[Llvm-bgq-discuss] Details behind MPI wrapper for bgclang++
Jeff Hammond
jeff.science at gmail.com
Fri Mar 1 15:43:04 CST 2013
I can't think of a PAMI issue here but I have no experience with
dynamic linking on BGQ.
Sent from my iPhone
On Mar 1, 2013, at 4:39 PM, Hal Finkel <hfinkel at anl.gov> wrote:
>> From: "Jack Poulson" <jack.poulson at gmail.com>
>> To: "Hal Finkel" <hfinkel at anl.gov>
>> Cc: "Jeff Hammond" <jhammond at alcf.anl.gov>, llvm-bgq-discuss at lists.alcf.anl.gov
>> Sent: Friday, March 1, 2013 3:07:17 PM
>> Subject: Re: [Llvm-bgq-discuss] Details behind MPI wrapper for bgclang++
>> On Fri, Mar 1, 2013 at 1:03 PM, Jack Poulson < jack.poulson at gmail.com
>>> wrote:
>> On Fri, Mar 1, 2013 at 12:43 PM, Hal Finkel < hfinkel at anl.gov >
>> wrote:
>> The lightweight core files are really text files, I looked at the
>> line:
>> While executing instruction at..........0x000000000100c7c4
>> Then I ran powerpc64-bgq-linux-objdump -C -d Backproj-2d and looked
>> at the assembly around address 100c7c4 (if you search for it in the
>> file, note that objdump may omit the leading 0s in the address).
>> Thanks!
>> Can you try compiling/linking with
>> /home/projects/llvm/r175919-20130222/bin/bgclang++ instead of the
>> default one; this is a newer build and I'd like to see if it still
>> has whatever bug is yielding this miscompile.
>> Strangely enough, my executable ran correctly with the new version of
>> LLVM (and passed my accuracy tests). I'm rerunning it again right
>> now to help rule out whether or not that was a fluke.
>> Any ideas as to what might have been the major change in the new
>> release?
>> Sigh. It was a fluke.
> Hrmm... this being something that sometimes works is interesting. Are there any sources of non-determinism here? [I suppose that running on different partitions could cause PAMI to malloc memory differently; Jeff?]
>> Perhaps we should take this offline to avoid spamming everyone else
>> on the list? I will try linking statically next.
> Let's see if static linking "fixes" it; the list would certainly like to know that ;)
> -Hal
>> Jack
More information about the llvm-bgq-discuss
