[Llvm-bgq-discuss] Details behind MPI wrapper for bgclang++
Jack Poulson
jack.poulson at gmail.com
Fri Mar 1 17:18:43 CST 2013
On Fri, Mar 1, 2013 at 1:57 PM, Hal Finkel <hfinkel at anl.gov> wrote:
> > From: "Jeff Hammond" <jeff.science at gmail.com>
> > To: "Hal Finkel" <hfinkel at anl.gov>
> > Cc: "Jack Poulson" <jack.poulson at gmail.com>, "Jeff Hammond" <
> jhammond at alcf.anl.gov>,
> > llvm-bgq-discuss at lists.alcf.anl.gov
> > Sent: Friday, March 1, 2013 3:50:01 PM
> > Subject: Re: [Llvm-bgq-discuss] Details behind MPI wrapper for bgclang++
> > Should be deterministic. I've tested that before (a year ago maybe)
> > because of symmetric heap implementations. However, that's with
> > static
> > linkage.
> For some reason I thought that he was linking dynamically, but that may
> not have been the case (at some point he deleted the executable, but before
> he did I ran ldd on it and it did not say that it was dynamically linked).
> Also, the bgclang wrapper script links statically by default.
> Jack, is the problem itself deterministic?
> -Hal
Sorry, I had a meeting that I had to run off to and am back now. The
problem is only non-deterministic because I am seeding from
std::random_device. I could use a fixed unsigned integer if you would like.
I then randomly instantiate a large number of sources throughout the my 2D
domain and then apply the adjoint of a Radon transform on them
(backprojection).
I will happily try the flags you mentioned. Unfortunately, when I switched
to using static linkage, I ran into a rather strange compilation problem:
[ 9%] Building CXX object
CMakeFiles/Backproj-2d.dir/test/transform/Backproj-2d.cpp.o
/home/projects/llvm/r175919-20130222/bin/bgclang++ -Wall -std=c++11
-static -o CMakeFiles/Backproj-2d.dir/test/transform/Backproj-2d.cpp.o -c
/home/poulson/dist-butterfly/test/transform/Backproj-2d.cpp
/home/poulson/dist-butterfly/test/transform/Backproj-2d.cpp:8:10: fatal
error:
'dist-butterfly.hpp' file not found
#include "dist-butterfly.hpp"
1 error generated.
Assembler messages:
Error: can't open /tmp/Backproj-2d-u4LbNL.s for reading: No such file or
directory
clang: error: assembler command failed with exit code 1 (use -v to see
invocation)
make[2]: *** [CMakeFiles/Backproj-2d.dir/test/transform/Backproj-2d.cpp.o]
Error 1
make[2]: Leaving directory
`/gpfs/vesta-home/poulson/dist-butterfly/build/clang'
make[1]: *** [CMakeFiles/Backproj-2d.dir/all] Error 2
make[1]: Leaving directory
make: *** [all] Error 2
Have any of you ever seen this type of issue before? It looks like invalid
temporary files are being created. I'm not sure whether this is due to
clang or CMake...(though I have good money on which one Jeff will choose!)
Jack
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20130301/9a7f59cb/attachment.html>
More information about the llvm-bgq-discuss
