[Llvm-bgq-discuss] bgclang r220548-20141024 on vesta/mira
Christophe Prud'homme
christophe.prudhomme at feelpp.org
Tue Nov 4 23:16:31 CST 2014
Hello
thank you very much for this release !
We use advanced c++11, the latest boost (and boost.filesystem...) and
various other libs.
I have the following problem at link time with this release. We have the
V1R2M2 driver
but not /V1R2M2_base_4.7.2/gnu-linux-4.7.2
/bglocal/fe/pub/Clang/r220548-20141024/r220548-20141024/binutils/bin/ld:
cannot find
/bgsys/drivers/toolchain/V1R2M2_base_4.7.2/gnu-linux-4.7.2/powerpc64-bgq-linux//lib/libc.so.6
cannot find
/bgsys/drivers/toolchain/V1R2M2_base_4.7.2/gnu-linux-4.7.2/powerpc64-bgq-linux//lib/libc_nonshared.a
cannot find
/bgsys/drivers/toolchain/V1R2M2_base_4.7.2/gnu-linux-4.7.2/powerpc64-bgq-linux//lib/ld64.so.1
rather we have
/bgsys/drivers/toolchain/V1R2M2_base/gnu-linux
I guess the proper symlink will do. Do you see any other solution ?
did we miss something ?
Best regards
C.
On Sat, Nov 1, 2014 at 8:00 AM, Hal Finkel <hfinkel at anl.gov> wrote:
> Hi everyone,
> I've updated our bgclang install on vesta and mira to r220548-20141024.
> This new build picks up some nice upstream improvements and bug fixes and
> some local improvements and fixes.
> - support for __attribute__((align_value(n))) and #pragma omp simd
> aligned(n) for specifying pointer alignments
> - better support for QPX vectorization of math functions with -ffast-math
> is enabled (also, this build uses the scalar SLEEF functions for
> exp/exp2/exp10 by default because they're much faster than the libm
> versions).
> - bgclang++11 includes a work-around for std::locale("") being broken
> (because libc's newlocale is broken when provided with "") -- hopefully
> boost.filesystem will work better now.
> - A work-around (via a wrapper header) is provided for
> spi/include/kernel/process.h so you shouldn't need to worry about the
> missing __INLINE__ on Kernel_GetJobID in the system header any more.
> For those maintaining their own installs, RPMs (and SRPMs) are available
> on the trac page: https://trac.alcf.anl.gov/projects/llvm-bgq
> Thanks again,
> Hal
> Hal Finkel
> Assistant Computational Scientist
> Leadership Computing Facility
> Argonne National Laboratory
> llvm-bgq-discuss mailing list
> llvm-bgq-discuss at lists.alcf.anl.gov
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
Feel++ Project Manager
Professor in Applied Mathematics
@ Université Joseph Fourier (Grenoble, France)
@ Université de Strasbourg (France)
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20141105/63c3b507/attachment.html>
More information about the llvm-bgq-discuss
