[Llvm-bgq-discuss] New bgclang nighty builds (and other updates)
Schlottke, Michael
m.schlottke at fz-juelich.de
Fri Mar 20 05:44:27 CDT 2015
Hi everyone,
First of all, thanks a lot Hal, for the continued development of bclang and the maintenance of the easy-to-install RPMs. Unfortunately, linking does not seem to work with r232720-20150319 and our code on JUQEEN:
Linking CXX executable zfs
/bgsys/local/clang/r232720-20150319/r232720-20150319/libc++/lib/libc++.a(exception.cpp.o):(.toc+0x0): undefined reference to `vtable for std::nested_exception'
/bgsys/local/clang/r232720-20150319/r232720-20150319/binutils/bin/ld: /bgsys/drivers/V1R2M2/ppc64/gnu-linux/powerpc64-bgq-linux/lib/libc.a(clone.o): In function `__clone':
(.text+0x98): call to `_exit' lacks nop, can't restore toc; recompile with -fPIC/bgsys/local/clang/r232720-20150319/r232720-20150319/binutils/bin/ld: final link failed: Bad value
clang: error: linker command failed with exit code 1 (use -v to see invocation)
Any idea what the source of the problem could be? The only change we made is to switch from r220548-20141024 to the current nightly build.
Michael
P.S.: At JSC we use a set of install scripts to download and install the newest bgclang version. I finally got around to putting them on GitHub, so if anyone is interested, have a look at https://github.com/sloede/install-bgq. Please note that while the scripts should work on any BG/Q installation, they are only tested on JUQUEEN so far.
Michael Schlottke
SimLab Highly Scalable Fluids & Solids Engineering
Jülich Supercomputing Centre (JSC)
Forschungszentrum Jülich GmbH
52425 Jülich
Germany
Phone: +49 (2461) 61 2326
Mail: m.schlottke at fz-juelich.de<mailto:m.schlottke at fz-juelich.de>
Web: http://www.fz-juelich.de/jsc
On 20 Mar 2015, at 00:15 , Hal Finkel <hfinkel at anl.gov<mailto:hfinkel at anl.gov>> wrote:
Hello everyone,
First, let me apologize to everyone, this is a few months late... but, hopefully, this will never be a problem again...
I now have a system setup which automatically pulls in upstream changes and tries to merge those with the bgclang-specific patches, and then builds the resulting suite of bgclang RPMs. When this succeeds, the RPMs should be posted automatically to:
http://www.mcs.anl.gov/~hfinkel/bgclang/
(note that installing a build from here now also requires both the 'stage1' and 'stage2' RPMs as well)
The first such nightly build, r232720-20150319, has been posted to that page.
And, for the curious, the local repositories used for version control are now mirrored to github:
https://github.com/hfinkel/clang-bgq
https://github.com/hfinkel/llvm-bgq
https://github.com/hfinkel/bgclang-aux
https://github.com/hfinkel/compiler-rt-bgq
https://github.com/hfinkel/libcxx-bgq
https://github.com/hfinkel/openmp-bgq
https://github.com/hfinkel/sleef-bgq
Compared to the latest "released" version (r220548-20141024), the most-recent nightly build does show some performance regressions, and there are a few things I've not even tested yet (LTO, ASan, etc.), but it also contains a number of bug fixes and improvements, so feel free to test on your applications.
One particular noteworthy improvement is that our OpenMP runtime library now has affinity support enabled. This means that all of the OpenMP 4 affinity features should work, and also that the default thread<->core bindings are now sensible.
The bgclang wrapper script no longer disables 'fast-isel' instruction selection at -O0, so your debug builds should now be faster too. Also, the automated vectorization of math functions using our SLEEF library adaptation is controlled using the new -fveclib flag (so the wrapper script contains -fveclib=SLEEF, and you can add -fveclib=none to turn it off if desired for whatever reason).
Also, the core QPX support has been contributed upstream (although not yet the Clang-level intrinsics support); so if you're using LLVM as a library, and want to just build from upstream sources instead of depending on the bgclang builds, that is now possible.
Thanks again everyone, and please let me know if you experience any difficulties,
Hal
Hal Finkel
Assistant Computational Scientist
Leadership Computing Facility
Argonne National Laboratory
llvm-bgq-discuss mailing list
llvm-bgq-discuss at lists.alcf.anl.gov<mailto:llvm-bgq-discuss at lists.alcf.anl.gov>
https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
Forschungszentrum Juelich GmbH
52425 Juelich
Sitz der Gesellschaft: Juelich
Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
Geschaeftsfuehrung: Prof. Dr.-Ing. Wolfgang Marquardt (Vorsitzender),
Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
Prof. Dr. Sebastian M. Schmidt
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20150320/1bbdb0aa/attachment-0001.html>
More information about the llvm-bgq-discuss
