[Llvm-bgq-discuss] Details behind MPI wrapper for bgclang++
Jeff Hammond
jeff.science at gmail.com
Fri Mar 1 15:50:01 CST 2013
Should be deterministic. I've tested that before (a year ago maybe)
because of symmetric heap implementations. However, that's with static
linkage.
Sent from my iPhone
On Mar 1, 2013, at 4:47 PM, Hal Finkel <hfinkel at anl.gov> wrote:
>> From: "Jeff Hammond" <jeff.science at gmail.com>
>> To: "Hal Finkel" <hfinkel at anl.gov>
>> Cc: "Jack Poulson" <jack.poulson at gmail.com>, "Jeff Hammond" <jhammond at alcf.anl.gov>,
>> llvm-bgq-discuss at lists.alcf.anl.gov
>> Sent: Friday, March 1, 2013 3:43:04 PM
>> Subject: Re: [Llvm-bgq-discuss] Details behind MPI wrapper for bgclang++
>> I can't think of a PAMI issue here but I have no experience with
>> dynamic linking on BGQ.
> I was just wondering how reproducible addresses returned from malloc() are when running the same problem.
> -Hal
>> Sent from my iPhone
>>>> From: "Jack Poulson" <jack.poulson at gmail.com>
>>>> Cc: "Jeff Hammond" <jhammond at alcf.anl.gov>,
>>>> Sent: Friday, March 1, 2013 3:07:17 PM
>>>> bgclang++
>>>> On Fri, Mar 1, 2013 at 1:03 PM, Jack Poulson <
>>>>> wrote:
>>>> On Fri, Mar 1, 2013 at 12:43 PM, Hal Finkel < hfinkel at anl.gov >
>>>> wrote:
>>>> The lightweight core files are really text files, I looked at the
>>>> line:
>>>> While executing instruction at..........0x000000000100c7c4
>>>> Then I ran powerpc64-bgq-linux-objdump -C -d Backproj-2d and
>>>> looked
>>>> at the assembly around address 100c7c4 (if you search for it in
>>>> the
>>>> file, note that objdump may omit the leading 0s in the address).
>>>> Thanks!
>>>> Can you try compiling/linking with
>>>> /home/projects/llvm/r175919-20130222/bin/bgclang++ instead of the
>>>> default one; this is a newer build and I'd like to see if it still
>>>> has whatever bug is yielding this miscompile.
>>>> Strangely enough, my executable ran correctly with the new version
>>>> of
>>>> LLVM (and passed my accuracy tests). I'm rerunning it again right
>>>> now to help rule out whether or not that was a fluke.
>>>> Any ideas as to what might have been the major change in the new
>>>> release?
>>>> Sigh. It was a fluke.
>>> Hrmm... this being something that sometimes works is interesting.
>>> Are there any sources of non-determinism here? [I suppose that
>>> running on different partitions could cause PAMI to malloc memory
>>> differently; Jeff?]
>>>> Perhaps we should take this offline to avoid spamming everyone
>>>> else
>>>> on the list? I will try linking statically next.
>>> Let's see if static linking "fixes" it; the list would certainly
>>> like to know that ;)
>>> -Hal
>>>> Jack
More information about the llvm-bgq-discuss
