[Llvm-bgq-discuss] Implicit memset call
Jeff Hammond
jhammond at anl.gov
Thu Mar 20 11:22:03 CDT 2014
Per http://lists.cs.uiuc.edu/pipermail/llvmdev/2012-May/050112.html,
you might want to try -fno-builtin and/or -ffreestanding.
Jeff
On Thu, Mar 20, 2014 at 11:17 AM, Jeff Hammond <jhammond at anl.gov> wrote:
> As best I can tell, this bug is upstream as well. I see the same
> thing happen on my Mac with Clang 3.4.
> Jeff
> On Thu, Mar 20, 2014 at 11:06 AM, Thomas Gooding <tgooding at us.ibm.com> wrote:
>> Hello,
>> I have some code that implements the memset() routine. It appears that
>> bgclang is getting (too) clever by detecting the setting-loop. Once it
>> detects this, it decides the "real" memset would be more efficient and calls
>> that routine inplace of the setting-loop. Very clever, but not optimal for
>> me (and functionally incorrect since in the real code, it results in a
>> recursive bomb calling memset repeatedly)
>> Is there a way to disable this feature?
>> bgclang -g -O2 t.c
>> #include <stdio.h>
>> #include <stdint.h>
>> char buffer[24];
>> void* my_memset(void* dest, int value, size_t n )
>> printf("memset: dest=%p size=%ld\n", dest, n);
>> uint8_t* d = (uint8_t*)dest;
>> while (n--)
>> *d++ = value; // this while loop replaced with
>> memset() call
>> return dest;
>> int main(int argc, char** argv)
>> my_memset(buffer, 0, sizeof(buffer));
>> printf("done\n");
>> return 0;
>> 00000000010003c0 <.my_memset>:
>> 10003c0: 7c 08 02 a6 mflr r0
>> 10003c4: fb e1 ff f8 std r31,-8(r1)
>> 10003c8: f8 01 00 10 std r0,16(r1)
>> 10003cc: f8 21 ff 61 stdu r1,-160(r1)
>> 1000408: 7b 84 06 20 clrldi r4,r28,56
>> 100040c: 7f c3 f3 78 mr r3,r30
>> 1000410: 7f a5 eb 78 mr r5,r29
>> 1000414: 48 00 d0 7d bl 100d490 <.memset>
>> Tom Gooding
>> Senior Engineer / Blue Gene SW Lead / CAPI
>> tgooding at us.ibm.com 507-253-0747
>> llvm-bgq-discuss mailing list
>> llvm-bgq-discuss at lists.alcf.anl.gov
>> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> Jeff Hammond
> Argonne Leadership Computing Facility
> University of Chicago Computation Institute
> jhammond at anl.gov / jhammond at uchicago.edu / (630) 252-5381
> http://www.linkedin.com/in/jeffhammond
> https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
Jeff Hammond
More information about the llvm-bgq-discuss
