[Llvm-bgq-discuss] Compiling apps on Cetus with clang
Hal Finkel
hfinkel at anl.gov
Fri Oct 10 14:13:16 CDT 2014
Unfortunately, this is a known problem (and is already part of a Clang-compatibility PMR with IBM).
The problem really is not what is in compiler_support.h, but the fact that the declaration in process.h is missing __INLINE__ (if you'll notice, all of the other declarations have them). What I've done previously is to create a local copy of process.h, add the __INLINE__ and then put that file in my include path ahead of the real one.
I should really create a proper system-wide work-around for this, but I've not yet.
-Hal
----- Original Message -----
> From: "Sebastien Boisvert" <boisvert at anl.gov>
> To: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Friday, October 10, 2014 2:09:35 PM
> Subject: [Llvm-bgq-discuss] Compiling apps on Cetus with clang
> I have set +mpiwrapper-bgclang in my ~/.soft
> Then I ran 'resoft'.
> My build script is:
> [boisvert at cetuslac1 biosal]$ cat
> scripts/IBM_Blue_Gene_Q/build-spate-clang.sh
> #!/bin/bash
> # on Cetus:
> # 1. edit ~/.soft
> # 2. run 'resoft'
> CFLAGS="-I. -g -O3 -DTHORIUM_DEBUG "
> CFLAGS="$CFLAGS -I/soft/libraries/alcf/current/xl/ZLIB/include"
> LDFLAGS="-L/soft/libraries/alcf/current/xl/ZLIB/lib -lm -lz"
> make clean
> make -j 8 CFLAGS="$CFLAGS" LDFLAGS="$LDFLAGS" \
> applications/spate_metagenome_assembler/spate
> I am getting this error:
> Clang 3.6.0
> "clang version 3.6.0 (trunk)"
> /bgsys/drivers/V1R2M2/ppc64/spi/include/kernel/cnk/process_impl.h:132:10:
> error: static declaration of 'Kernel_GetJobID' follows non-static
> declaration
> Obviously, I am not the author of process_impl.h.
> The line 132 is:
> __INLINE__
> uint64_t Kernel_GetJobID()
> return CNK_SPI_SYSCALL_0(GETJOBID);
> The file /bgsys/drivers/V1R2M2/ppc64/spi/include/kernel/process.h
> contains the prototype:
> /*! \brief Returns the JobID of the currently active job
> * \return job identifier
> uint64_t Kernel_GetJobID();
> I am not sure what is the problem. I suppose that it should also be
> __INLINE__ (whatever this is) in process.h.
> I digged a little and __INLINE__ is defined in
> /bgsys/drivers/V1R2M2/ppc64/hwi/include/common/compiler_support.h at
> line 28:
> #ifndef __INLINE__
> #ifdef __llvm__
> #define __INLINE__ static inline
> #else
> #define __INLINE__ extern inline __attribute__((always_inline))
> #endif
> #endif
> So basically this is broken because a function can not be not static
> (in process.h) and static (process_impl.h) at the same time.
> The obvious workaround here is to fix the broken compiler_support.h.
> Is there a (easy) of solving this (without having to re-root the
> whole V1R2M2 tree !) ?
> llvm-bgq-discuss mailing list
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
Hal Finkel
Assistant Computational Scientist
Leadership Computing Facility
Argonne National Laboratory
More information about the llvm-bgq-discuss
