[Llvm-bgq-discuss] mpic++11 Runtime Error on Cetus
Hal Finkel
hfinkel at anl.gov
Sun Aug 14 13:07:48 CDT 2016
----- Original Message -----
> From: "Michael Collins" <mikeliamcollins at gmail.com>
> To: "Hal Finkel" <hfinkel at anl.gov>
> Cc: llvm-bgq-discuss at lists.alcf.anl.gov, "Patrick E Gartung" <gartung at fnal.gov>
> Sent: Sunday, August 14, 2016 12:59:18 PM
> Subject: Re: [Llvm-bgq-discuss] mpic++11 Runtime Error on Cetus
> If I remember correctly, I had to manually add to LD_LIBRARY_PATH.
Understood. This shouldn't be necessary, however. Are you linking with bgclang, or one of its MPI wrapper scripts?
I'm worried that something you're doing (or whatever build system you're using is doing) is confusing the wrapper script so that it does not add the appropriate linker options -- in this case, I'd like to improve the wrapper script so it does not have this problem.
Thanks again,
Hal
> On Sun, Aug 14, 2016 at 1:51 PM, Hal Finkel < hfinkel at anl.gov >
> wrote:
> Hi Michael,
> How are you linking? The underlying bgclang wrapper script should add
> the necessary directories
> (/bgsys/drivers/ppcfloor/gnu-linux-4.7.2/powerpc64-bgq-linux/lib in
> this case) to your rpath so everything functions correctly.
> -Hal
> > From: "Michael Collins" < mikeliamcollins at gmail.com >
> > To: "Patrick E Gartung" < gartung at fnal.gov >
> > Sent: Monday, July 18, 2016 10:32:14 PM
> > Well, it took most of the day, but I finally found a libstdc++.so
> > that works. The path is as follows:
> > /bgsys/drivers/V1R2M1/ppc64/toolchain-4.7.2/gnu/build-powerpc64-bgq-linux/gcc-4.7.2-build/powerpc64-bgq-linux/libstdc++-v3/src/.libs/libstdc++.so.6
> > Now, the program runs exactly as intended. Thanks so much for the
> > help, Patrick.
> > On Mon, Jul 18, 2016 at 1:25 PM, Patrick E Gartung <
> > gartung at fnal.gov
> > > wrote:
> > Probably this path or something similar
> > /bgsys/drivers/toolchain/V1R2M4_base_4.7.2/gnu-linux-4.7.2/powerpc64-bgq-linux/lib/
> > From: Michael Collins < mikeliamcollins at gmail.com >
> > Date: Monday, July 18, 2016 at 1:11 PM
> > To: Patrick Gartung < gartung at fnal.gov >
> > Cc: " llvm-bgq-discuss at lists.alcf.anl.gov " <
> > llvm-bgq-discuss at lists.alcf.anl.gov >
> > OK, I'll dig around a bit and see if I can find the libstdc++.so I
> > need.
> > On Mon, Jul 18, 2016 at 1:02 PM, Patrick E Gartung <
> > gartung at fnal.gov
> > > wrote:
> > My solution only worked because I compiled with gcc4.8.4 in the
> > mpich_cpp wrapper. I think bgclang is compiled against a different
> > libstdc++.so. This may be the cause of the segfault. You will have
> > to determine the correct LD_LIBRARY_PATH to use with bgclang.
> > Date: Monday, July 18, 2016 at 12:57 PM
> > That seems to have done the trick. My program's segfault-ing, but
> > at
> > least that means the library was loaded.
> > On Mon, Jul 18, 2016 at 12:22 PM, Michael Collins <
> > mikeliamcollins at gmail.com > wrote:
> > Thanks, Patrick. I'll give it a try and report back.
> > On Mon, Jul 18, 2016 at 12:20 PM, Patrick E Gartung <
> > gartung at fnal.gov > wrote:
> > Hi Michael
> > I had the same problem on vesta. I had to add the envs option with
> > LD_LIBRARY_PATH to the qsub command
> > qsub -n 2 --mode c1 -t 120 --env
> > LD_LIBRARY_PATH=/soft/compilers/gcc/4.8.4/lib/gcc/powerpc64-bgq-linux/4.8.4/:/soft/compilers/gcc/4.8.4/lib/gcc/:/soft/compilers/gcc/4.8.4/lib/gcc/powerpc64-bgq-linux/4.8.4/../../../../powerpc64-bgq-linux/lib/:$LD_LIBRARY_PATH
> > From: < llvm-bgq-discuss-bounces at lists.alcf.anl.gov > on behalf of
> > Date: Monday, July 18, 2016 at 12:14 PM
> > To: " llvm-bgq-discuss at lists.alcf.anl.gov " <
> > Subject: [Llvm-bgq-discuss] mpic++11 Runtime Error on Cetus
> > Hello, all.
> > I'm having some trouble running my Swift/T project on Cetus. I'm
> > compiling a shared library with mpic++11 under the
> > mpiwrapper-bclang-mpi3 wrapper, and my program is dynamically
> > linked
> > to it. At runtime, I'm getting the following error when my program
> > tries to load the shared library:
> > stderr[1]: couldn't load file
> > "/home/mlcoll/src/eq-c/tests/genmax/EQC/libeqc.so":
> > /lib64/bgq/libstdc++.so.6: version `CXXABI_1.3.5' not found
> > (required by
> > /soft/compilers/bgclang/r266865-stable/libc++/lib/libc++.so.1)
> > Any ideas on how to remedy this?
> > Thanks,
> > Mike Collins
> > _______________________________________________
> > llvm-bgq-discuss mailing list
> > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> Hal Finkel
> Assistant Computational Scientist
> Leadership Computing Facility
> Argonne National Laboratory
Hal Finkel
More information about the llvm-bgq-discuss
