[notify] NOTE - Possible BGP outage at 2 PM today
Andrew Cherry
acherry at mcs.anl.gov
Thu Apr 17 11:29:17 CDT 2008
Late last night, we identified a problem with the BG/P environmental
monitoring on intrepid that needs to be addressed. Unfortunately,
there is a possibility that this may result in having to restart the
control system again (we are still working with IBM to try to cover
all other options before we resort to a control system restart). We
have therefore reserved the entire system for a possible restart at 2
PM. New jobs queued on intrepid will not be started if they are
long enough run past 2 PM. We don't expect any currently running
production jobs to be impacted (since they will be finished by the
time the work begins), but long-running early science jobs may need
to be killed if they are still running and we determine that the
restart is needed.
Access to the login nodes and the filesystems will not be impacted by
this work - this will only affect the BlueGene itself.
We will send out another note when we know for sure what the impact
will be.
Thanks...
-Andrew Cherry
ALCF Support
More information about the intrepid-notify
