[Llvm-bgq-discuss] Issues with inlining
Schlottke, Michael
m.schlottke at fz-juelich.de
Mon Feb 23 08:50:01 CST 2015
Dear Clang/BGQ folks,
We encounter a problem with certain parts of our C++ code when using higher-level optimizations (-On with n>1) with clang on JUQUEEN. I was able to boil down the problem to being apparently linked to the “-inline” optimization pass. When I compile with “-O3” or “-O2” and also use the “-fno-inline” option afterwards, execution works as expected.
The problem only seems to occur on the BG/Q machine as we use the same flags everywhere and it does work on e.g. our institute’s cluster. Therefore my questions are
a) Have you encountered a similar problem on BG/Q? If yes, how did you manage to resolve it?
b) What would be the best way to identify and fix the offending lines in our code (assuming that it can be fixed/reduced to a handful of locations)?
Thanks a lot!
Michael
P.S.: Since I have a good idea in which file the error is located, I tried to fix the location by just specifying
#pragma clang optimize off
at the beginning of a source file. This, however, led to a compiler crash (see http://llvm.org/bugs/show_bug.cgi?id=22664), so I could not investigate this issue further.
Michael Schlottke
SimLab Highly Scalable Fluids & Solids Engineering
Jülich Supercomputing Centre (JSC)
Forschungszentrum Jülich GmbH
52425 Jülich
Germany
Phone: +49 (2461) 61 2326
Mail: m.schlottke at fz-juelich.de<mailto:m.schlottke at fz-juelich.de>
Web: http://www.fz-juelich.de/jsc
Forschungszentrum Juelich GmbH
52425 Juelich
Sitz der Gesellschaft: Juelich
Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
Geschaeftsfuehrung: Prof. Dr.-Ing. Wolfgang Marquardt (Vorsitzender),
Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
Prof. Dr. Sebastian M. Schmidt
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20150223/d997eba7/attachment.html>
More information about the llvm-bgq-discuss
