[hpct] Summary of the issues: Sept 4, 2008
Vitali A. Morozov
morozov at anl.gov
Thu Sep 4 09:36:58 CDT 2008
Hello, Sophia;
3) Yes, I understood that from Christoph's message.
4) the source is in current directory. The message comes: "Cannot
generate the binary analysis file!". Opening the sources from File->Open
Sources does not locate the calls from the viz files, and therefore
impractical.
5) I do not use MP profiler.
with best regards,
Vitali
Hui-fang Wen wrote:
> 3) What is IHPCT_BASE env. variable? When I should use it?
> Answer: It is recommended to set up the IHPCT_BASE
> environment variable. It may be required for some of the
> components in the toolkit. It is safe to always set this
> variable first. Please refer to the env_csh file in the
> hpct installed directory. For example, if you install HPCT
> at /usr/local/ihpct_2.1, the IHPCT_BASE env. variable
> should be set to this installed path.
> 4) peekperf does not show sources for Fortran program.
> Answer: peekperf will try to open the sources. If peekperf
> cannot find the files in the current working directory, it
> should pop up a dialog to ask where the top-level source
> code directory is. If peekperf still fails to locate, you
> can always use File->Open Sources to open the files.
> 5) Fortran instrumented program generates "Error getting
> the executable name, line number information will not be
> available" message.
> Answer: Did you use the mp profiler? The MP profiler
> should be able to get the executable name. If not, there
> may be some problem here.
> Regards,
> Sophia
> Inactive hide details for "Vitali A. Morozov" ---09/03/2008 05:24:08
> PM---Hi Guojing;"Vitali A. Morozov" ---09/03/2008 05:24:08 PM---Hi
> Guojing;
> From:
> "Vitali A. Morozov" <morozov at anl.gov>
> To:
> Guojing Cong/Watson/IBM at IBMUS
> Cc:
> HPCT Mailing list <hpct at alcf.anl.gov>
> Date:
> 09/03/2008 05:24 PM
> Subject:
> Re: [hpct] Summary of the issues: Sept 4, 2008
> Hi Guojing;
> Thank you very much for a quick response. I am also copying this
> message to the list so that everybody know we have been working on
> some mentioned issues.
> 1) I confirm, 5 is fixed. Great job!
> 2) I confirm, 6 is fixed. Very good!
> A related question is how to search for a second occurrence?
> 3) We had the histogram capability in previous releases, so why cannot
> we continue having it? What has changed since, say, March?
> 4) Please take a look at the picture you sent me in the next message:
> there are two scroll bars: internal, which is what you are looking at,
> and external, which never scrolls.
> Issue 1) Agree - difficult to repeat. But there is second part -
> broken PostScript output.
> Issue 2) Open
> Issue 3) In discussion
> Issue 4) Open
> Issue 5) Fixed
> Issue 6) Fixed
> Basically we have 3 issues, and one discussion.
> Thanks again,
> Vitali
> Guojing Cong wrote:
> hi Vitali,
> I believe I fixed 5, 6, and 3. Note that the histogram
> capability would have to depend on another software that
> we (IBM) do not own. Besides, the original Xprofiler on
> AIX does not have this capability either. If you insist on
> having that, we can open another chanel for discussion,
> and see how we might get that for you. There is no
> technical problem, the issue I believe is purely legal.
> Now for 1, as it is sporadic, we will need to find a way
> to reproduce that in a repeatable manner. It might take
> more time to fix. For 4, there is a partial fix, and we
> are working to get it in there. For 2, I am investigating.
> I remember the scroll bar is used when there are many
> function calls. I will send you a separte note with the
> xprofiler attached.
> Regards
> Guojing
> *"Vitali A. Morozov" **_<morozov at anl.gov>_*
> <mailto:morozov at anl.gov>
> Sent by: _hpct-bounces at lists.alcf.anl.gov_
> <mailto:hpct-bounces at lists.alcf.anl.gov>
> 09/03/2008 04:18 PM
> To
> HPCT Mailing list _<hpct at alcf.anl.gov>_
> <mailto:hpct at alcf.anl.gov>
> cc
> Subject
> Sept 4, 2008: HPCT: Summary of the issues
> 1) We want to be able to reduce statistics, generated in
> mpi_profile.* files, by some sort of
> MPI_Start_Statistics()/MPI_Stop_Statistics() function
> calls. As we know from I-hsin,
> MPI_trace_start()/MPI_trace_stop() calls control tracing
> part only.
> 2) According to I-hsin, "mpi_profile.<rank number> are
> generated per each MPI rank." We do not see this behavior:
> 4 files are generated instead with minimal, maximal, mean
> communication time, and collective over all tasks
> statistics file called mpi_profile.0. Please clarify 1)
> what is printed at the end of the run, 2) how to print
> statistics from a particular MPI task. Examples of the
> test run would be very useful to have.
> available" message.
> 6) peekview single_trace gives the node 0, 8, and 15.
> Example program was sent to the list already and contains
> 2 Sends and 2 Recvs. Where are the other communications?
> See attached screenshot.
> 7) peekview on selective instrumentation does not show
> correct number of calls. From 1 Send and 1 Recv, we see
> nothing on peekview screen.
> 8) HPM part does not work: core file at runtime. Please,
> give us example of 1) how to compile HPM-instrumented
> program, 2) what is the result of the run.
> 9) Xprofiler has 6 open issues:
> 1. Load Files, Filter -> Uncluster functions, File ->
> Screen Dump -> Select Target Window,
> 1. clicking now on the main window may occasionally cause
> crach
> 2. resulting file Xprofiler_screenDump.ps.0 is a
> balack-box Postscript
> 2. The meaning on exterior scroll bars in not clear, they
> never scroll.
> 3. *Removing Histogram functionality is unacceptable* A
> more complicated multistep example
> 1. Load Files
> 2. Report -> Flat Profile
> 3. Code Display -> Show Source Code
> 4. File -> Save as; File -> Close
> 5. Code Display -> Show Histogram w/Source Code
> 6. crash
> 4. Load Files, Report -> Flat Profile, Code Display ->
> Show Source Code, File -> Save as
> 1. Close the window by clicking X (not File -> Close)
> 2. Select another function in Flat Profile
> 3. Code Display -> Show Source Code; File -> Save as; crush
> 5. Load Files, Report -> Flat profile, Show Source Code,
> search anything non-existent, press enter, crash
> 6. Load Files, Report -> Flat Profile, try to search
> anything like 'asfsafd', once not found press Enter, crash
> Vitali
> hpct mailing list_
> __hpct at lists.alcf.anl.gov_ <mailto:hpct at lists.alcf.anl.gov>_
> __http://lists.alcf.anl.gov/cgi-bin/mailman/listinfo/hpct_
> hpct mailing list
URL: <http://lists.alcf.anl.gov/pipermail/hpct/attachments/20080904/ee4daa56/attachment.htm>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.alcf.anl.gov/pipermail/hpct/attachments/20080904/ee4daa56/attachment.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.alcf.anl.gov/pipermail/hpct/attachments/20080904/ee4daa56/attachment-0001.gif>
More information about the hpct
