[Llvm-bgq-discuss] clang on BGQ performance
Thomas Gooding
tgooding at us.ibm.com
Tue Mar 25 12:58:36 CDT 2014
bgclang's non-OMP good COPY performance is due to an implicit call to
memcpy(), which is QPX optimized. (see previous thread about built-ins ;)
If it helps, my sampling profiler has this breakdown of the -fopenmp.
thread 0 count= 772 (19.30%) ..omp_microtask.37
thread 0 count= 748 (18.70%) ..omp_microtask.35
thread 0 count= 717 (17.93%) ..omp_microtask.36
thread 0 count= 622 (15.55%) ..omp_microtask.34
thread 0 count= 102 (2.55%) .checkSTREAMresults
thread 0 count= 72 (1.80%) ..omp_microtask.15
thread 0 count= 44 (1.10%) ..omp_microtask.12
runjob --strace 0 shows several calls to gettimeofday, but not much other
kernel activity. So I suspect its spending its time in an OMP runtime
optimization opportunity.
Tom Gooding
Senior Engineer / Blue Gene SW Lead / CAPI
tgooding at us.ibm.com 507-253-0747
|Hal Finkel <hfinkel at anl.gov> |
| To: |
|"John A. Biddiscombe" <biddisco at cscs.ch> |
| Cc: |
|llvm-bgq-discuss at lists.alcf.anl.gov |
| Date: |
|03/25/2014 12:03 PM |
| Subject: |
|Re: [Llvm-bgq-discuss] clang on BGQ performance |
| Sent by: |
|llvm-bgq-discuss-bounces at lists.alcf.anl.gov |
John,
Thanks for looking into this (and providing a useful benchmark)! You'll
find this interesting:
bgclang -O3 -fopenmp with 1 thread:
Function Best Rate MB/s Avg time Min time Max time
Copy: 635.7 0.251708 0.251708 0.251709
Scale: 519.7 0.307855 0.307855 0.307856
Add: 802.0 0.299267 0.299266 0.299267
Triad: 753.4 0.318716 0.318566 0.318735
gcc 4.7.2 -O3 -fopenmp with 1 thread:
Copy: 2067.4 0.077393 0.077392 0.077395
Scale: 1329.4 0.120353 0.120353 0.120354
Add: 1943.5 0.123490 0.123489 0.123490
Triad: 1872.4 0.128179 0.128178 0.128179
gcc without OpenMP is actually slightly worse, go figure ;)
bgclang -O3 with 1 thread (with no -fopenmp)
Copy: 15660.2 0.010296 0.010217 0.010870
Scale: 5523.7 0.028967 0.028966 0.028967
Add: 6283.2 0.038198 0.038197 0.038198
Triad: 6331.9 0.037906 0.037903 0.037920
bgxlc_r -O3 -qsmp=omp with 1 thread:
Copy: 3762.0 0.042535 0.042531 0.042538
Scale: 5083.5 0.031481 0.031474 0.031494
Add: 7394.2 0.032487 0.032458 0.032510
Triad: 7397.6 0.032481 0.032443 0.032499
bgxlc_r -O3 (no -qsmp=omp) with 1 thread:
Copy: 3574.1 0.044768 0.044767 0.044769
Scale: 3301.2 0.048468 0.048467 0.048469
Add: 4233.2 0.056696 0.056694 0.056699
Triad: 4350.1 0.055173 0.055171 0.055177
all of these defined TUNED (just because it puts the kernels into separate
functions). It seems that the OpenMP outlining in Clang/LLVM is seriously
interfering with the ability of the vectorizer and instruction scheduler to
do useful work. I assume that most of this is because of pointer aliasing
information being lost in the OpenMP transformation. We'll need to work on
this! (I'm actually in the middle of working on a new pointer aliasing
framework for LLVM, and I'll be able to use that to solve a lot of these
issues).
-Hal
----- Original Message -----
> From: "John A. Biddiscombe" <biddisco at cscs.ch>
> To: "Hal Finkel" <hfinkel at anl.gov>
> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Tuesday, March 25, 2014 11:44:50 AM
> Subject: RE: [Llvm-bgq-discuss] clang on BGQ performance
> > Can you please provide details on exactly what you did? What
> > compile flags
> > did you use, did you define TUNED?
> edited Makefile to skip the fortran and set bgclang vars
> bbpbgas040:~/bgas/clang/build/stream$ cat Makefile
> CC = bgclang
> CFLAGS = -O3 -fopenmp
> -L/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/omp/lib/
> all: stream_c.exe
> stream_c.exe: stream.c
> $(CC) $(CFLAGS) stream.c -o stream_c.exe
> clean:
> rm -f stream_c.exe *.o
> then just a make. I didn't set any other vars (like TUNED etc)
Hal Finkel
Assistant Computational Scientist
Leadership Computing Facility
Argonne National Laboratory
llvm-bgq-discuss mailing list
https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20140325/6b74148a/attachment-0001.html>
Type: image/gif
Desc: not available
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20140325/6b74148a/attachment-0002.gif>
Type: image/gif
Desc: not available
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20140325/6b74148a/attachment-0003.gif>
More information about the llvm-bgq-discuss
