[Llvm-bgq-discuss] New bgclang nighty builds (and other updates)
Mark Abraham
mark.j.abraham at gmail.com
Sun May 10 09:04:50 CDT 2015
Bump. Erik Lindahl has also observed this on bgclang on JUQUEEN. Is it
helpful if I produce a small piece of code that reproduces some of the
issues on bgclang 3.6?
On Wed, Mar 25, 2015 at 4:16 PM Mark Abraham <mark.j.abraham at gmail.com>
wrote:
> On Tue, Mar 24, 2015 at 7:29 PM, Hal Finkel <hfinkel at anl.gov> wrote:
>> ----- Original Message -----
>> > From: "Mark Abraham" <mark.j.abraham at gmail.com>
>> > To: "Hal Finkel" <hfinkel at anl.gov>
>> > Cc: llvm-bgq-discuss at lists.alcf.anl.gov
>> > Sent: Tuesday, March 24, 2015 12:35:20 PM
>> > Subject: Re: [Llvm-bgq-discuss] New bgclang nighty builds (and other
>> updates)
>> > Hi Hal,
>> > Thanks very much for the update & effort.
>> You're very welcome.
>> > I tried out the default bgclang 3.6.0 on vesta, but found a bunch of
>> > the GROMACS SIMD-layer unit tests failing. These need correct QPX
>> > vector intrinsics available. From memory, things worked fine with
>> > bgclang in ~August last year, but I no longer have those results. Is
>> > there a simple way I can compile on vesta with older bgclang to see
>> > where a problem might lie? Otherwise / depending what I learn, I'll
>> > break out a debugger.
>> The old builds are still all installed. Just use the MPI wrappers from:
>> /home/projects/llvm/<whatever>/mpi/bgclang/bin -- I don't know exactly
>> which build you were using in August of last year, r209570-20140527 maybe?
> Yes, that was it, looking at some cruft in my former build script. In any
> case, the latest GROMACS SIMD single-precision unit tests pass on that old
> compiler version (3.5.0), and many of them fail in a release build on the
> default 3.6.0 bgclang on vesta. For some of the cases, it looks like some
> junk memory gets loaded, somehow. A few tests pass, but no theme for
> passing or failing tests leaps out at me. Double precision unit tests are
> OK, though.
> Naturally, in debug mode most of the tests pass. However, the two I looked
> at in ddt were fine up until they called vec_extract(x, 0) e.g. on lines
> https://github.com/gromacs/gromacs/blob/master/src/gromacs/simd/impl_ibm_qpx/impl_ibm_qpx.h#L315
> (where a SIMD vector of 1 2 3 1 was summed to 3, rather than 7) and
> https://github.com/gromacs/gromacs/blob/master/src/gromacs/simd/impl_ibm_qpx/impl_ibm_qpx.h#L462
> (where a SIMD vector dot product of the first 3 lanes returns a garbage
> answer). So maybe that is a productive lead?
> I couldn't inspect the disassembly in ddt, so I'm not sure where we can
> take this from here, Hal. Tarball of test results attached.
> Thanks,
> Mark
>> -Hal
>> > Thanks,
>> > Mark
>> > On Fri, Mar 20, 2015 at 12:15 AM, Hal Finkel < hfinkel at anl.gov >
>> > wrote:
>> > Hello everyone,
>> > First, let me apologize to everyone, this is a few months late...
>> > but, hopefully, this will never be a problem again...
>> > I now have a system setup which automatically pulls in upstream
>> > changes and tries to merge those with the bgclang-specific patches,
>> > and then builds the resulting suite of bgclang RPMs. When this
>> > succeeds, the RPMs should be posted automatically to:
>> > http://www.mcs.anl.gov/~hfinkel/bgclang/
>> > (note that installing a build from here now also requires both the
>> > 'stage1' and 'stage2' RPMs as well)
>> > The first such nightly build, r232720-20150319, has been posted to
>> > that page.
>> > And, for the curious, the local repositories used for version control
>> > are now mirrored to github:
>> > https://github.com/hfinkel/clang-bgq
>> > https://github.com/hfinkel/llvm-bgq
>> > https://github.com/hfinkel/bgclang-aux
>> > https://github.com/hfinkel/compiler-rt-bgq
>> > https://github.com/hfinkel/libcxx-bgq
>> > https://github.com/hfinkel/openmp-bgq
>> > https://github.com/hfinkel/sleef-bgq
>> > Compared to the latest "released" version (r220548-20141024), the
>> > most-recent nightly build does show some performance regressions,
>> > and there are a few things I've not even tested yet (LTO, ASan,
>> > etc.), but it also contains a number of bug fixes and improvements,
>> > so feel free to test on your applications.
>> > One particular noteworthy improvement is that our OpenMP runtime
>> > library now has affinity support enabled. This means that all of the
>> > OpenMP 4 affinity features should work, and also that the default
>> > thread<->core bindings are now sensible.
>> > The bgclang wrapper script no longer disables 'fast-isel' instruction
>> > selection at -O0, so your debug builds should now be faster too.
>> > Also, the automated vectorization of math functions using our SLEEF
>> > library adaptation is controlled using the new -fveclib flag (so the
>> > wrapper script contains -fveclib=SLEEF, and you can add
>> > -fveclib=none to turn it off if desired for whatever reason).
>> > Also, the core QPX support has been contributed upstream (although
>> > not yet the Clang-level intrinsics support); so if you're using LLVM
>> > as a library, and want to just build from upstream sources instead
>> > of depending on the bgclang builds, that is now possible.
>> > Thanks again everyone, and please let me know if you experience any
>> > difficulties,
>> > Hal
>> > Hal Finkel
>> > Assistant Computational Scientist
>> > Leadership Computing Facility
>> > Argonne National Laboratory
>> > _______________________________________________
>> > llvm-bgq-discuss mailing list
>> > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
>> Hal Finkel
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20150510/54efa1a8/attachment.html>
More information about the llvm-bgq-discuss
