[Llvm-bgq-discuss] build issues with bgclang on vesta
Sayan Ghosh
sayandeep52 at gmail.com
Thu Jul 31 18:24:17 CDT 2014
Thanks, it works now.
On Thu, Jul 31, 2014 at 5:51 PM, Hal Finkel <hfinkel at anl.gov> wrote:
> Sayan,
> For some reason the V1R2M2 4.7.2 toolchain (which was just installed on
> vesta on Monday) does not provide the libnss_* static libraries that the
> BG/Q libc has traditionally required. For the time being, we'll use the
> V1R2M1 4.7.2 toolchain.
> In short, it should work now. Please re-compile your code.
> -Hal
> > From: "Hal Finkel" <hfinkel at anl.gov>
> > To: "Sayan Ghosh" <sayandeep52 at gmail.com>
> > Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> > Sent: Thursday, July 31, 2014 5:35:39 PM
> > Subject: Re: [Llvm-bgq-discuss] build issues with bgclang on vesta
> > Sayan,
> > Thanks for reporting the problem. Looks like this is related to a new
> > change in the V1R2M2 driver. I'll check it out...
> > -Hal
> > > From: "Sayan Ghosh" <sayandeep52 at gmail.com>
> > > To: llvm-bgq-discuss at lists.alcf.anl.gov
> > > Sent: Thursday, July 31, 2014 5:32:44 PM
> > > Subject: [Llvm-bgq-discuss] build issues with bgclang on vesta
> > > Hi,
> > > I am new to Vesta, and having trouble building anything using
> > > bgclang, upon bgclang -v, I get the following output, which shows a
> > > link error:
> > > [sghosh at vestalac1 build]$ bgclang -v
> > > clang version 3.5.0 (trunk)
> > > Target: powerpc64-bgq-linux
> > > Thread model: posix
> > > Found candidate GCC installation:
> /bgsys/drivers/toolchain/V1R2M2_base_4.7.2/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2
> > > Selected GCC installation:
> > > Candidate multilib: .;@m64
> > > Selected multilib: .;@m64
> > > "/home/projects/llvm/r209570-20140527/binutils/bin/ld"
> > > --hash-style=gnu --no-add-needed --build-id -m elf64ppc -static -o
> > > a.out
> /bgsys/drivers/toolchain/V1R2M2_base_4.7.2/gnu-linux-4.7.2/powerpc64-bgq-linux/lib/crt1.o
> /bgsys/drivers/toolchain/V1R2M2_base_4.7.2/gnu-linux-4.7.2/powerpc64-bgq-linux/lib/crti.o
> /bgsys/drivers/toolchain/V1R2M2_base_4.7.2/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2/crtbeginT.o
> -L/bgsys/drivers/toolchain/V1R2M2_base_4.7.2/gnu-linux-4.7.2/powerpc64-bgq-linux/lib
> > > -L/home/projects/llvm/r209570-20140527/sleef/lib
> -L/bgsys/drivers/toolchain/V1R2M2_base_4.7.2/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2
> -L/bgsys/drivers/toolchain/V1R2M2_base_4.7.2/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2/../../../../lib64
> > > -L/lib/../lib64 -L/usr/lib/../lib64
> -L/bgsys/drivers/toolchain/V1R2M2_base_4.7.2/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2/../../../../powerpc64-bgq-linux/lib
> > > -L/gpfs/vesta-home/projects/llvm/r209570-20140527/bin/../lib -L/lib
> > > -L/usr/lib --as-needed -lsleef --no-as-needed --start-group -lgcc
> > > -lgcc_eh -ldl -lc -lnss_files -lnss_dns -lresolv -lm --end-group
> /bgsys/drivers/toolchain/V1R2M2_base_4.7.2/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2/crtend.o
> /bgsys/drivers/toolchain/V1R2M2_base_4.7.2/gnu-linux-4.7.2/powerpc64-bgq-linux/lib/crtn.o
> > > /home/projects/llvm/r209570-20140527/binutils/bin/ld: cannot find
> > > -lnss_files
> > > -lnss_dns
> > > clang: error: linker command failed with exit code 1 (use -v to see
> > > invocation)
> > > My hello-world program also fails with the same link-time error:
> > > [sghosh at vestalac1 tmp]$ bgclang -o tt tmp.c
> > > -lnss_files
> > > -lnss_dns
> > > invocation)
> > > I am following the instructions given in:
> http://www.alcf.anl.gov/user-guides/bgclang-compiler#using-bgclang-on-vesta,-mira-and-cetus
> > > My .soft file:
> > > +bgqdriver-V1R2M2
> > > +bgqtoolchain-gcc472
> > > +cmake
> > > +mpiwrapper-bgclang
> > > Thanks. --
> > > Regards, Sayan
> > > _______________________________________________
> > > llvm-bgq-discuss mailing list
> > > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> > Hal Finkel
> > Assistant Computational Scientist
> > Leadership Computing Facility
> > Argonne National Laboratory
> Hal Finkel
Sayan
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20140731/5959e57f/attachment-0001.html>
More information about the llvm-bgq-discuss
