[Llvm-bgq-discuss] Does bgclang++11 implement thread_local
Hal Finkel
hfinkel at anl.gov
Thu Jul 14 21:01:14 CDT 2016
----- Original Message -----
> From: "Patrick E Gartung" <gartung at fnal.gov>
> To: "Hal Finkel" <hfinkel at anl.gov>
> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Thursday, July 14, 2016 8:53:17 PM
> Subject: Re: [Llvm-bgq-discuss] Does bgclang++11 implement thread_local
> Hi Hal,
> Can you add libc++abi to the bgclang build? It is supposed to provide
> thread local for clang.
> http://libcxxabi.llvm.org/
Not directly (integration here is tricky because of the need to support statically linking against g++-compiled code - like the BG/Q PAMI implementation), however, I plan to try extracting the implementation from there if practical.
> As you can see from the link line I also tried to use libsupc++ for
> this.
Yep; the system libraries on the BG/Q are old. That's why bgclang has to supplement in many circumstances.
Thanks again,
Hal
> Patrick
> On 7/14/16, 8:28 PM, "Hal Finkel" <hfinkel at anl.gov> wrote:
> >Hi Patrick,
> >Thanks for the report. I suspect this is another case where
> >bgclang++11 needs to supplement the base system libraries; I'll
> >need to see whether that is possible. thread_local should work on
> >plain data types; I suspect this problem is tied to the need to
> >call a destructor on this variable when the thread terminates.
> > -Hal
> >> To: llvm-bgq-discuss at lists.alcf.anl.gov
> >> Sent: Tuesday, July 12, 2016 11:25:54 PM
> >> Subject: [Llvm-bgq-discuss] Does bgclang++11 implement
> >> thread_local
> >> Hi
> >> I am trying to link code that uses thread_local and I get this
> >> error:
> >> /soft/compilers/bgclang/nightly/wbin/bgclang++11 -g -fPIC
> >> -fno-vectorize -fno-slp-vectorize -std=c++11 -std=c++14 -dynamic
> >> -lsupc++ CMakeFiles/TBBDemo.dir/main.cpp.o -o
> >> ../BuildProducts/bin/TBBDemo -rdynamic
> >> ../BuildProducts/lib64/libTBBFrameworkCore.a
> >> ../BuildProducts/lib64/libTBBTestModules.so
> >> /home/gartung/tbb44_20160526oss/build/linux_bg_clang_cc4.4.7_libc2.12_kernel2.6.32_release/libtbbmalloc.a
> >> /home/gartung/tbb44_20160526oss/build/linux_bg_clang_cc4.4.7_libc2.12_kernel2.6.32_release/libtbb.a
> >> -Wl,-rpath,/home/gartung/build/BuildProducts/lib64:
> >> ../BuildProducts/lib64/libTBBFrameworkCore.a(ModuleThreadStack.cpp.o):
> >> In function `demo::ModuleThreadStack::privateStack()':
> >> /home/gartung/toy-mt-framework/TBBProcessingDemo/TBBFrameworkCore/ModuleThreadStack.cpp:21:
> >> undefined reference to `__cxa_thread_atexit’
> >> This is line 21 of ModuleThreadStack.cpp
> >> thread_local std::vector<TransitionModuleID> s_stack;
> >> Does bgclang++11 implement thread_local?
> >> Patrick Gartung
> >> _______________________________________________
> >> llvm-bgq-discuss mailing list
> >> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> >Hal Finkel
> >Assistant Computational Scientist
> >Leadership Computing Facility
> >Argonne National Laboratory
Hal Finkel
More information about the llvm-bgq-discuss
