[Llvm-bgq-discuss] bgclang r220548-20141024 on vesta/mira
Boisvert, Sebastien
boisvert at anl.gov
Sat Nov 1 14:09:04 CDT 2014
> From: llvm-bgq-discuss-bounces at lists.alcf.anl.gov [llvm-bgq-discuss-bounces at lists.alcf.anl.gov] on behalf of Hal Finkel [hfinkel at anl.gov]
> Sent: Saturday, November 01, 2014 2:00 AM
> To: llvm-bgq-discuss at lists.alcf.anl.gov
> Subject: [Llvm-bgq-discuss] bgclang r220548-20141024 on vesta/mira
> Hi everyone,
> I've updated our bgclang install on vesta and mira to r220548-20141024.
> This new build picks up some nice upstream improvements and bug fixes and some local improvements and fixes.
> - support for __attribute__((align_value(n))) and #pragma omp simd aligned(n) for specifying pointer alignments
> - better support for QPX vectorization of math functions with -ffast-math is enabled (also, this build uses the scalar SLEEF functions for exp/exp2/exp10 by default because they're much faster than the libm versions).
> - bgclang++11 includes a work-around for std::locale("") being broken (because libc's newlocale is broken when provided with "") -- hopefully boost.filesystem will work better now.
> - A work-around (via a wrapper header) is provided for spi/include/kernel/process.h so you shouldn't need to worry about the missing __INLINE__ on Kernel_GetJobID in the system header any more.
Thanks for the work-around.
> For those maintaining their own installs, RPMs (and SRPMs) are available on the trac page: https://trac.alcf.anl.gov/projects/llvm-bgq
> Thanks again,
> Hal
> Hal Finkel
> Assistant Computational Scientist
> Leadership Computing Facility
> Argonne National Laboratory
> llvm-bgq-discuss mailing list
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
More information about the llvm-bgq-discuss
