use
> > > > >>>> bgclang++,
> > > > >>>> the
> > > > >>>> error
> > > > >>>> does not occur, but it does when using either
> > > > >>>> -stdlib=libc++
> > > > >>>> or
> > > > >>>> bgclang++11.
> > > > >>>> Do you have any idea what the source of the problem could
> > > > >>>> be?
> > > > >>>> I
> > > > >>>> attached
> > > > >>>> a MWE and the output of running bgclang++11 with -v.
> > > > >>>> Regards,
> > > > >>>> Michael
> > > > >>>> P.S.: We had a driver/toolchain upgrade on JUQUEEN and
> > > > >>>> thus
> > > > >>>> our
> > > > >>>> old
> > > > >>>> clang installations are not working anymore. Maybe this
> > > > >>>> could
> > > > >>>> be
> > > > >>>> related
> > > > >>>> to the problem?
> > > > >>>> ----------------------- Forschungszentrum Juelich GmbH
> > > > >>>> 52425 Juelich
> > > > >>>> Sitz der Gesellschaft: Juelich
> > > > >>>> Eingetragen im Handelsregister des Amtsgerichts Dueren Nr.
> > > > >>>> HR
> > > > >>>> B
> > > > >>>> 3498
> > > > >>>> Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen
> > > > >>>> Huthmacher
> > > > >>>> Geschaeftsfuehrung: Prof. Dr.-Ing. Wolfgang Marquardt
> > > > >>>> (Vorsitzender),
> > > > >>>> Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing.
> > > > >>>> Harald
> > > > >>>> Bolt,
> > > > >>>> Prof. Dr. Sebastian M. Schmidt
> > > > >>>> _______________________________________________
> > > > >>>> llvm-bgq-discuss mailing list
> > > > >>>> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> > > > ------------------------- Forschungszentrum Juelich GmbH
> > > > 52425 Juelich
> > > > Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B
> > > > 3498
> > > > Huthmacher
> > > > (Vorsitzender),
> > > > Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald
> > > > Bolt,
> > > Hal Finkel
> > > Assistant Computational Scientist
> > > Leadership Computing Facility
> > > Argonne National Laboratory
> 52425 Juelich
> Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
> Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
> Geschaeftsfuehrung: Prof. Dr.-Ing. Wolfgang Marquardt (Vorsitzender),
> Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
Hal Finkel
More information about the llvm-bgq-discuss
